Author Topic: Cherry MX-Board 3.0 Stems  (Read 2649 times)
Offline drrtyrokka
« on: Tue, 25 March 2014, 08:47:10 »
Hey guys,
does anyone know, if the stems of the Cherry MX-Board 3.0 are off-centered or like the normal filco layout (centered)?
Wondering if i could use my old filco keycaps with this one, because i dont really like low-profile caps.
Thanks for help!
Greetings
Re: Cherry MX-Board 3.0 Stems
« Reply #1 on: Tue, 25 March 2014, 08:49:01 »
AFAIK the caps lock is the only odd key, it is between what we call offset and center stemmed.
Offline drrtyrokka
« Reply #2 on: Tue, 25 March 2014, 08:50:58 »
Ah okay, thank you then :)
Offline zig_ziglar
« Reply #3 on: Wed, 26 March 2014, 18:56:10 »
This is correct. If you are planning on replacing the MX3.0 keyset, I recommend purchasing a separate single keycap for the caps, just in case you fail at your first attempt at stem relocation surgery.
Offline drrtyrokka
« Reply #4 on: Thu, 27 March 2014, 01:15:53 »
Thanks again, mate. I just bought a Ducky Zero 2108 instead, think it has a better build quality.. But if I decide to buy the MX 3.0 in the future, I know what it's about.
Offline berserkfan
« Reply #5 on: Thu, 27 March 2014, 01:47:53 »
wtf, so it isn't even compatible with either offset and center stemmed caps lock?
and what does Cherry think that will do? Magically improve typing accuracy, speed, and durability of keyboard?
« Reply #6 on: Thu, 27 March 2014, 06:16:49 »
I'm guessing for whatever reason that was just the mold that devlin had for caps lock.
Offline drrtyrokka
« Reply #7 on: Thu, 27 March 2014, 08:23:17 »
It's ridicular, cherry knows about the mechanical keyboard market and i really doubt they dont realizesd what's happening here on geekhack or deskthority and all the groupbuys and stuff. Why the heck would I through a new keyboard on the market with lots of new features but dont take a standard layout... how can it be that difficult to get this...
Especially for this price, the keyboard would be nice to have it (even just for keycap storage :D)
Offline zig_ziglar
« Reply #8 on: Thu, 27 March 2014, 15:56:44 »
Honestly, I don't think geekhack (or keyboard modders in general) were the target audience for the MX3.0. Yes they've put a bit more effort in appealing to gamers, but I think they're looking more towards the group of gamers who just a keyboard with whatever is left over after buying the main system components.
Any of us here should know the MX2.0 and 3.0 are not build at a high standard. I have the 2.0 and it flexes just when I"m typing on it and just all 'round feels cheap and nasty. It is the cheapest feeling keyboard I own. The only reason I got it was because it was on special for $60 and it was the cheapest way for me to own Blues and find out if I liked them or not.
