Author Topic: [WTB] Ergodox acrylic case  (Read 3023 times)
Offline komar007
  • Trade Count: (0)
    • komar's blog
« on: Mon, 31 March 2014, 12:37:56 »
I'm looking for a standard Ergodox layered acrylic case. Can be with wrist extension or without.
I've seen that mechanicalkeyboards.com have some with aluminium tops, but these are beyond my budget.
Offline Sniping
  • Trade Count: (0)
Re: [WTB] Ergodox acrylic case
« Reply #1 on: Tue, 01 April 2014, 01:38:26 »
Check out czarek's PVC case, good value.
Offline LaugeGregers
  • Trade Count: (0)
« Reply #2 on: Tue, 01 April 2014, 02:44:51 »
Depending on what your budget is, you can get a case laser cut.
I think it can be done for around 90 USD including material.
DXF files for the individual layers can be found here:
https://github.com/bishboria/ErgoDox
It can be a good idea to merge all of the layers into one file, as it will save a lot on the start up fees.
Some companies want svg files. Inkscape will work perfectly for this, just drag and drop, and turn of scaling.
Offline tbc
  • Trade Count: (0)
« Reply #3 on: Tue, 01 April 2014, 03:00:32 »
EDIT: nvm, got prices mixed up....or mk.com changed their prices -_-
Offline komar007
  • Trade Count: (0)
    • komar's blog
« Reply #4 on: Tue, 01 April 2014, 04:06:16 »
Thanks, I couldn't find these files.
Do you know the thickness of each layer?
Offline lcs
  • Lover of Grape Drank
  • Trade Count: (0)
  • はやく
« Reply #5 on: Tue, 01 April 2014, 04:27:21 »
3mm
5mm
5
5
3
Offline komar007
  • Trade Count: (0)
    • komar's blog
« Reply #6 on: Tue, 01 April 2014, 15:57:19 »
Thanks.
I've sent a quote request to the first company with a laser cutter I came across;)
  • Trade Count: (0)
« Reply #7 on: Thu, 03 April 2014, 08:41:41 »
3mm
5mm
5
5
3
According to this post:
http://adereth.github.io/blog/2014/02/12/building-an-ergodox/
It should be possible to fit it all into a case, where all of the layers are 3mm.
Offline komar007
  • Trade Count: (0)
    • komar's blog
« Reply #8 on: Fri, 04 April 2014, 10:41:37 »
Thanks for help, everybody. I'll be trying to have it cut out of as thin acrylic as possible and I'll see what I get;)
