Author Topic: [IC] GMK modifiers kit  (Read 51087 times)
Offline tinlong117
« on: Tue, 01 April 2014, 06:28:44 »
Got a quote for this set - they said it should be around €28 for 250 sets.
Suggestions?
« Last Edit: Tue, 01 April 2014, 20:33:16 by tinlong117 »
Re: GMK MOGGLE
« Reply #1 on: Tue, 01 April 2014, 06:29:22 »
What's a moggle?
Offline StylinGreymon
  • Keyboard Hipstar
Re: GMK MOGGLE
« Reply #2 on: Tue, 01 April 2014, 06:33:54 »
Isn't it a creature from Final Fantasy?
If today had been a hippo, then you'd really have to worry about tomorrow.
Re: GMK MOGGLE
« Reply #3 on: Tue, 01 April 2014, 06:35:11 »
59398-0
this is what google comes up with
Offline tinlong117
Re: GMK MOGGLE
« Reply #4 on: Tue, 01 April 2014, 06:43:46 »
Offline infiniti
  • I <3 KB
  • Bob was here
Re: GMK MOGGLE
« Reply #5 on: Tue, 01 April 2014, 06:58:16 »
What's a moggle?
Source: http://deskthority.net/wiki/Adapter_kit#Moogle_kit
Quote from: deskthority wiki
A moogle kit is an adapter kit that complements keys from vintage keyboard so that they fit onto a modern keyboard with 1.25 units wide modifier keys, such as Windows keys.
A typical moogle kit contains modifiers for the bottom row and a space bar. It is common for them to also contain a caps lock key with a centered stem (as opposed to off-center stem) and a 2.75 wide right shift key, even though not all users may need them.
The original moogle kits were designed to allow the use of Cherry doubleshot ABS keys (harvested off a cheap keyboard in the Cherry G80 series) on a modern Filco Majestouch. Moogle kits have also been made Dolch and Wyse PCE.
The term "moogle kit" is named after the Geekhack user who first proposed it: Moogle Stiltzkin. A "Moogle" is a type of creature that appear in several games by Square Enix, such as the Final Fantasy series.[1]
The term "moogle kit" (MOOGLEWHITE and MOOGLEBLACK) had been first introduced by 7bit as order-IDs for the Round 3 group buy in early 2011.
Re: GMK MOGGLE
« Reply #6 on: Tue, 01 April 2014, 07:00:24 »
What's a moggle?
I know what a moogle is but this thread is for a moggle :D
Offline bazh
Re: GMK MOGGLE
« Reply #7 on: Tue, 01 April 2014, 07:00:30 »
What's a moggle?
look at his avatar :v
HHKB Pro2 white
Newbie again
Offline infiniti
  • I <3 KB
  • Bob was here
Re: GMK MOGGLE
« Reply #8 on: Tue, 01 April 2014, 07:02:10 »
What's a moggle?
whoa...didn't notice that  :)) :))
Offline riotonthebay
  • Cherry Peasant
  • keycult.com
Re: GMK MOGGLE KIT
« Reply #9 on: Tue, 01 April 2014, 07:22:56 »
If you are including 1.5x mods and a 1.75x r-shift in the kit (it looks like it from the OP?) it would be great to include the 1x Fn and 2 1x blanks as well. Otherwise just get rid of that stuff for a cheaper kit.
Offline lightsout714
Re: GMK MOGGLE KIT
« Reply #10 on: Tue, 01 April 2014, 10:43:51 »
I am interested in this.
Offline boost
  • BOSTMOBILE
  • NY Giants!!!
Re: GMK MOGGLE KIT
« Reply #11 on: Tue, 01 April 2014, 10:46:35 »
I'm down
-Enzo Ferrari
Offline digi
  • elite af tbh
  • keyboard game on fleek
Re: GMK MOGGLE KIT
« Reply #12 on: Tue, 01 April 2014, 11:14:23 »
How much more to put the stepped-windowed caps lock back in? :)
« Last Edit: Tue, 01 April 2014, 11:36:43 by digi »
Re: GMK MOGGLE KIT
« Reply #13 on: Tue, 01 April 2014, 11:32:59 »
wtf, ISO enter but no ANSI? How much for all the keys shown, even the ones with red Xs through them?
Re: GMK MOGGLE KIT
« Reply #14 on: Tue, 01 April 2014, 11:38:56 »
Maybe that's why its called a moggle and not a moogle.
Offline digi
  • elite af tbh
Re: GMK MOGGLE KIT
« Reply #15 on: Tue, 01 April 2014, 11:39:57 »
lol, some new **** right der.
Re: GMK MOGGLE KIT
« Reply #16 on: Tue, 01 April 2014, 11:45:08 »
Is the enter something usually needing to be sourced? The one I got from a G81 was the right size.
Re: GMK MOGGLE KIT
« Reply #17 on: Tue, 01 April 2014, 11:46:12 »
Is this set going to be BoW?
