Author Topic: Question about lubing Filco  (Read 1618 times)
Offline boradori007
  • I'm trippin bear balls.
« on: Sun, 30 March 2014, 16:24:08 »
Hey guys,
I currently have Filco TKL Brown Majestouch which I had for about 3 years and I thought maybe I should go ahead and apply some lube to make it as good as new. Now this is my first time modding a keyboard so I wanted to ask which lube is beat for my keyboard and is there a guide or video tutorial on how and where to lube my keyboard? Thanks in advance!
Offline Candyflip
Re: Question about lubing Filco
« Reply #1 on: Sun, 30 March 2014, 16:42:46 »
Here is a neat video guide for lubing the switches, visit this guys YT channel got some very useful videos  :thumb:
Offline boradori007
« Reply #2 on: Sun, 30 March 2014, 16:49:04 »
Thanks for that video, great tutorial. Anyway I wonder if it's necessary to lube every spots that he did on the video. That sure will take a long time. Also any recommendation on which lube to use?
Offline Candyflip
« Reply #3 on: Sun, 30 March 2014, 16:53:04 »
http://techkeys.us/products/krytox-switch-lurbricant
The thick formula is for switches with tactile bump (like blues/browns/clears) and the thin is for linear (reds/blacks). The most important spot is the sliders of the stem, if you want to save on time you can skip lubing the spring.
Offline boradori007
« Reply #4 on: Mon, 31 March 2014, 00:30:52 »
Thank you
