Author Topic: [GB] Granite Set ~ Sublimated Full PBT (spacebar included)  (Read 2489632 times)
Offline jacobolus
Re: [GB] Granite Set ~ Sublimated Full PBT (spacebar included)
« Reply #750 on: Sat, 12 April 2014, 03:26:18 »
I guess Mono Legend just isn't in the cards... :'(
I’d expect the standard Mono Legends to still make it. Probably out of luck on the international ones though.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #751 on: Sat, 12 April 2014, 03:55:12 »
I'll be working on the final legends this weekend. I'm redesigning the whole thing with illustrator to reduce chance of error with the printing process (SP surely uses Illustrator). I'll post everything here when done.
Offline mougrim
« Reply #752 on: Sat, 12 April 2014, 04:21:09 »
And Nerdom is almost reached next tier... one left :)
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
Offline justnits
« Reply #753 on: Sat, 12 April 2014, 05:08:44 »
Hi All,
This group buy looks like a great setup! There was a comment earlier in the thread about the seemingly low number of Ergodox orders, I might of found a reason. I hate to be to be criticizing your hard work Matt3o, Just hoping that there is a chance to adjust things to make the set a better fit.
I laid out the setup to figure out which key sets I would need and it seems neither the Icon/Text Pro Mod set or the Ergodoxian set have a 1.5 Tab key. You'd have to get the Icon/Text (non pro) Mod set (which is, by design, mostly filled with keys that won't fit an Ergodox) or go with the blank set. Springing for 36$ over the 115$ for the 3 base Ergodox sets for one key is a bit of a barrier. I know it's late in the game but any chance we could get a 1.5 tab key added to the Ergodoxian or Icon/Text Pro set?
At this stage I can't add/remove other keys.
Normally you'd have to take the full TKL set as a minimum, this GB is not different. The difference is that a full TKL keyboard will end up costing $62, which is pretty reasonable for a full PBT sublimated set. The split between common and modifiers is not because you can get one or another, but because you can choose between icon and text.
There seems to be quite some interest in Ergodox sets, sooner or later we might organize something specifically crafted for ergodox.
hmm...putting a tab in ergodox kit or text pro mod kit seems to make sense.
i was actually trying to find a way to buy 1 set of each to utilize the kits so that i can put them on my ergodox and a tkl board.
i find it that it will be almost perfect for me if the cyrillic doesn't have the *7 missing keys to fill up a full alpha.
then i can have tkl and ergodox with 1 missing Tab (which right now i have to get Half Blank to fill it up)
by ordering,
Base Kit,
Text Mod,
Text Pro Mod,
Numpad,
Ergodoxian,
Nerdom,
Blue Enter,
7u Spacebar,
Half Ergo Blank,
*Cyrillic <-- refer to earlier paragraph
Ducky DK9008 Shine 2 Gateron Red w/ Korean 55g gold lubed spring & custom LED | Ergodox with Aluminium top plate | IBM Model M SSK | GHPad | GON's Nerd TKL | Filco Majestouch 2 TKL MX Blue
[Sold]Keycool 87 PBT White Cherry MX Blue | [Sold]ikbc F-104 Cherry MX Brown
Offline ideus
  • Björkö.
« Reply #754 on: Sat, 12 April 2014, 08:35:06 »
Please Note:
If you purchase this deal you will only be charged the final group price
- See more at: http://www.pimpmykeyboard.com/deals/granite-set-pbt-dye-sub-dsa/
edit: really need to trim my order... can't decide between text and Icon so I want both but my wallet can't handle it right now.
Go for the icons, you may spend a few dollars more now, but you will have a one-of-a-kind set, the legends are just too common. You may get them somewhere else, but the icons are fine art you will only have this chance to get.
« Last Edit: Sat, 12 April 2014, 09:08:18 by ideus »
Offline vierax
« Reply #755 on: Sat, 12 April 2014, 17:26:53 »
All Mono will make it, we are some guys on DT working to have the Mono International :thumb:
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #756 on: Sat, 12 April 2014, 17:45:57 »
Current status:
We need 2 more Numpads, 7 ISO Enter, 1 more Nerdom, 3 more Cyrillic and 6 more Windowed!
