Author Topic: What Linux Distro do the Linux users of GH use?  (Read 1148274 times)
Offline blackbox
Re: What Linux Distro do the Linux users of GH use?
« Reply #150 on: Wed, 16 April 2014, 16:22:52 »
I just started playing around with SliTaz because I wanted a super lightweight distro with a UI.  Can't beat a 35MB iso file.  :)
It is pretty good so far.  Pretty much everything I need and it is pretty intuitive.  Stuff like the networking just worked out of the box, I didn't have to do anything special.  That is always nice...
Nice, I used a liveusb of ophcrack (Running slitaz) and it was pretty nice considering how much space it takes.
« Last Edit: Mon, 21 April 2014, 11:20:11 by blackbox »
The LAN table!
Offline sth
  • 2 girls 1 cuprubber
« Reply #151 on: Thu, 17 April 2014, 01:20:14 »
yes you dang well can http://distro.ibiblio.org/tinycorelinux/
and if you're not a wimp: http://ttylinux.net/
Offline esko997
  • Linux Lover
« Reply #152 on: Thu, 17 April 2014, 09:47:55 »
Woah ttylinux looks really cool, definitely going to play around with this tonight.
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #153 on: Thu, 17 April 2014, 10:23:15 »
TTYLinux doesn't have a UI included does it?  I use ttylinux on CloudStack cause it is tiny...
tinycorelinux is pretty ugly i must say...
« Last Edit: Thu, 17 April 2014, 10:25:19 by swill »
Offline Lurch
« Reply #154 on: Thu, 17 April 2014, 11:37:01 »
I was starting to build up a CentOS server from the ground up with no pre-installed dependencies, but as a Linux novice, this proved to be very difficult. I feel like the debugging/troubleshooting aspect of a Linux environment needs to be learned from the command-line environment (from a netadmin perspective at least), to be able to support Linux for a company/enterprise.
I have a "lab environment" with two Fedora Clients, and CentOS. Fedora seems to be solid for end users in a business setting, but I probably wouldn't use it at home.
Quote from: Flyersfan1
Offline osi
« Reply #155 on: Fri, 18 April 2014, 10:31:45 »
Tinycore is awesome! I need to check out this ttylinux...
Offline tricheboars
  • Keyboards are Important!
« Reply #156 on: Fri, 18 April 2014, 10:40:16 »
arch and mainly centOS
Offline TacticalCoder
« Reply #157 on: Fri, 18 April 2014, 19:50:59 »
btw... I do agree that Debian lacks behind when it comes to packages / releases. That's why I compile important stuff from sources, like Emacs. I admit it's a bit crazy: I think Debian still ships Emacs 23 (or maybe even 22!?) even though we're already at Emacs 24.3 and Emacs is not exactly a software which comes up frequently with new major releases.
The reason I use Debian is that it's rock-stable solid. My desktop regularly reaches 6 months of uptime (typically it's restarted when there's a black-out or when I move my desk, neither of which happens often). It's a desktop with a core i5 - 3450s (very low max TDP), 80+ gold alim, no GPU (only the integrated one), SSD, etc. so the electricity consumption is really not an issue (and it's ultra-quiet) and I can leave it on all the time.
I've had a dedicated server with Debian on it which reached 4 years of uptime (no critical security hole affecting its setup during these four years, so no need to restart it!). It got restarted the day the motherboard eventually died and got changed by the company I was renting the server from. That's why I'm "sold" on Debian.
Sure, they may lack a bit (or a lot) behind on software releases but they've chosen to create an insanely stable distro and they totally delivered on that front.
Easily six months of uptime for a desktop. 'nuff said  8)
Offline smknjoe
« Reply #158 on: Fri, 18 April 2014, 20:02:37 »
I figured that was a given. ;)
Yeah, you can pretty much go indefinitely with good ole Deb. Slackware, is much flakier out of the box and requires quite a bit of modding to get it stable, but when you get it there it's just as stable as you can get.
