Author Topic: Lubing Cherry switches.  (Read 1051 times)
Offline zeroni13
« on: Fri, 28 March 2014, 06:22:31 »
I ordered some new springs from "Sprit" and since I will be taking all the switches apart to change the springs anyway I tought I should lube them aswell, but what lube should I use? Would regular silicon lube work fine?
Phantom with Silver Vortex Case   Keychron Q6 Pro ISO Knob
Offline BlueBär
Re: Lubing Cherry switches.
« Reply #1 on: Fri, 28 March 2014, 06:53:31 »
Use one of the lube kits you can get at Techkeys or Originative, they contain Krytox which is a very good lube.
