Author Topic: keyboard feet  (Read 3005 times)
Offline nvus
keyboard feet
« on: Sun, 05 April 2009, 00:21:28 »
Is it ergonomically better for my hands/wrist to have the keyboard feet up or collapsed (so keyboard is flatter)?
Offline wheel83
keyboard feet
« Reply #1 on: Sun, 05 April 2009, 00:27:32 »
"they" say having your wrists bent upwards is not ergonomically correct.  i like mine down personally.
I <3 BS
Offline Hak Foo
  • Make America Clicky Again!
keyboard feet
« Reply #2 on: Sun, 05 April 2009, 13:17:04 »
Quote from: webwit;27116
I've read conflicting ergonomic reports about that. First there's the "keep it as low as possible" school from the soft science western ergonomics branch, based on the principle of not bending your wrists.
Plus, there's the assumption that you're lying your wrists on the table.  It would be interesting to see if people do or don't.  I don't, because the comical two-fingered way I type, my arms have to move substantially.
Overton130, Box Pale Blues.
Offline itlnstln
keyboard feet
« Reply #3 on: Mon, 06 April 2009, 07:09:40 »
Whether correct or not, I keep the feet colapsed.  I like the 'board to lay flat; It's more comfortable that way, IMO.
Offline FKSSR
keyboard feet
« Reply #4 on: Mon, 06 April 2009, 08:02:56 »
For me, it depends on the keyboard.  I am typing on my Macally MK96 right now, and I have to have it flat.  When I type on an AT101W or my Filco, I have to have them at a tilt.  In those cases, it seems to have to do with how much pressure I have to put on the keys.  My Model M also lays flat, to support that theory.
Also, when talking about ergo, I am pretty sure that you should start from a correct typing technique.  Of course, people can use whatever works for them, but there really is a best practice.
Add me on Steam | Twitter
Offline itlnstln
keyboard feet
« Reply #5 on: Mon, 06 April 2009, 08:28:28 »
Quote from: FKSSR;27227
Look closely at the keys, too.  I wonder if the Macally has spherical keys (keys that are angled if you look at them from the side.).  The Filco and the Dell do not.
Offline patrickgeekhack
keyboard feet
« Reply #6 on: Mon, 06 April 2009, 08:50:15 »
It also depends on how high the keyboard is setup. If I'm using a keyboard tray, I won't tilt the keyboard, but will if I'm not using a tray.
Cherry MX Blue: Cherry G80-3000, Das Keyboard Model S Ultimate
Cherry MX Brown: Filco Majestouch, Compaq MX11800
ALPS: AEK, AEK II, Northgate Omnikey Ultra, Matias Tactile Pro 4
Topre: Realforce 103UB
Buckling Spring: IBM Model M 1390120
Previous owned: Unicomp Customizer 104, IBM Model M 1390141, ABS M1
Offline FKSSR
keyboard feet
« Reply #7 on: Mon, 06 April 2009, 12:31:10 »
Quote from: itlnstln;27229
The MK96 are actually flat.  That does make sense, though.  I'd never thought of even looking for that.
