Author Topic: [CLOSED] [GB] Alt Controller Board for HHKB  (Read 172987 times)
Offline hasu
  • @tmk
Re: [CLOSED] Alt Controller Board for HHKB
« Reply #100 on: Tue, 10 March 2015, 23:48:01 »
I ordered Rev.G PCBs days ago, they will get to me in one or two weeks.
In Rev.G I just made small two change, 1) removing unused pads and 2) refine thermal relieve of ground pad. In terms of electric it completely same as Rev.F.
https://github.com/tmk/HHKB_controller/blob/master/TODO_revF.txt
Code: [Select]
Rev.F Errata
- Poly FUSE foot print
    Size up to 3225-3228
    Recommended pads are used already, not changed. Solder jumper is removed. 03/09
- GND pin should be connected to just one side due to thermal relief
    thin spoke thermal relief is used for reset button 03/09
« Last Edit: Thu, 12 March 2015, 16:23:39 by hasu »
Offline deci
Re: [GB] Alt Controller Board for HHKB
« Reply #101 on: Wed, 11 March 2015, 12:36:36 »
Received my controller and just shopping for BT dongles and batteries now.
Has anyone found any good batteries other than the Sparkfun 1000mah (out of stock until next week) and 2000mah Ali Express one posted earlier?
Also, any BT dongle recommendations or basically any of the cheap ones on Amazon are ok?
Offline redskull
« Reply #102 on: Wed, 11 March 2015, 22:43:39 »
hi hasu,
did you get my pm? i am interested to get into que for this. thanks.
Offline hasu
  • @tmk
« Reply #103 on: Wed, 11 March 2015, 23:52:57 »
Added! Sorry, I missed.
Offline Greed
« Reply #104 on: Fri, 20 March 2015, 19:21:07 »
Missed me too! ;)
Offline hasu
  • @tmk
« Reply #105 on: Tue, 24 March 2015, 18:32:25 »
I got a buch of componentsa and controllers in the mail, next production is going to begin soon.
Offline Bromono
  • Wanabe Cicerone
  • HHKB > Your Opinion
« Reply #106 on: Tue, 24 March 2015, 19:16:36 »
:D I will def grab one. Joined to late and missed out on this
Offline Greed
« Reply #107 on: Wed, 25 March 2015, 10:50:42 »
Very excited!
Offline TheOtherAdam
« Reply #108 on: Thu, 26 March 2015, 20:26:03 »
Hi Hasu
Thanks for making these boards available, PM and payment sent.
Cheers
Adam
« Reply #109 on: Thu, 26 March 2015, 20:37:15 »
I'm definitely interested.  I'm also wondering if there's any chance that the controller might be compatible with this Topre board I recently found or if there's any way it could be made compatible.  I can provide any info needed.
« Last Edit: Thu, 26 March 2015, 20:39:03 by nubbinator »
Offline shawn24
« Reply #110 on: Fri, 27 March 2015, 21:29:53 »
just set up my usb board, it works well, thx hasu.
for Mac OSX user, if you use homeberw to install bfu-programmer, it may install the 7.0 version,
which can only successfully erase chip but not flash for me.
after several try until I download the latest 7.2 version, I succeeded flash the new hex file
and here is a question, it is said that the lion battery need protection circuit to prevent booooom
which kind of the circuit should we buy? or is it ok to use the battery without protection circuit?
Offline hasu
  • @tmk
« Reply #111 on: Fri, 27 March 2015, 22:14:34 »
shawn24, thanks for your feedback!
yeah, I've found this problem and fixed just a few days ago(03/26). I think the latest TMK has no problem with dfu-programmer 0.7. I tested with dfu-programmer 0.7.1, not 0.7.2 yet though.
https://github.com/tmk/tmk_keyboard/commit/2b7d217ebb44934dd8554f3505ab656106649a11
You should use battery with protection function. Most Lipo Battery has protection circuit itself but some doesn't. You have to check datasheet of battery vendor/manufacturer offers. I can recommend Sparkfun batteries.
https://geekhack.org/index.php?topic=56494.msg1597883#msg1597883
https://geekhack.org/index.php?topic=56494.msg1595705#msg1595705
Read this. This is enough to use Lipo. I don't know beyond what this page explains.
https://learn.adafruit.com/li-ion-and-lipoly-batteries
Offline shawn24
« Reply #112 on: Sat, 28 March 2015, 08:33:00 »
oh, the one u recommend already has built-in protection circuit. cool :thumb:
On the batteries we sell, the protection circuit is soldered onto the battery and then taped into the little cavity at the top of the battery. This is very common for lipoly cells.
