Author Topic: Keycaps: Costar or Cherry compatible?  (Read 2483 times)
Offline morpheus
« on: Thu, 27 March 2014, 05:32:24 »
Are these keycaps from Korea, costar stabilizer compatible? or are they only Cherry stabilizer compatible?
http://www.monsterlabs.co.kr/shop/product_detail.html?pd_no=11249
thanks
Offline skuko
Re: Keycaps: Costar or Cherry compatible?
« Reply #1 on: Thu, 27 March 2014, 05:38:08 »
every MX keycap is costar compatible. you just need the stabilizer inserts. can be bought from WASDkeyboards.com for example.
be aware that some caps (such as the cherry profile) made from thick PBT may grind on the stabilizer wires. nothing you can't fix, but just be aware of it.
