Author Topic: Does anybody know the USB usage id of the [Fn] key of a mac keyboard?  (Read 4879 times)
Offline ecerulm
I'm a mac os x user and bought a TECK. In mac os x , when using windows 8 on a parallels vm you need to press Fn-Ctrl-C in other to emulate Win-C (the command key is reserved by mac os x so the guest cannot see it).
So I was trying to reprogram my TECK and assign the mac fn (which is not the same as the T_FN) to one of my keys but I cannot find  that key among the presets in the TECK layout editor. But the TECK layout editor allows to assign any USB usage id from usb usage page 0x07 or usage page 0x0c.
So does anybody know what is the usage page and id of the mac fn key, or the mac fn key + ctrl if the mac fn key doesn't generate a kaypress of it's own.
Any help of how to obtain the usage page /id of that key combination would be greatly appreciated.
Offline ecerulm
Re: Does anybody know the USB usage id of the [Fn] key of a mac keyboard?
« Reply #1 on: Tue, 25 March 2014, 15:31:41 »
Sorry I meant to say Fn + Cmd not Fn + Ctrl
Offline hydrospell
  • some keyboard thing
    • octobrain
« Reply #2 on: Fri, 28 March 2014, 19:41:06 »
⌨ Filco MJ2 MX Blues / M0116 Orange Alps / Homemade 60% MX Reds / M0110
Cherry MX art prints 20/50 still available!
« Reply #3 on: Fri, 28 March 2014, 20:18:28 »
fn doesn't have a keycode, as it doesn't actually send any data to the computer itself.
Offline intelli78
« Reply #4 on: Fri, 28 March 2014, 20:22:27 »
I know nothing about the TECK or its editor, and concur that on most external KBs, FN does not send a scancode. That said, the internal KB on my Macbook Pro does send a scancode. Not clear if this guy is asking about the internal Mac FN or the one on the TECK keyboard thought.
Offline ecerulm
« Reply #5 on: Sat, 29 March 2014, 02:33:28 »
I'm asking about that AppleKeyboard, what key code(s) are sent when pressing Fn+Ctrl on an Apple Keyboard?