« Last Edit: Sat, 28 March 2015, 08:41:49 by shawn24 »
Offline hasu
  • @tmk
« Reply #113 on: Mon, 30 March 2015, 13:40:13 »
Last weekend I could make many boards and yesterday I shipped eight packages. Updated the first post.
I'll be able to supply USB boards enough to clear all the list untill next week. And hopefully all requested BT boards also  will be made within next few weeks.
Thanks,
Offline Vizir
« Reply #114 on: Mon, 30 March 2015, 14:51:28 »
Just a FYI, my name is in 3 places on the list (bold and underlined). Not sure if that's intentional or mistake, but I wanted to point it out so that in the future there is no confusion :)
PROCESSING STATUS:
Name                List    PM      Res     Paid    Shipped Delivered   Rev
masticasesos        12/04   01/06   -----   -----   -----   -----       -
echo0               10/13   01/06   01/07   01/07   01/07   01/13       F
mashby              10/14   01/06   -----   -----   -----   -----       -
HoffmanMyster       10/14   01/06   01/08   01/08   01/08   01/17       F
Vizir               10/22   01/06   01/07   -----   -----   -----       -
jahkeup             10/25   01/06   01/07   01/07   01/07   01/24       F
jaemzp              11/03   01/10   01/12   01/12   01/13   02/01       F
cooldiscretion      11/14   01/06   01/07   -----   -----   -----       -
woodada             11/14   01/08   01/08   01/08   01/08   01/26       F
kaesve              11/16   01/08   01/09   01/09   01/09   01/14       F
osxoep              11/16   01/08   01/10   01/10   01/13   01/19       F
esoomenona          03/30   01/30   01/31   01/31   02/02   02/10       Fb
Matt3o              12/05   01/30   01/30   01/30   02/02   03/04       Fb
argcargv            10/11   01/30   01/30   -----   -----   -----       -
naasfu              10/18   01/30   02/01   02/01   02/02   02/10       Fb
bazh                10/30   01/30   01/30   -----   -----   -----       -
yicaoyimu           11/16   02/04   02/04   02/04   02/04   02/13       Fb
Elocutive           11/16   02/04   02/04   -----   -----   -----       -
Synjin              11/16   02/04   02/04   02/04   02/04   02/15       F
Jakes               11/20   02/04   02/05   02/05   02/05   02/18       F
tpc2084             01/16   02/04   02/04   02/04   02/04   02/13       F
amzee               11/17   02/15   02/18   -----   -----   -----       -
shawn24             11/20   02/15   02/15   02/15   02/23   03/04       F
shawn24             11/20   02/22   02/22   02/22   02/23   03/04       Fb
rssll               11/18   02/18   -----   -----   -----   -----       -
tzskp1              12/01   02/22   02/22   02/22   02/23   02/24       F
frontier            12/03   02/22   -----   -----   -----   -----       -
IonutZ              12/19   02/22   03/10   03/10                       G
Vizir               10/22   02/22   02/22   -----   -----   -----       -
deci                09/20   02/22   02/22   02/22   02/23               Fb
rdev5               12/04   02/22   -----   -----   -----   -----       --
x1a0                12/09   02/22   02/26   02/26   02/27   03/07       Fb
jmolino             12/29   02/27   03/06   03/10   03/11               Fb
P233                01/10   02/27   02/27   02/28   03/02   03/07       F
tinymao             01/13   02/27   02/27   02/27   02/27   03/04       F
MJ45                01/16   02/27   02/27   03/01   03/02   03/09       F
Cakered             03/07   03/07   03/07   03/07   03/09   03/13       Fj
yankez001           03/13   03/13   03/13   03/13   03/13   03/16       Fj
TheOtherAdam        01/16   03/27   03/27   03/27   03/27               G
exitfire401         01/16   03/27   03/27   -----   -----   -----       --
trizkut             01/16   03/27   03/27   03/27   03/27               G
Finn                01/17   03/27   03/27   03/27   03/30               G
rjradical           01/21   03/27   03/27   03/28   03/30               G
RoastPotatoes       02/11   03/27   03/27   03/27   03/30               G
byker               01/03   03/29   03/29   03/29   03/30               Fb
Vizir               01/07   03/29   03/29   03/29   03/30               Gb
cooldiscretion      11/14   03/29                                       Gb
coolbho3k           01/16   03/29                                       Gb
yaro_b              02/11   03/29   03/29   03/29   03/30               G
steve.v             02/16   03/29   03/29   03/29                       G
evera               02/21   03/29                                       G
beestingza          02/23   03/29                                       G
pexon               02/23   03/29                                       G
whodevil            02/27   03/29   03/30   03/30   03/30               G
duq                 03/03   03/29                                       G
snakeyes            03/04   03/29                                       G
Synjin              01/16   03/29   03/29   03/29   03/30               G
Offline hasu
  • @tmk
« Reply #115 on: Mon, 30 March 2015, 15:57:11 »
Vizir, no worry. It is intentinal and misktaken.