SSKs for everyone!
Offline osi
« Reply #159 on: Sat, 19 April 2014, 09:30:24 »
Slackware flaky!? I politely disagree!
On another note. I'm going to be leaving fluxbox behind and switch to a tiling window manager. Been trying out awesome and i3 and so far i3 is taking the cake.
Hopefully I can nail down my config before Monday, for the most part.
Offline sulonen
« Reply #160 on: Sat, 19 April 2014, 10:18:59 »
I used Red Hat from ~96 to 2002.. Debian ever since. Personally, not a fan of all the 'extra' stuff (...and their dependencies) many distros install.
This. RedHat was popular for a variety of reasons during the DotCom era - primarily the ease of configuration provided by RPM, but I feel that Debian is actually a more mature product. The Debian community is far and away the most abusive and intolerant group of netizens I've encountered, but they do keep the distro honest.
I run Debian on systems that I have control over. Dependencies are handled (to my mind at least) intelligently. We use Suse at work for a variety of application servers, and Debian for utility boxen. I believe Suse is a RedHat deriivative; it seems to be popular among DB middleware providers tryiing to get away from Solaris. Java is a teensy bit more challenging on Debian, but not bad.
(And darn this bouncing "I" on the Black Widow ultimate I'm using right now. I'm about ready to throw this board away and go back to one of my Das or get the HHKB out of my bag... Anyone else have problems with QC on Razer boards? It's not like they cost that much less than "real" boards...)
And vim. Yes. emacs is the product of dementia.
« Last Edit: Sat, 19 April 2014, 10:24:01 by sulonen »
Offline dante
« Reply #161 on: Sun, 20 April 2014, 20:12:45 »
I put Lubuntu on my dad's PC today.  With all his porn spyware/etc he was getting along with it being XP it was time to get him on something new.
Not bad - especially on a single core w/ 512mb.  Most of the bloat comes from the web browser not the OS.
Offline marcusant
« Reply #162 on: Sun, 20 April 2014, 20:51:28 »
I use Arch on all of my home PCs and Debian on my servers.
The AUR in Arch makes it pretty much impossible for me to switch to anything else and stick to it for over a week. I also like FreeBSD (not Linux, but whatever), but hardware support is hit or miss.
Offline esko997
  • Linux Lover
« Reply #163 on: Sun, 20 April 2014, 20:56:09 »
Nice, another Archer. Do you game on your Arch install?
Offline marcusant
« Reply #164 on: Sun, 20 April 2014, 21:02:11 »
I hardly game much, but when I do I usually just play the games that are natively ported over to *nix on Steam (I don't bother with WINE or anything). I have a Windows partition on my desktop if I feel like playing anything that isn't supported natively (I have a lot of extra disk space).
Offline esko997
  • Linux Lover
« Reply #165 on: Sun, 20 April 2014, 21:04:05 »
Nice. Yah the only game I really play is DoTA2, which runs great on Arch. Really impressed with the porting.
Offline fishfalcon
« Reply #166 on: Tue, 22 April 2014, 22:00:00 »
I dual boot arch and windows 7 on my Thinkpad, and am using Debian and win8 on my desktop... I only use windows for adobe software, and  Steam.
I'm thinking of switching to debian from arch... its stability is far more valuable to me than being 'bleeding-edge' rolling release. I remember updating my gnome desktop roughly a year ago only to discover that my gdm.service broke, and had to rescue by usb :( not a dealbreaker, but an unexpected inconvenience. A bigger inconvenience is depending on AUR packages which are or are not kept up to date, which can cause breakages... Since I only really 'edit text'/code in linux, i don't need much else... my biggest extravagance is using KDE :)
WASD Code TKL (MX Greens) | Model M Industrial
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #167 on: Tue, 22 April 2014, 22:04:48 »
People (ok, person) mocked me for calling Steam a mission-critical app.  It is good to see I have a brother in Windows-for-Adobe-plus-Steam!
