Author Topic: Lego Case  (Read 5849 times)
Offline Vibex
  • Love y'all
Lego Case
« on: Sat, 29 March 2014, 19:26:14 »
Hey guys. I bought a Poker II a little while back, but I got it dirt cheep since it had no case. I promptly fixed that. ;D
It's still a work in progress, but I like it a ton. If you want to here me go a little more in depth on it, you can check it out on my site. LINK
Also, ignore the potato pics, I gave up on fixing my camera, so I'm using my HTC One.
59154-0
59156-1
59158-2
59160-3
59162-4
59164-5
59166-6
Re: Lego Case
« Reply #1 on: Sat, 29 March 2014, 20:00:42 »
Sweet :)
Lego wrist rest on the way?
Offline Vibex
  • Love y'all
Re: Lego Case
« Reply #2 on: Sat, 29 March 2014, 20:02:15 »
Sweet :)
Already in the works. :D Just have to find some more slanted pieces so the bumps on the bricks don't dig into my wrists.
Re: Lego Case
« Reply #3 on: Sat, 29 March 2014, 20:07:00 »
Really digging the case Vibex.  One of noko's gray stained leather rests would look incredibruuuu with it :D
Offline Vibex
  • Love y'all
Re: Lego Case
« Reply #4 on: Sat, 29 March 2014, 20:13:31 »
I already threw $100 on a different noko wrist wrest, so I'm gonna hold of on another for now. :p
Offline boradori007
  • I'm trippin bear balls.
Re: Lego Case
« Reply #5 on: Sun, 30 March 2014, 02:09:09 »
oh interesting
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Lego Case
« Reply #6 on: Sun, 30 March 2014, 02:32:58 »
Nice case!  All it needs now is a lego keycap! :cool:
Offline Vibex
  • Love y'all
Re: Lego Case
« Reply #7 on: Sun, 30 March 2014, 06:59:07 »
I've thought about making one. Did you just put a cherry stem inside the 1 stud cylinder on the bottom of the brick? Or did you cut that part of and just glue the cherry stem to the bottom?
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Lego Case
« Reply #8 on: Sun, 30 March 2014, 07:09:50 »
I removed the cylinder stud inside the 2x2 brick and then superglued a keycap stem from an unused keycap inside.
I had to sand do the bottom of the 2x2 brick a bit since it wouldn't clear the top of the mx switch.
Offline Vibex
  • Love y'all
Re: Lego Case
« Reply #9 on: Sun, 30 March 2014, 07:19:56 »
Okay, I'll get to work on that.
Offline infiniti
  • I <3 KB
  • Bob was here
Re: Lego Case
« Reply #10 on: Sun, 30 March 2014, 07:28:13 »
Some tips:
The quickest way to remove the cylinder in the lego brick is with a dremel.  Just be careful with your fingers.
Get the placement of the brick right before you super glue the stem.  It helps if you have an extra loose switch to mount the donor stem to for trial placement/fitting.
Lastly, make sure you get the "LEGO" text on the studs of the brick are the right side up before you super glue...it totally sucks to have the perfectly placed stem but then the "LEGO" text is upside down (true story) hehe
Offline Vibex
  • Love y'all
Re: Lego Case
« Reply #11 on: Sun, 30 March 2014, 07:32:31 »
Some tips:
Thanks! ;D
I have a few other things I'm working on right now, but I'll definitely give this a try.