You changed order to BT at Jan 7. But invoice for USB was sent again wrongly at Feb 22.
Check your PMs around the dates if  you need.
Offline Vizir
« Reply #116 on: Mon, 30 March 2015, 16:31:42 »
Yep, I checked and it's easy for me, but I thought you'd have a hard time checking through the multitudes of PM's you probably receive. So I was making sure you knew of this. And it looks like you are on top of things.
Offline JanitorJoe
« Reply #117 on: Thu, 02 April 2015, 12:07:04 »
Well gosh darn, not even two weeks and my board is already in the mail!
I need to start planning my layout.
Offline FrostyToast
  • Litshoard
« Reply #118 on: Thu, 02 April 2015, 12:14:01 »
Going to make my payment tomorrow!
Quote from: elton5354
Offline Bromono
  • Wanabe Cicerone
« Reply #119 on: Fri, 03 April 2015, 09:59:40 »
anyway I can get on the list =3?
Offline kubatyszko
« Reply #120 on: Fri, 03 April 2015, 20:48:16 »
Hello, I would like to order one controller for JP (PD-KB420B), I live in Tokyo.
今日、クバです、
JPモデル(ワイアー)用一個を買いたいんですが、東京へ発送をできますか?
早めに着払いはどうでしか?
振り込みもうできますよ。
宜しくお願いします。
クバ
« Last Edit: Fri, 03 April 2015, 20:52:45 by kubatyszko »
Offline hasu
  • @tmk
« Reply #121 on: Fri, 03 April 2015, 21:09:24 »
Thanks all for your interest and support!
Finally I sent invoices for all orders in the waiting list, most of controllers can be shipped immediately or within a week in the worst case.
Now that there is no backorder and no further development for this project is needed, so I'm going to close this group buy and create my artisan service thread for this.
For a while, I'll leave this GB open so that you can still order controller boards untill my artisan service is open.
Thank you so much for supporting this project!
Offline hasu
  • @tmk
« Reply #122 on: Fri, 03 April 2015, 21:11:25 »
Bromono, kubatyszko, Thanks for your interest.
To order read the first post of this thread and PM me.
EDIT: PM=Personal Message
« Last Edit: Fri, 03 April 2015, 21:13:11 by hasu »
Offline FrostyToast
  • Litshoard
« Reply #123 on: Fri, 03 April 2015, 21:19:38 »
I just sent payment!
I don't even have an hhkb yet...
Offline byker
  • Literally Canada
« Reply #124 on: Fri, 03 April 2015, 23:33:46 »
Better order it soon! EMS shipping means that the controller is going to be there soon :)
Offline ctm
  • Hello, world!
« Reply #125 on: Tue, 07 April 2015, 16:04:29 »
Just curious, there seems to be plenty of space in HHKB, so is there possibility of stuffing a USB hub in so that the controller is connected to one port and the other two ports can be used in place of Pro 2 USB hub? (Actually I don't have great need for USB hub on Pro 2. I just think it's a little ugly to leave two holes there.)
EDIT: I just find a USB hub that looks small enough to fit into HHKB. It has 4 ports so maybe the DIP place can be an extra port? http://smile.amazon.com/Sabrent-Portable-MacBook-Windows-HB-MCRM/dp/B00L2442H0/ref=sr_1_15?ie=UTF8&qid=1428441835&sr=8-15&keywords=4-ports+usb+hub
« Last Edit: Tue, 07 April 2015, 16:36:15 by ctm »
Coming:
Ellipse Model F F62.