Remember that if you can help spreading the word by adding a link to your signature. Here's how. These are the results so far http://lab.cubiq.org/granite/result.php
Also, we are running out of time! Just 4 days and a bunch of hours remaining!
If you were holding back, now it's the time to act!
Offline taylordcraig
« Reply #757 on: Sat, 12 April 2014, 18:11:37 »
I might take out a loan to make this happen.  :confused:
Offline ideus
  • Björkö.
« Reply #758 on: Sat, 12 April 2014, 18:13:12 »
If I want to add a couple of kits to my original order, how should I proceed? I know I can just add a second order, but that will require to pay an additional shipping, right?
« Last Edit: Sat, 12 April 2014, 19:13:38 by ideus »
Offline tbc
« Reply #759 on: Sat, 12 April 2014, 20:59:43 »
hehe.
window set is tipped now :D
order more!  because it's freaking expensive
Offline Photoelectric
« Reply #760 on: Sat, 12 April 2014, 21:03:46 »
Matt3o: could you please make us a nice 3D mock-up of a set-up with Cyrillic caps?  Perhaps with some other kits, like RGB or Lost and Found.
Offline minho
  • i'm kind of back
« Reply #761 on: Sat, 12 April 2014, 22:18:56 »
Can anyone give me a tl;dr rundown of all the Nerdom keycaps? I'm not familiar with the origins of many of them.
Offline rockhawksam
  • I'm a big dirty **** Hawk
    • tanglingstars.com
« Reply #762 on: Sat, 12 April 2014, 22:58:48 »
Excuse me for the total noob question, but do the cyrillic caps come with the other numbers, do you know? Because in the picture it only shows 2,3,4,6,7 for some reason.
« Reply #763 on: Sat, 12 April 2014, 23:00:22 »
They do not.  They are an add-on pack to replace certain keycaps in the base kit.  Only those keycaps that would be different on a full English/Cyrillic keyboard.  I do wish they were a full set of alphas.
Offline rockhawksam
    • tanglingstars.com
« Reply #764 on: Sat, 12 April 2014, 23:07:53 »
Damn, okay. Thanks for letting me know.
Offline osi
« Reply #765 on: Sat, 12 April 2014, 23:21:35 »
Order is in for numpad and spacebar! Thanks Matt3o
Offline mougrim
« Reply #766 on: Sun, 13 April 2014, 01:16:42 »
Nerdom kit reached next tier at last :)
Offline tbc
« Reply #767 on: Sun, 13 April 2014, 01:28:46 »
I wish it had a dark mod color for the |\ so that it would work on the ergodox.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #768 on: Sun, 13 April 2014, 01:41:06 »
it takes some time, I'll do my best but I still have to finalize all the templates.
deskthority, robot emeritus, pi, bitcoin, geekhack, atom, sad mac, glider, life heart, (just cute cats), evangelion, firefly, starwars, x11 server, linux, amiga A x2, top view of a cherry MX.
Offline mougrim
« Reply #769 on: Sun, 13 April 2014, 02:33:47 »
Hmm... 150 tier already almost here... I'll keep praying for 200 tier... even if it's a liiitle far from reality :)
« Reply #770 on: Sun, 13 April 2014, 02:54:48 »
I know that I was the one who quoted the SP website, but I would like to make certain.
If I order now and then we reach a lower price point, I will pay the lower price point after the buy ends,
yes?
edit: i went to c/o with paypal and it seemed as though I was paying.
edit2: JACKED YOUR SIGNATURE
Offline mougrim
« Reply #771 on: Sun, 13 April 2014, 04:07:17 »
yes?
Paypal locked sum of kit prices at the time of your buy. But if any of those kits will reach the next tier, all money it saved will be returned to your account.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #772 on: Sun, 13 April 2014, 08:24:54 »
It does. It's in the alpha kit.
« Reply #773 on: Sun, 13 April 2014, 09:48:35 »
If I order now and then we reach a lower price point, I will pay the lower price point after the buy ends, yes?
