Author Topic: Convert PS2 to USB  (Read 3848 times)
Offline da20valve
Convert PS2 to USB
« on: Sat, 29 March 2014, 02:12:47 »
Just wondering can all PS2 keyboard be converted to USB ?, do I need a special adapter or can I just get one of them cheap ones on Ebay.
Offline crthell
    • crthell
Re: Convert PS2 to USB
« Reply #1 on: Sat, 29 March 2014, 02:25:38 »
I'm sure somebody could shed further light on this, but basically the cheap little eBay adapters don't actively convert the signal. You need something that does.
/crthell
Mechanical Keyboard(s): Apple Extended Keyboard II M3501 (dampened Alps)
Quality Rubber Dome(s): Dell QuietKey RT7D5JTW
Offline RESPRiT
  • HHKB = ❤
« Reply #2 on: Sat, 29 March 2014, 02:34:22 »
Most of the time you should be buying a converter and not just an adapter.
Offline da20valve
« Reply #3 on: Sat, 29 March 2014, 02:54:09 »
so what's the point of the ones on eBay then ??
Offline da20valve
« Reply #5 on: Sat, 29 March 2014, 06:31:15 »
I would if they would ship to Australia....... NEXT
Offline intelli78
« Reply #6 on: Sat, 29 March 2014, 06:41:53 »
The blue cube is good but it doesn't work with every keyboard. mkawa has another high quality adapter available, good to have as an alternative. I got one. PM him.
« Reply #7 on: Sat, 29 March 2014, 18:59:20 »
I bought some from GH - I seem to recall that mkawa was involved, although I think all of that batch were sold.
So far they have worked well, even to get an old AT keyboard working on my Mac (via an At to PS/2 adaptor, then one of the PSD/2 to USB adaptors).
« Reply #8 on: Sat, 29 March 2014, 20:10:50 »
I think I mailed it to you. Anyway, it's almost certainly the ID innovations multimode USB adapter. It supports 6KRO  and is generally awesome.
However, there are reports that some PS/2 DIY OTD keyboards will not work with it.
Offline Pacifist
  • on hiatus
« Reply #9 on: Sat, 29 March 2014, 20:16:43 »
techkeys will stock mkawa's converters soon
« Reply #10 on: Sat, 29 March 2014, 20:19:11 »
I think you did!
ID innovations sounds familiar - a brief search did not turn up anything here though.
Offline Input Nirvana
« Reply #11 on: Sun, 30 March 2014, 02:13:31 »
Pi Engineering makes an active PS/2 to USB active converter. Have not found any limitations. New they are about $55. I have one or two for sale $25 plus shipping if you need. They will take 2 PS/2 devices and actively convert to one USB. They also allow a couple programmable keys.