Offline Ngt
« Reply #126 on: Tue, 07 April 2015, 17:24:35 »
Is the sale still up for the USB controller?
Offline hasu
  • @tmk
« Reply #127 on: Tue, 07 April 2015, 17:33:58 »
ctm, totally possible. Use small controller board like Teensy or pro micro instead of this board. Or just buy HHKB Pro and sell your Pro2 :p
https://geekhack.org/index.php?topic=12047.msg1699177#msg1699177
Ngt, yes. Read through the first post and PM me.
Offline IonutZ
  • Stay awhile and listen
    • SC
« Reply #128 on: Tue, 07 April 2015, 21:24:53 »
Probably the best investment I've ever made for the HHKB... Hasu's bluetooth alt... amazing!
Offline Bucake
« Reply #129 on: Wed, 08 April 2015, 10:14:40 »
mine has arrived already :D
awesome stuff hasu, thank you
Offline yomammary
« Reply #130 on: Thu, 09 April 2015, 08:59:07 »
Hey guys,
I'm wondering if any of you compiled this using Windows using Flip.
If so, any recommendations?
As you can see I don't have much programming experience.
« Last Edit: Thu, 09 April 2015, 09:13:21 by yomammary »
RF 87u 55g | Leeku 1800
Offline shawn24
« Reply #131 on: Sat, 11 April 2015, 10:02:56 »
Hey guys,
just follow the instruction on hasu"s github, it should be detailed enough
Offline yomammary
« Reply #132 on: Sat, 11 April 2015, 10:18:45 »
Hey guys,
Alright!
Offline byker
  • Literally Canada
« Reply #133 on: Sat, 11 April 2015, 12:37:16 »
For some reason my Windows PC doesn't pick up the hhkb when I have it in bluetooth mode, but my macbook easily connected. Anyone have this issue? I have tried restarting both sides multiple times..
Offline shawn24
« Reply #134 on: Sat, 11 April 2015, 15:45:25 »
does ur pc have built-in bt module?
Offline hasu
  • @tmk
« Reply #135 on: Sat, 11 April 2015, 16:34:06 »
byker,
Windows won't find your keyboard if it is linked with Mac or other host. In this situation to make the keyboard discoverable you have to disconnect it from the host first or start pairing mode with pressing LShift+RShift+p(Magic p command).
If this is not your problem possible cause is various...
Offline byker
  • Literally Canada
« Reply #136 on: Sat, 11 April 2015, 18:55:32 »
shawn24 - no, i am using a separate bluetooth connecter.
hasu - Thanks, I will try that!
Offline Vizir
« Reply #137 on: Sat, 11 April 2015, 19:02:14 »
rec'd my Rev. Gb board a couple of days ago. Waiting for the 1000mAh battery from sparkfun before I try it out.
Offline hasu
  • @tmk
« Reply #138 on: Sun, 12 April 2015, 02:16:32 »
Thanks for your support!
Keymap editor for Bluetooth controller is available now.
Also firmware was updated in USB keymap editor.
http://www.tmk-kbd.com/tmk_keyboard/editor/index.html
This is not needed if you are already familiar with editing keymap file and building firmware. Also you cannot make use of all functions with this keymap editor. But it will be useful when you don't need fancy keymap function or you are in trouble with your own built firmware.
Offline btctopre
« Reply #139 on: Mon, 13 April 2015, 14:04:23 »
Got my controller in! With minimal experience doing anything like this before, it only took me 15 minutes or so to create my keymap using the editor, and then flash it onto the controller using Flip. Process was incredibly easy and the result is exactly what I wanted. The purchase was well-worth it, thank you hasu for you hard work!
The only issue I'm encountering is the same thing HoffmanMyster previously did, where there is a slight delay when a function layer is initially trigger (so Fn + [/Up Arrow has like a .2 second delay before moving up), but disappears if the Fn key remains pressed. This isn't as big of a deal to me, as I only have a few commonly-used keys on the secondary layer, but it is noticeable. Is there any known fix for this? I'm plugged into a motherboard back USB port, so power should be okay, and I've tried multiple ports to no avail.