Thank you for clarifying. I will add more money to my account later this week and make my purchase in a day or two. [or more likely in the last 24 hours]
Granite Set (PBT, dye-sub, DSA)
Granite Text Modifiers
Granite Icon Modifiers
Granite Numpad
Granite Text Pro Modifiers
Granite 6.25u Spacebar
 Granite 7u Spacebar x2
Granite Blue Enter x2
Granite Lost and Found
Granite WASD
Granite Icon RGB
Granite Text RGB
Granite RGB Blank
Granite Mono Legend
Granite Half-Ergodox Blank
Granite Base kit Blank
Granite Additional Mods Blank
Granite Numpad Blank
Granite Windowed keys
Granite Extra Homing keys
Enough for two boards with custom layouts. One blank or minimal; maybe even egdx [when I eventually get my hands on one]
Offline mougrim
« Reply #774 on: Sun, 13 April 2014, 11:20:09 »
Heh. That's a lot :) But for two custom boards you probably need it.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #775 on: Sun, 13 April 2014, 11:45:21 »
Nerdom finally hit 25 tier! Now we need more ISO!!!
1 more for 150 common kits!
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #776 on: Sun, 13 April 2014, 12:29:33 »
We will break 150 with my order. I will be getting icon kits as well, but I won't order till the last day because of the paypal freeze stuff. Being in canada I will pay a % for what gets converted to USD and if there is a refund, it will be in USD which I can no longer withdraw from my PP account (can only withdraw Canadian funds).
It's a bit tricky working with USD from Canadian paypal, so it is much easier to deal with if the price is less likely to change.
How much is shipping btw?
Offline mougrim
« Reply #777 on: Sun, 13 April 2014, 12:32:29 »
Hmmm... Can't you pay from some debit bank card through Paybal NOT signing up?
Offline Zeal
    • Zeal Generation Inc.
« Reply #778 on: Sun, 13 April 2014, 12:46:38 »
PayPal refunds to whatever source you got the money from. So if it was PayPal balance/Bank transfer/Debit card, the refund would end up in your PayPal balance. If you purchase via CC, it'll get refunded to your CC. Only downside is, you get dinged twice by unfavourable exchange rates.  :( I believe you can also withdraw USD to Canadian banks, except it uses PP's conversion rate to CAD.
Shipping will depend on your order. If you fill in the billing/shipping info, and continue with checkout, it'll show you the shipping cost. When I did a test purchase, Base kit+ Nerd+ Enter+ Mods cost $17 shipping to Canada.
Offline squarefrog
  • \m/_
    • Ergodox Layout Stats
« Reply #779 on: Sun, 13 April 2014, 12:48:01 »
If you build it, they will come....
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #780 on: Sun, 13 April 2014, 12:58:29 »
The final nerdom kit.
Offline mougrim
« Reply #781 on: Sun, 13 April 2014, 13:06:58 »
Cool! That'll be Empire for the Pn and Republic for the Fn keys :)
...Or maybe Empire symbol will replace my Windows key. Because it's Dark Side :)
Offline TBone
« Reply #782 on: Sun, 13 April 2014, 13:35:59 »
TAKE MY MONEY! Just put in my order, so psyched. Now I have a reason to buy a Poker II ... like I needed a reason before!
All of my monies.
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #783 on: Sun, 13 April 2014, 13:38:13 »
150!
You are amazing guys!
Now head to 200!
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #784 on: Sun, 13 April 2014, 16:36:34 »
I think you have to sign up, but yes you can pay from a debit card. When you do, it will transfer the funds to USD and I pay a fee on that (and the exchange rate). Then if there is a refund, it will be in USD which can not be transferred back Canadian dollars, so they will not let me transfer that back to my bank. The only way to then use that money is to pay for something else in USD from PP. It's not a huge issue, but I would like to limit what I am forced commit to USD in PP.
Not sure if that all makes sense.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #785 on: Sun, 13 April 2014, 16:40:47 »
Thx for the shipping details zeal.
Ya, just trying to limit my losses.