Rock on, fishfalcon!
 - Ron | samwisekoi
Offline fishfalcon
« Reply #168 on: Tue, 22 April 2014, 22:09:49 »
Heck yea! MS paint hasn't been a killer app for me since kindergarten! lol
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #169 on: Tue, 22 April 2014, 22:12:47 »
If it wasn't for Adobe Photoshop and Illustrator, I would be using a Linux machine as my daily driver.  I did for 7 years, but GIMP and Inkspace just were not cutting it for me then.  They may be better now, I should check.  Currently using a Mac as my core laptop but all my other environments are Linux.
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #170 on: Tue, 22 April 2014, 22:29:11 »
I have switched to GIMP and Inkscape for 90% of those tasks.  Sometimes I have to drop back to Photoshop, but rarely.  Visio and video production are Windows tasks for me still.  And some Word things that need "real" Word for compatibility with HR departments, etc.  Gimp and Inkscape are worth a re-look now.
And Steam, but don't give up your gaming machine just yet.
 - Ron | samwisekoi
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #171 on: Tue, 22 April 2014, 23:25:50 »
 - Ron | samwisekoi
I will check them out again...
Ya, I play LoL and thats pretty much it.  Working well on my Mac right now, but I have not tried on a Linux machine yet.  I played WoW on a really old Linux machine with WineX for a long time.  Performed perfectly...
Offline iri
« Reply #172 on: Wed, 23 April 2014, 05:19:53 »
you won't believe!!!!!1111111 gimp can use a single window layout now!!!!1111111
-Ray Bradbury
Offline Demetrium
« Reply #173 on: Wed, 23 April 2014, 12:52:21 »
Debian for work, gonna try out Ubuntu on an old laptop though.
Offline abjr
    • abjr.org
« Reply #174 on: Wed, 23 April 2014, 13:00:48 »
I have been using Slackware at home and on my personal servers since 1994. However, within the past year I have transitioned to Mint on my desktop at home. At work it's all SuSE.
CM QFR | magicforce 68 (Gateron) | magicforce 68 (Outemu) | Acros 6311-K
Offline Altis
« Reply #175 on: Thu, 15 May 2014, 19:22:15 »
The only Linux I use is Slacko Puppy, booted from a USB 2.0 drive. I use it because I can boot it on my work laptop while on the go and don't have to worry about the whole encrypted work drive/spyware/keyloggers.
It boots very quickly and seems to just work without issue. I also really like being able to instantly access multiple desktops with Alt+1-4. Might try 5.7.1 'Precise' and see if it's any good.
To be honest, though, I know very very little about Linux, and find it difficult to get into as everything is straight away over my head.
Offline Vibex
  • Love y'all
« Reply #176 on: Thu, 15 May 2014, 20:02:02 »
I've recently moved from funtoo to sabayon. Not a huge change, but way less effort to work with. :p
Offline physicsmajor
« Reply #177 on: Sun, 18 May 2014, 23:45:24 »
Linux Mint for mobile, Scientific Linux on workstation. The latter is just impressive.
Offline luisbg
« Reply #178 on: Mon, 19 May 2014, 00:48:46 »
Currently running Fedora 20 because it makes it easy to develop against GNOME bleeding edge.
I roll around Fedora, Debian and gentoo. Debian being the one I end up spending the most time on.
Leopold FC660M - Brown mx switches - black case - white blank keys :: ErgoDox - Blue mx switches - classic case - black blank keys
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #179 on: Tue, 20 May 2014, 09:29:18 »
I use Windows 98.
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #180 on: Tue, 20 May 2014, 09:34:34 »
I use Windows 98.
Garbage... go troll a different thread.
« Reply #181 on: Tue, 20 May 2014, 09:35:23 »
I use Windows 98.
