Author Topic: Where to get Cherry Mx Springs?  (Read 1881 times)
Offline wezkoz
« on: Sun, 30 March 2014, 13:48:30 »
Can someone please help me find a source to purchase cherry mx clear springs (55g)?
Looking to swap my red to clears (non tactical, non clicky, 55g) Thanks !!
Re: Where to get Cherry Mx Springs?
« Reply #1 on: Sun, 30 March 2014, 13:50:47 »
Not quite the same weighting as cherry MX springs but here are some Korean springs.
The weight is measured at full compression, instead of half like MX springs.
Offline Zeal
    • Zeal Generation Inc.
« Reply #2 on: Sun, 30 March 2014, 13:58:47 »
There's a group buy that's currently running for Gold Plated springs of numerous weights.
http://geekhack.org/index.php?topic=55888.0
Offline davkol
  •  Post Editing Timeout
« Reply #3 on: Sun, 30 March 2014, 17:00:53 »
Are sprit's "clear"/'grey" springs progressive (if you know what I mean)?
Offline QuadGMoto
« Reply #4 on: Sun, 30 March 2014, 17:07:14 »
They should be linear, as on the chart here.
Offline davkol
« Reply #5 on: Sun, 30 March 2014, 17:23:50 »
All those /restricted/ functions are linear. The important part is that stock clears have a steeper curve. If sprit's clear-like springs are like that and not like panda clears, it's awesome.
