Author Topic: Windows 7 not happy with ps2 input.  (Read 10726 times)
Offline lam47
« on: Sun, 05 April 2009, 09:04:21 »
I can not boot into windows 7 7068 with a ps2 keyboard plugged in.
I get this error message until I unplug it and re boot with a USB board.
Any keyboard plugged into the ps2 socket causes this error.
Its not fun at all :(
Keyboards. Happy Hacking pro 2 x2. One white one black. IBM model M US layout. SGI silicone Graphics with rubber dampened ALPS. IBM model F. ALPS apple board, I forget what it is. And some more I forget what I have.
Typewriters. Olivetti Valentine. Imperial Good Companion Model T. Olympia SM3
Offline lam47
« Reply #1 on: Sun, 05 April 2009, 09:26:10 »
Just booted with one of each plugged in and it seems OK so far WTF?
Offline lal
« Reply #2 on: Sun, 05 April 2009, 09:52:03 »
It's a beta.  I'd look for the canonical forum on microsoft.com.  Maybe the developers don't know about it yet and would be happy about a bug report?
BS: Customizer, Model Ms; Alps: CSK-2101, FK-2002, AT-101 (SGI & Dell), MCK-860, FKBN87Z/EB; Cherry: Poker X, FKBN87MC/EB, WY60, G80-3000, G84-4100, TDV 5010
Offline xsphat
  • Enlightened
    • Dan Newman, Writer
« Reply #3 on: Sun, 05 April 2009, 11:23:42 »
Good idea. You should let them know.
Offline lam47
« Reply #4 on: Sun, 05 April 2009, 12:12:08 »
I will I will.
Its an odd error.
Im surprised there is not more about it online.
Perhaps all the beta folk use USB.
Offline bhtooefr
    • bhtooefr.org
« Reply #5 on: Sun, 05 April 2009, 12:21:41 »
Could be a specific bug with your chipset, too. Or maybe even your specific motherboard.
Offline ch_123
« Reply #6 on: Sun, 05 April 2009, 12:28:37 »
I've had no problems with Win 7 and any of my keyboards. I'd say its either a problem with hardware, or Windows 7 has a problem with your hardware.
Offline lam47
« Reply #7 on: Sun, 05 April 2009, 12:30:06 »
Its very possible as the USB can be a bit odd on this mobo.
Its an Asus crosshair AMD board.
With my HH I have to press the keys loads of times after boot before it will input.
In any OS.
Offline xsphat
  • Enlightened
« Reply #8 on: Sun, 05 April 2009, 15:18:57 »
Quote from: lam47;27142
In any OS.
What is causing that? Is it some hardware incompatibility problem? As a Mac guy, since the company is so tight assed about it's products, I go to the store and buy stuff, bring it home and it just works with all my other Apple products. That is my favorite thing about Apple, and why I'll never switch.
Offline bhtooefr
    • bhtooefr.org
« Reply #9 on: Sun, 05 April 2009, 15:21:23 »
Could be buggy drivers, faulty hardware, etc., etc.
Offline lam47
« Reply #10 on: Sun, 05 April 2009, 17:52:34 »
Its the only keyboard that has ever done it.
The white one I had did it too.
My guess would be its the motherboard.
It can be a little odd some times.
I will swap it for a new socket soon anyway.
Offline ch_123
« Reply #11 on: Mon, 06 April 2009, 02:56:33 »
Which build of Windows 7 are you using?
Offline lam47
« Reply #12 on: Mon, 06 April 2009, 05:32:44 »
The latest one.
7068 64bit.
Offline wheel83
« Reply #13 on: Sat, 11 April 2009, 00:21:17 »
im running that one as well and i have no problems with my space saver directly plugged as ps2.
I <3 BS
Offline Eclairz
« Reply #14 on: Wed, 15 April 2009, 17:08:23 »
actually there is one sure way to find out get a ps2 keyboard which has complete n-key rollover and plug it in if the keyboard can't recognise over 7 keys it is probably your motherboard using a ps2 to usb adapter @_@
Lenovo ThinkPad TrackPoint Keyboard
RealForce 45g UK 88UB
FILCO Majestouch TenKeyPad
Offline lam47
« Reply #15 on: Wed, 15 April 2009, 17:35:19 »
I had a 48 key input from the marquardt :)
Offline Eclairz
« Reply #16 on: Wed, 15 April 2009, 17:52:55 »
Then its probably a windows 7 issue then or chipset compatibility. But you could say windows may stop supporting these ps2 devices altogether. Not that I care so much I never have more than 6 fingers depressing a keyboard at any one time. Just log the issue with microsoft and hope it gets sorted by release or maybe by sp1 at the latest.
edit : just saw you said you used sharp keys with windows 7 maybe this is an issue?
« Last Edit: Wed, 15 April 2009, 17:55:45 by Eclairz »
Offline cmr
« Reply #17 on: Mon, 20 April 2009, 14:56:35 »
i wonder why they didn't write the spec for 8 or 9 keys instead of 6... then they'd cover pretty much all practical rollover scenarios
« Last Edit: Mon, 20 April 2009, 15:40:40 by cmr »