Offline hasu
  • @tmk
« Reply #140 on: Mon, 13 April 2015, 16:44:56 »
Hmm, 0.2sec deay reminds me Dual role keys or Tapping in TMK terminology.
http://en.wikipedia.org/wiki/Modifier_key#Dual-role_keys
https://github.com/tmk/tmk_keyboard/blob/master/doc/keymap.md#4-tapping
What are you using actually as Fn key?
With 'Layer Switch Momentary'(L1, L2, ...) you should not have the delay, if you suffer it is a bug.
In Keymap Editor 'Layer Switch with Tap Toggle', 'Layer switch with Tap key' and 'Modifier with special function' are Dual role keys. These should have the delay inevitably from its nature.
Offline btctopre
« Reply #141 on: Mon, 13 April 2015, 17:29:30 »
I'm using the standard L1 Fn key (momentary). And I tried reflashing the firmware with my layout, then flashing the default layout and still the delay is there on both unfortunately. I'll try using it with a different computer in a couple hours and see what the result is.
Offline hasu
  • @tmk
« Reply #142 on: Mon, 13 April 2015, 18:04:48 »
Thanks for the testing.
Ah, I finally found the delay you described, never found it myself so far, I don't know why :D
It seems like this is unneeded delay and I can fix it. I'll look into source later.
Offline IonutZ
    • SC
Found a super battery
« Reply #143 on: Mon, 13 April 2015, 18:36:59 »
I'd like to know your thoughts on this - I found a really badass battery
3000mah (can be found on ebay, called a 3010080 lipo)
3mm x 100mm x 80mm
Check out the pictures
In order to install this had to take out 4 screws (only 3 pictured, also one above). With the battery installed it does not seem to affect stability of keyboard.
There is a bit of a bulge in the front. I don't think it's too bad...
This bulge is distributed across first half and second half, putting a little strain on middle hinge.
You can see the battery in the back as it sits on top of the pcb.
Size of battery
By my calculations having run it with a 500mah... This would last about 40 hours at 3000mah. Which means an entire work week without having to recharge.........
What are your thoughts?
Offline btctopre
« Reply #144 on: Tue, 14 April 2015, 00:19:47 »
You're the best  :thumb: The delay still persists on my home machine, but you adjust to it pretty quick. If you do come up with a fix, please let me know though. That would make your controller board absolutely perfect!
Offline Pemdas
« Reply #145 on: Tue, 14 April 2015, 17:26:40 »
Got my controller and got everything working, your keymap editor made everything so easy. Not only does this give me bluetooth support (something I've wanted for a looong time) but it also gives me media control keys on windows using the HHKB!
Thank you again Hasu! Love the controller  :p
Offline Greed
« Reply #146 on: Tue, 14 April 2015, 19:20:34 »
Just another happy camper here. Hasu you are AMAZING! Thank you so much for doing this. All I was looking for was bluetooth capability for my HHKB Type-S and this delivered big time. Just open the case, remove the old controller replace with Hasu's controller and plug in a battery and I was wirelessly thocking away withing 5-10 mins of receiving the controller :)
I rigged up a 1000mah battery for this just waiting for my 2000mah battery from China.
Thanks again Hasu!
Offline byker
  • Literally Canada
« Reply #147 on: Tue, 14 April 2015, 19:32:05 »
For some reason I still cannot get my computer to see my hhkb via bluetooth. I know it must be a problem on the computer's end as I have been able to sync the hhkb to other devices. This is the bluetooth adaptor I have, do you see any problems with it hasu? http://www.amazon.ca/gp/product/B005Z5HT2M
Offline hasu
  • @tmk
« Reply #148 on: Tue, 14 April 2015, 19:49:52 »
Thanks for your feedbacks. Nice to hear from users of my controller!
byker, it looks no problem with the adapter, which is 3.0 and should have backward compatibility to 2.1 that keyboard uses.
Can you connect to other PC or devices like phone? And BT LED is blinked(once per sec) while trying?
EDIT: oops
« Last Edit: Tue, 14 April 2015, 19:51:57 by hasu »
Offline byker
  • Literally Canada
« Reply #149 on: Tue, 14 April 2015, 19:58:32 »
EDIT: oops
Yup, bt led blinks once per second.
