Author Topic: can users post model number of old mechanical +buckling sping keyboards  (Read 3797 times)
Offline da20valve
Just wondering (apart from the IMB M Model) what old keyboard are mechanical, sping buckling), wondering if users can post model numbers on keyboards that fit this description.
Offline jacobolus
Re: can users post model number of old mechanical +buckling sping keyboards
« Reply #1 on: Sat, 29 March 2014, 06:19:07 »
You may want to glance at the Deskthority wiki: http://deskthority.net/wiki/Category:List_of_all_keyboards
Offline da20valve
« Reply #2 on: Sat, 29 March 2014, 06:29:43 »
are all these Mechanical ??.
Offline jacobolus
« Reply #3 on: Sat, 29 March 2014, 07:05:01 »
Most of them. That’s also not a very complete list. But if you look up some specific type of switch on the Deskthority wiki, you can usually get a good idea of several possible boards to look for for that switch.
Offline ComradeSniper
  • HHKB Pro
Offline E TwentyNine
    • Some of My Keyboards
« Reply #7 on: Mon, 31 March 2014, 09:28:26 »
I had a weird/goofy/cool/cheap Chinese buckling spring keyboard a couple of years ago but I sold it on ebay. You can't read the numbers but it was not really very good. I would not recommend chasing one down unless you just want to add it to the collection on the shelf.
- Franklin Roosevelt 1933
« Reply #8 on: Mon, 31 March 2014, 10:05:39 »
Ya Sheng.  Crap. http://deskthority.net/photos-videos-f8/buckling-springs-can-5001cw-t2043.html
