Author Topic: ErgoDox Acrylic/Aluminum Case @ MK.com  (Read 3001 times)
Offline AKmalamute
  • HHKB Scrub
Re: ErgoDox Acrylic/Aluminum Case @ MK.com
« Reply #1 on: Fri, 28 March 2014, 15:55:22 »
 Despite being in the midst of a DIY GB for an all-aluminum solution,
I have to say "way to go" to MK
HHKB-lite2, Dvorak user
Offline Sniping
« Reply #2 on: Fri, 28 March 2014, 19:48:46 »
kmiller8 is assembling my ErgoDox for me and I bought one of these cases for the build, I'll report back on how it is and include some pictures.
Offline HPE1000
  • Keycap Paparazzo
« Reply #3 on: Fri, 28 March 2014, 20:11:28 »
What color did you go for? :D
« Reply #4 on: Fri, 28 March 2014, 20:13:20 »
Stupid logo -_-
I'm still considering getting a blue one.
Offline Sniping
« Reply #5 on: Fri, 28 March 2014, 20:41:23 »
Blue! kmiller8 already has a picture up but I'll be able to take some more pics when I get it on Wednesday with my DSLR.
« Reply #6 on: Fri, 28 March 2014, 20:52:26 »
Stupid logo -_-
You don't like the logo? I thought it was pretty cool.
« Reply #7 on: Fri, 28 March 2014, 21:50:27 »
Stupid logo -_-
I mean it's fine but on both sides, really?
Offline HPE1000
  • Keycap Paparazzo
« Reply #8 on: Fri, 28 March 2014, 22:14:11 »
Stupid logo -_-
I agree, the logo is not bad, but it really should only be on the left(or right) side. Other than that, these cases look really nice.
Offline jacobolus
« Reply #9 on: Sat, 29 March 2014, 02:40:12 »
Couldn’t you just flip the two aluminum plates over, to avoid the logos?
Offline RESPRiT
  • HHKB = ❤
« Reply #10 on: Sat, 29 March 2014, 03:04:14 »
That would probably work, although the bottoms might not be colored or something, but I suppose that's unlikely.
Offline Thechemist
« Reply #11 on: Sat, 29 March 2014, 15:09:50 »
Pretty sure logos are on both sides.
« Reply #12 on: Sat, 29 March 2014, 18:44:22 »
EDIT: Nevermind I'm dumb
http://geekhack.org/index.php?topic=56326.msg1275658#msg1275658
Yes they're on both sides.
« Last Edit: Sat, 29 March 2014, 18:58:23 by Sifo »
