Author Topic: The HHKB Master Race:Should I join it?  (Read 7506 times)
Offline Roibhilin
  • Saver of Humens
« on: Sat, 29 March 2014, 19:58:50 »
I've heard lots of people saying "Get a HHKB and get out while you still can" and I'm wondering if I should sell my Quickfire TK along with some PC parts on eBay, keep my QFR, and then buy the HHKB with the resulting money.
I like the feeling of good rubber dome keyboards like the "Made in Thailand" QuietKeys so if Topres are similar at all I think I'd like them too, will I have any regrets if I get the HHKB?
QFR | Poker II | Quickfire TK
Offline Linkbane
Re: The HHKB Master Race:Should I join it?
« Reply #1 on: Sat, 29 March 2014, 20:03:07 »
Layout could be an issue, you might not like Topre, etc. Best to try Topre out first. I personally like the FC660C better than the HHKB, as it's much cheaper, also has PBT caps (comes in blank now as well), and has a more functional layout. You may really end up liking the HHKB though, but there are lots of options.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #2 on: Sat, 29 March 2014, 20:06:15 »
It's all up to you and what you like. I just sold mine after loving it for a few months but finally got fed up w the layout and not having arrows. I love my Leopold fc660c
« Reply #3 on: Sat, 29 March 2014, 20:07:25 »
I use mine on my Mac where arrow keys are not quite as much of a concern as under Windows.
Offline Roibhilin
  • Saver of Humens
« Reply #4 on: Sat, 29 March 2014, 20:09:04 »
Are the non-replacable keycaps on the Leopold an issue?
I want to get the cheaper one too since I'd have money to spare but I read something about the build quality being worse, unless that was coming from a fanboy.
« Reply #5 on: Sat, 29 March 2014, 20:25:05 »
I got the blank version since I don't like the Leopold print. Then I swapped the number row and alphas with realforce caps. If you wanted to do that you'd have to either buy a realforce like I did or find the discontinued realforce caps. Or you could just use blanks.
I do like the angle of the HHKB case better but like I like the size of the leos shift and backspace better. I've opened both up and the Leopold has a steel plate which I think is a plus. The HHKB is plastic inside. I couldn't tell a different on the USB ports or pcb. But the springs domes and sliders all were the same.
But because of the plate, the Leo has a slight noise when you type but it is gone if you dental band the sliders also can lube them with krytox for extra smoothness.
« Last Edit: Sat, 29 March 2014, 20:27:36 by dustinhxc »
Offline Roibhilin
  • Saver of Humens
« Reply #6 on: Sat, 29 March 2014, 20:40:16 »
BTW, do you guys think that the Leopold will still be in stock by April 16th? I'm getting it a few days before then for my birthday and I'm worried it'll be out of stock  :(
« Reply #7 on: Sat, 29 March 2014, 20:41:54 »
You'd have to email them and see how many they have
Offline eth0s
  • Peace & Love
« Reply #8 on: Sat, 29 March 2014, 21:47:27 »
well, I think people are saying get the HHKB before the prices go back up due to the changing currency exchange rate of the Japanese Yen.  I haven't heard anything about PFU not continuing to make the HHKB pro 2.  They have been making it since 2006, and it just gets more popular each year, so I don't see why they would stop making it.
Offline Roibhilin
  • Saver of Humens
« Reply #9 on: Sat, 29 March 2014, 22:13:59 »
BTW, is the miniUSB cable included with the Leopold? It isn't listed on the product page.
Offline ComradeSniper
  • HHKB Pro
« Reply #10 on: Sat, 29 March 2014, 22:25:58 »
Mine came with one.
« Reply #11 on: Sat, 29 March 2014, 22:29:28 »
Can you explain why arrow keys aren't needed as much on a mac?  I've never thought of them as being an OS-specific feature and I'm curious why you say this.
Offline esoomenona
  • Gnillort?
« Reply #12 on: Sat, 29 March 2014, 22:36:53 »
Because people don't use Macs to do any actual work.
« Reply #13 on: Sat, 29 March 2014, 22:56:25 »
I happen to like the HHKB layout. Once you get used to it, its hard to switch back to a "standard" layout again. That's one reason I live keyboards with programmable controllers. I can program Caps Lock to be Control, Fn+Tab to be Caps Lock, and swap the backspace and backslash keys. If I used the tilde key much I might find it annoying to go back and forth with different keyboards, but I don't, so I don't. :)
« Reply #14 on: Sat, 29 March 2014, 23:02:14 »
You mean like they won't stop making coloured Topre keycap sets?
Because you can use control sequences to do many things.  Ctrl-A = beginning of line, ^F = forward, ^B = backwards, ^E = end of line, that kind of thing.
Under Windows ^A is select all, but on Mac select all is Command-A.
Mac is closer to its Unix origins.
« Reply #15 on: Sat, 29 March 2014, 23:09:49 »
Hmm, interesting.  Well we do have Home and End for beginning and end of line, but F and B seem rather awkward and non-intuitive choices for forward and backward.  But if you find it easy then that's all that matters.  :)  I guess I'd need to try it myself to see.  Sorry for slight off-topic.