I want the icon mods to get to the next tier, that is the only one I am concerned about. Pretty sure the rgb icon set won't get to next tier, but I would be stoked if it did. :)
Offline Grendel
« Reply #786 on: Sun, 13 April 2014, 17:16:00 »
Put my order in:
Granite Set 2x
Granite Text Modifiers 2x
Granite Numpad 2x
Granite Cyrillic: RU, UA 1x
Granite 6.25u Spacebar 1x
Granite Blue Enter 1x
Granite Icon Modifiers 1x
Granite Icon Pro Modifiers 1x
Granite Lost and Found 1x
Granite Icon RGB 1x
Granite Windowed keys 1x
- I'm game !
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #787 on: Sun, 13 April 2014, 17:17:45 »
Put my order in:
Granite Set 2x
Granite Numpad 2x
Granite Icon RGB 1x
Nice!  More icon sets (+RGB).  <3U
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #788 on: Sun, 13 April 2014, 17:37:14 »
current status
Offline skuko
« Reply #789 on: Sun, 13 April 2014, 19:27:34 »
dayum, it's really nice, almost everything is flipped :) almost makes me want to get the icon mods and icon RGB for the saved money lol
« Reply #790 on: Sun, 13 April 2014, 19:35:35 »
Am I understanding that after my order we need 6 more blank RGB for moq?
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #791 on: Sun, 13 April 2014, 20:42:15 »
Just do it. :)
Offline ideus
  • Björkö.
« Reply #792 on: Sun, 13 April 2014, 20:47:26 »
How many base sets do you think will the GB reach by its end?
Offline MrClaus
  • MrClaus
« Reply #793 on: Sun, 13 April 2014, 21:51:38 »
Matt3o, I've already ordered some caps sets about a week ago...If I wanted to add some more caps now, will I have to order again and pay the shipping charges again? Or can I inform you first so that paypal doesn't double charge me the shipping fees.
Offline ideus
  • Björkö.
« Reply #794 on: Sun, 13 April 2014, 21:54:39 »
I got this answer at the SP site for a similar question:
ideus says:
April 12, 2014 at 11:28 pmhow can I add two small subsets to my order without incurring in further shipping charges.
Reply
  •    Tyler Byrd says:
    April 13, 2014 at 6:48 amideus if you just check out again we will package the two orders together. Shipping is based on the weight of each individual product, so you will only pay shipping charges for the increased weight.
- See more at: http://www.pimpmykeyboard.com/deals/granite-set-pbt-dye-sub-dsa/#sthash.JXOBmHo3.dpuf
« Reply #795 on: Sun, 13 April 2014, 22:53:25 »
I dunno about the international, but there's stunningly few blank sets sold.
Wonder why ...
Offline Ronnn
« Reply #796 on: Sun, 13 April 2014, 23:18:06 »
How is the color of granite set compared to wyse dsa set( http://i.imgur.com/SddZHKx.jpg ) ?  Is the wyse's whiter than granite set? Anyone know the color code of wyse dsa set?
Offline Matt3o
  • -[°_°]-
  • ** Robot Emeritus
« Reply #797 on: Mon, 14 April 2014, 01:51:50 »
Last 3 days! Order now or regret forever!
TKL Keyboard:
Common kit + Text mods = $62
Full keyboard:
Common kit + Text mods + Numpad = $77
I'm also glad to announce that even 1.50u keyboards (and less common layouts) are sub $100 now:
Common+text mods+pro mods+7u spacebar = $95
Any ISO layout:
Common kit + Text mods + ISO Enter + Intl kit = $113
Add $6 and you also get blue enter.
we need at least 5 more ISO Enters!
At this point our target is 200 common kits, so price will be even better!
« Last Edit: Mon, 14 April 2014, 01:55:24 by Matt3o »
Offline StylinGreymon
  • Keyboard Hipstar
« Reply #798 on: Mon, 14 April 2014, 02:10:29 »
Wow, we're really gunnin' it now! :eek:
Dis gon' be gud...
If today had been a hippo, then you'd really have to worry about tomorrow.
Offline mougrim
« Reply #799 on: Mon, 14 April 2014, 03:42:57 »
It'd be nice if Cyrillic set tipped next tier...