Windows 98 is not garbage. Don't make yourself look like a fool saying things like that.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
« Reply #182 on: Tue, 20 May 2014, 09:40:47 »
mint
-Enzo Ferrari
  • Live long and prosper
« Reply #183 on: Tue, 20 May 2014, 09:42:58 »
Ubuntu. Cuz it's the most mainstream.
tp thread is tp thread
Offline iri
« Reply #184 on: Tue, 20 May 2014, 11:25:03 »
y u no hipstah
-Ray Bradbury
Offline swill
  • builder & enabler
    • swillkb.com
« Reply #185 on: Tue, 20 May 2014, 11:54:57 »
I use Windows 98.
Blue screens of garbage...
« Reply #186 on: Tue, 20 May 2014, 11:59:15 »
I use Windows 98.
Those are purely fictional. They only happen when you use crappy browsers like Firefox.
Offline luisbg
« Reply #187 on: Tue, 20 May 2014, 12:39:31 »
I use Windows 98.
Windows 98 != Linux
Windows 98 != a real operating system
« Reply #188 on: Tue, 20 May 2014, 12:43:24 »
I use Windows 98.
Windows 98 != Linux
Windows 9x = a GUI for DOS, so you're technically right.
Offline luisbg
« Reply #189 on: Tue, 20 May 2014, 12:49:28 »
I use Windows 98.
Windows 98 != Linux
Yeah, it is what I meant. Just a shell of DOS, and a copycat of Apple at that.
« Reply #190 on: Tue, 20 May 2014, 13:06:43 »
I use Windows 98.
Windows 98 != Linux
FTFY. (I do this all the time too).
Offline luisbg
« Reply #191 on: Tue, 20 May 2014, 13:23:56 »
I use Windows 98.
Windows 98 != Linux
Oooops
Offline user 18
« Reply #192 on: Tue, 20 May 2014, 13:46:11 »
Update here: Mint 15 Cinnamon on a laptop, Mint 16 Cinnamon on my desktop -- dual boot win7 :( -- Ubuntu server 12.04.4 LTS on my new samba file server box.
Avatar by ashdenej
Offline airlangga07
« Reply #193 on: Wed, 21 May 2014, 04:53:04 »
#! Linux, with i3wm, plus firefox+vimperator. my little setup with minimum usage of mouse.
Offline C5Allroad
  • Formerly HUNTERANGEL121
« Reply #194 on: Wed, 21 May 2014, 14:40:09 »
Ubuntu here... Still learning ins and outs of Linux lol
Offline Protato_Tubby
  • people enthusiast
« Reply #195 on: Wed, 21 May 2014, 16:53:52 »
Yup, most people start on 'Buntu! :D
Have fun!
DELL AT102W Black Alps | IBM Model M 122 | Matias Tactile Pro 4
Offline user 18
« Reply #196 on: Wed, 21 May 2014, 17:11:28 »
Enjoy it. I find it much more functional and powerful than windows. If I wasn't so tied to my games, I'd give it up entirely.
Avatar by ashdenej
Offline luisbg
« Reply #197 on: Wed, 21 May 2014, 17:51:19 »
Nobody has said gentoo yet. That makes me sad.
If I weren't so busy hacking on code, and needing to install libraries easily in a jhbuild for it. I would be tempted to go back.
For now debian and Fedora serve me right.
Offline brainT
« Reply #198 on: Wed, 21 May 2014, 18:10:55 »
I started out on Ubuntu but have mainly stayed with Crunchbang with a few brief forays into other distro's.  I've been curious about both Arch and Gentoo so I'll probably end up giving one or both of them a go when I have the time/patience needed to do so.  I've also been meaning to play around with Mint as we sell refurbed Thinkpads with it at work and it would be good to be at least somewhat familiar with it.  So many distro's, so little time...
Offline luisbg
« Reply #199 on: Wed, 21 May 2014, 18:15:24 »
Ubuntu isn't what it used to be. I recommend people that like Ubuntu to switch to debian.
And to think I used to lead an official Ubuntu derivative distro.