« Reply #16 on: Sat, 29 March 2014, 23:15:51 »
https://en.wikipedia.org/wiki/Control_key
Offline PolaBurrr
« Reply #17 on: Sat, 29 March 2014, 23:16:26 »
doo eet!
Offline Roibhilin
  • Saver of Humens
« Reply #18 on: Sun, 30 March 2014, 08:57:42 »
OK guys, you've convinced me to get a FC660C, I'll probably post a review when it comes  :)
Offline morpheus
« Reply #19 on: Sun, 30 March 2014, 09:27:32 »
For me, keyboards are more like a tool. Sure, the aesthetics come into play, but it doesn't matter as much. The fact is, I need to be as productive as possible, and I can't do it without the arrow keys. I need to know that when I'm typing I'm in full control, so I can hum away without even thinking about it.
I too once owned an HHKB, but I just couldn't justify keeping it, especially at its price. The FC660C gives me everything I need and then some, at a lower price point.
Offline Linkbane
« Reply #20 on: Sun, 30 March 2014, 09:57:59 »
Great choice. Welcome to the club!
Offline acsim
« Reply #21 on: Sun, 30 March 2014, 14:59:39 »
I am a proud owner of both the FC660C and the HHKB. I'd definitely say I am having more fun with the HHKB but the FC660C is no slouch. The reason I use HHKB more often is that somehow the layout allows me to find my way around the keyboard more easily. I don't know why that's the case but from the many posts I've read, tells me that the FC660C is more 'flat' whatever that means. I personally can't tell the difference when comparing them side by side. But I do feel the difference when typing. Other than that the FC660C is a smoking piece of machinery by any standards, whether you're pulling the trigger on any of them, you would have our blessings!
Cheers!
Offline Roibhilin
  • Saver of Humens
« Reply #22 on: Sun, 30 March 2014, 22:18:45 »
Cheers!
Cheers!
Update:
Offline Linkbane
« Last Edit: Mon, 31 March 2014, 10:47:57 by Linkbane »
Offline Linkbane
Offline tns
« Reply #26 on: Mon, 31 March 2014, 13:10:39 »
I guess HHKB fans prefer it over Leopold because of its cute layout? I might be wrong
And those who prefer Leopold over HHKB is because of more standard layout?
Even thought I don't really know...
Actually I wanted to ask, do we have Leopold switching to HHKB, but why?
Offline acsim
« Reply #27 on: Mon, 31 March 2014, 13:56:47 »
The main reason why I chose to use the HHKB as my daily driver is the layout like you mentioned. I mean, that's the main draw of the HHKB. But I also noticed that the HHKB has a lower profile(slimmer, less height), especially on the bottom rows, compared to the FC660C. This is very noticeable for me as I float my wrists while I type and I have to raise my wrists significantly higher when using the FC660C.
So in that sense, typing on the HHKB is also more comfortable for me.   :thumb:
Offline Linkbane
« Reply #28 on: Mon, 31 March 2014, 14:00:53 »
You have to raise your wrists on the FC660C? I float and type pretty well, and that's never been a problem for me. Must be body shape, I suppose.
The reason that the HHKB has a lower profile is probably because of the keys it uses. Standard Topre keys for the HHKB/Realforce boards use a more Cherry-like profile, while the Leopold uses something between that and an OEM. I've played with a friend's HHKB once, and it wasn't very different for me, but I can certainly see why people might like the HHKB; the look is lovely. I can't go without arrow/window keys, but it's not made for people like me.
Offline thesentinel
« Reply #29 on: Mon, 31 March 2014, 15:25:44 »
Does anyone know if the 660c comes in white? I really like white keyboards and they seem so uncommon. IF they do come in white, where would a man buy them?
Keyboards are the only thing keeping me from consuming human flesh.
Offline Beca
  • what am i doing with my life
« Reply #30 on: Mon, 31 March 2014, 16:01:22 »
I don't believe they produce white FC660Cs. But, they did recently-ish release the white FC660M, so it's possible that they are planning to come out with a white FC660C.
« Reply #31 on: Mon, 31 March 2014, 16:40:44 »
I've only seen the MX version in the white.
Good job welcome! I have the blank model since it's hard to find 1.25 keys
« Reply #32 on: Mon, 31 March 2014, 19:47:03 »
I've been looking for a white FC660C since the FC660C appeared.  No joy.
« Reply #33 on: Mon, 31 March 2014, 21:27:51 »
I was actually curious if the m and c cases are swappable. The m goes for $100 I'd pay that for a case.
Offline eth0s
  • Peace & Love
« Reply #34 on: Mon, 31 March 2014, 21:39:31 »
Well, a man doesn't ask.  A man just does.
But no, Leo does not make the FC660C in white.  At least not yet.
Offline Smasher816
  • HHKB Master
« Reply #35 on: Mon, 31 March 2014, 22:54:08 »
I know a lot of topre boards (ex: the HHKB) have the case as part of the keyswitch construction. Since the F660M doesn't use sliders and is just a different design in general I would doubt it would work for a topre board.
But what do I know. I fully expect someone to reply proving me wrong.
