Author Topic: g9x makes a high pitched noise whenever idle  (Read 4518 times)
« on: Wed, 26 March 2014, 19:51:59 »
and it's driving me insane. any idea what it could be?
Offline kaz
Re: g9x makes a high pitched noise whenever idle
« Reply #1 on: Thu, 27 March 2014, 07:10:44 »
Open it up and see if the noise goes away when you press on any of the components on the circuit board.
Cherry G80-11800 (Workhorse) | Cherry G80-11900 | \'93 IBM Model M | Apple M0116
Offline atlas3686
  • HHKB Elite
« Reply #2 on: Thu, 27 March 2014, 07:29:38 »
Wow that is so crazy, I have a G9x and never head it make a sound, let us know what it was if you figure it out.
Offline kaz
« Reply #3 on: Thu, 27 March 2014, 07:48:34 »
Never realised it before but I can hear a very faint high pitched sound out of my G9X when I put it up to my ear. Seems like a pretty common problem going by google.
Offline davkol
  •  Post Editing Timeout
« Reply #4 on: Thu, 27 March 2014, 07:56:27 »
IIRC this is a known issue with some laser mice. I can't find details right now, but it's definitely been reported before.
« Reply #5 on: Fri, 28 March 2014, 18:07:55 »
maybe it's because my room is really quiet, but it's ridiculously annoying. to the point that i am no longer going to use this mouse.
yeah, a google search brings up a couple of results. sending it in was an option, as people have gotten mice that don't make that much noise but.. this mouse is like 4-5 years old now. so no RMA for me =/
Offline jwaz
  • * based mod
  • #geekhack on freenode
« Reply #6 on: Fri, 28 March 2014, 18:10:13 »
Is a capacitor going bad? Sounds like cap squeal.
Offline boradori007
  • I'm trippin bear balls.
« Reply #7 on: Sun, 30 March 2014, 02:14:06 »
I dont know why logitech discontinue this mouse.
Offline atlas3686
  • HHKB Elite
« Reply #8 on: Sun, 30 March 2014, 06:17:53 »
Had a really careful listen to mine and I can hear something! have to put my ear in the perfect spot right above it but I can hear it.
I think I might buy myself another before they disappear, some of the retailers here still have stock.
Offline PolaBurrr
« Reply #9 on: Mon, 31 March 2014, 23:27:09 »
I noticed this with my old g500 also.
Offline adhoc
« Reply #10 on: Tue, 01 April 2014, 06:55:30 »
Lower your refresh rate. Your motherboard is probably low quality. I've had the same issue until I bought a top notch mobo. You're probably using 1khz refresh rate which you don't really need anyway.
