Author Topic: Doubled Shelf Liner for Added Dampening  (Read 2705 times)
Offline aref
« on: Mon, 24 March 2014, 17:58:01 »
GH suggested I use shelf liner to dampen the ping in my CMQFR. I did it and it worked well; but I wanted a tad more dampening. So I added a second layer of shelf line on the base layer of the case except under the R1 space-bar row, there's too little headroom for adding a second layer under the space-bar row. The result is excellent. The keys, MX Blue, sound thocky and feel great. And the additional shelf line didn't prevent the case from closing properly. All it did was super dampen the CMQFR's interior. I'm sure many of you have done this, but I hadn't read anything about it, so I figured I'd post it.
After Pacifist's comment (below), I measured the thickness of the liner I used: 1/10" thick for a single layer.
« Last Edit: Mon, 24 March 2014, 18:05:08 by SSKGuy »
Offline Pacifist
  • on hiatus
Re: Doubled Shelf Liner for Added Dampening
« Reply #1 on: Mon, 24 March 2014, 17:58:54 »
It depends on how thick your liner is
stuff as much as you can
Offline esoomenona
  • Gnillort?
« Reply #2 on: Mon, 24 March 2014, 18:00:10 »
Yeah. Just stuff as much as you can. Don't worry about if you've having trouble closing it. The screws will pull it altogether. Also, stuff some under the top as well. And stuff some more around the switches before you put the caps back on.
Offline aref
« Reply #3 on: Mon, 24 March 2014, 18:01:21 »
Good point. I just measured the thickness of the liner I used and it came in a 1/10 of an inch. The difference in the sound of the key switches and dampening is incredible.
« Last Edit: Mon, 24 March 2014, 18:04:08 by SSKGuy »
« Reply #4 on: Mon, 24 March 2014, 18:38:28 »
Alternating the waffle rubber mats with felt can work well, too.
And for those odd-shaped spaces, strips of felt rolled into appropriate-sized cylinders can be nice, and look good, too.
Offline aref
« Reply #5 on: Mon, 24 March 2014, 19:09:23 »
Good ideas. I had cut oddly shaped pieces of shelf liner to fill those odd spaces inside the case.
The interior liner I did may not be aesthetically pleasing, but it sure works great. Thanks for the
space-filling ideas.
