Author Topic: Tool Recommendation for separating CM and Filco keyboard housings  (Read 3645 times)
Offline aref
GH: Is there a special tool, self-made or purchased, that you use to separate
the upper from lower case when disassembling keyboard housings?
Thanks for the assist.
Re: Tool Recommendation for separating CM and Filco keyboard housings
« Reply #1 on: Sun, 30 March 2014, 11:21:30 »
A credit card
Offline Pacifist
  • on hiatus
« Reply #2 on: Sun, 30 March 2014, 11:40:09 »
A credit card
+1
Its really as simple as that
Offline Candyflip
Offline amos5606
« Reply #4 on: Sun, 30 March 2014, 11:43:38 »
You can use a Swiss army knife, I think it's much more stronger than a credit card.
What will fill your hearts with delight ,,
Offline aref
« Reply #5 on: Sun, 30 March 2014, 11:48:24 »
Thanks for the collective recommendation.
I've three zero-balance Starbucks' cards that are
going to be used to disassemble keyboards.
« Reply #6 on: Sun, 30 March 2014, 11:51:57 »
I used a butterknife on the first one, but after that, have been just using my fingers.
Of course, the best tool is a nylon stick, also called a "black stick" or "spudger".
« Reply #7 on: Sun, 30 March 2014, 12:16:38 »
There is a plastic tool coolermaster sends with the replacement tops. It works well.
Offline aref
« Reply #8 on: Sun, 30 March 2014, 12:57:08 »
I took a look at CM's website and couldn't find any info. If you have information
on the plastic tool, I'd appreciate it if you could forward to me. Thanks.
« Reply #9 on: Sun, 30 March 2014, 13:32:54 »
It comes in the package when you buy the topcase from CM. It's just a little piece of white plastic, but it seriously is the best tool for the job.
Offline strict
  • TKL Zealot
« Reply #10 on: Sun, 30 March 2014, 18:19:13 »
Plastic razor blades. IMO, even easier than a credit card and doesn't damage the plastic at all like a butter knife.
http://www.amazon.com/Plastic-Razor-Blades-Double-Scrape/dp/B0050P0PJQ
Offline aref
« Reply #11 on: Sun, 30 March 2014, 18:31:47 »
Nice! These are worth having on hand. Thanks for the tip and the link. I ordered two packs.
Offline HPE1000
  • Keycap Paparazzo
« Reply #12 on: Sun, 30 March 2014, 19:39:05 »
Yep, the tool that comes with replacement QFR top covers is amazing.
I know you already ordered something else, but putting it out there for people down the road I guess.
Offline laffindude
« Reply #13 on: Sun, 30 March 2014, 22:36:52 »
http://www.bricojapan.com/uploads/5/0/8/7/5087591/1869422_orig.jpg
I use one of those iPhone opening tools. Those blue stick thingers.
« Reply #14 on: Sun, 30 March 2014, 22:41:45 »
59217-0
You can sort of see it in this pic. IF mkawa still has any of those cheap QFR tops it's worth buying one to get the tool :D
I'd offer you one of mine but I keep losing them :(
Offline laffindude
« Reply #15 on: Sun, 30 March 2014, 22:53:28 »
^Ah those things. I was given one but don't know where I put it. I'll see if I can get a few more. iPhone tool works well enough for now.
« Reply #16 on: Sun, 30 March 2014, 22:54:16 »
Plastic or even metal putty knife.  I've tried several different things and hands down the putty knife works the best every time.
Offline clickclack123
« Reply #17 on: Mon, 31 March 2014, 00:24:13 »
They're called "spudgers" or pry tools. I bought one on ebay a while back and it's probably the tool that I've used the most out of anything!! Best dollar I ever spent!!
59227-0
Offline CommonCurt
  • One of the cool kids
  • 🍒 Beige or Bust
    • My Flickr Page
« Reply #18 on: Mon, 31 March 2014, 00:37:40 »
Hands down the little tool that comes with QFR replacement case.  Works better then anything else that I have tried. Plus it doesn't scratch anything up.
Some of Ye ole  Keyboards -->
WTB/WTS/WTT ---->