Offline whiskytango
  • Don't touch the trim
Re: GMK MOGGLE KIT
« Reply #18 on: Tue, 01 April 2014, 11:49:44 »
enter key on used DS is usually the most shiny in my experience. Having a fresh one would be nice
it also needs space bars, 6.25 and 7x
Re: GMK MOGGLE KIT
« Reply #19 on: Tue, 01 April 2014, 12:08:01 »
Thats true did not consider used.
I was assuming WoB for some reason. Clarification would be good.
« Last Edit: Tue, 01 April 2014, 12:09:37 by lightsout714 »
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GMK MOGGLE KIT
« Reply #20 on: Tue, 01 April 2014, 13:02:43 »
I think the set as I had it... the unedited version of the above was something like 40€ or about $55 which also included spacebars. Some of those keys are probably not strictly necessary though.
I think windowed keys should be made since the don't really exist in black or at least are wholly impractical to find. Keeping the lower MOQ is easy with windowed key if you keep them in even numbers. Just do 2 legend style like the lock icon and the upside down shift arrow. This way each set could also potentially cover 2 keyboards like 1 winkey ANSI and 1 winkeyless ISO for example. I would also keep the Fn key and 2 1x1 row B blanks and add 6.25 and 7 spacebar.
Having a clear first shot instead of windowed keys would also be very cool. While I think they can do it technically I have asked them about it several times and never have gotten an answer on it.
« Last Edit: Tue, 01 April 2014, 13:04:52 by IvanIvanovich »
Re: GMK MOGGLE KIT
« Reply #21 on: Tue, 01 April 2014, 13:03:38 »
WoB or Dolch mod colors?  Hard to tell.  I might be interested, depending how it shapes up.
Offline LechnerDE
Re: [IC] GMK MOOGLE KIT
« Reply #22 on: Tue, 01 April 2014, 16:27:24 »
It's GMK, so yeah I am interested!
What color are we talking about by the way :p
Offline jufa
« Reply #23 on: Tue, 01 April 2014, 16:56:08 »
interested if the kit include windowed, 1.5x mods and a 1.75x r-shift, 7x spacebar
Offline fknraiden
« Reply #24 on: Tue, 01 April 2014, 17:17:26 »
Yes. I very much want this set. I'd even be down to put in a couple extra orders to meet moq.
Offline epzy
  • HHKB Fiend
  • ded
« Reply #25 on: Tue, 01 April 2014, 17:20:40 »
Meh, I wanted the MOGGLE kit not the Moogle kit, why tin, whyyyyyyy. :/
« Reply #26 on: Tue, 01 April 2014, 19:56:47 »
I think a mod did that.
Offline tinlong117
« Reply #27 on: Tue, 01 April 2014, 20:31:54 »
Damn.
Offline tinlong117
Re: [IC] GMK modifiers kit
« Reply #28 on: Tue, 01 April 2014, 20:34:28 »
I can do both BoW and WoB.
« Reply #29 on: Tue, 01 April 2014, 21:59:04 »
Just do a whole BoW set :thumb:
Offline bazh
« Reply #30 on: Tue, 01 April 2014, 23:21:30 »
can we do White on Blue :v
HHKB Pro2 white
Newbie again
Offline ideus
  • Björkö.
« Reply #31 on: Wed, 02 April 2014, 00:22:17 »
In for a WoB set. I suggest to add FN keys in 1u and 1.25u.
« Last Edit: Wed, 02 April 2014, 00:29:24 by ideus »
Offline tinlong117
« Reply #32 on: Wed, 02 April 2014, 00:39:06 »
VVHAT?
Offline bazh
« Reply #33 on: Wed, 02 April 2014, 00:52:12 »
for mix&match, maybe :v
HHKB Pro2 white
Newbie again
Offline berserkfan
« Reply #34 on: Wed, 02 April 2014, 01:44:05 »
I finally noticed that this post was made in the early hours of April 1.
Offline cphead
« Reply #35 on: Wed, 02 April 2014, 03:27:43 »
Hehehehehehehheheheh. That flawless mockup pic though
Offline Paranoid
« Reply #36 on: Wed, 02 April 2014, 14:32:23 »
interested in the exact set of the OP
Offline billnye
  • ability man
« Reply #37 on: Wed, 02 April 2014, 14:35:00 »
Very interested if it comes with ANSI enter!
« Last Edit: Wed, 02 April 2014, 14:37:36 by billnye29 »
Offline yicaoyimu
« Reply #38 on: Wed, 02 April 2014, 23:36:50 »
+1 for complete WoB/BoW set.
Offline Halvar
« Reply #39 on: Thu, 03 April 2014, 03:06:12 »
Really? What sense would that make? Whatever this is, it's definitely not (only) a Moogle kit.
I'm in for one or two of these of course.
« Last Edit: Thu, 03 April 2014, 03:08:09 by Halvar »
Offline quochung1989
  • Vintage Cherry Collector
  • Frenzy Classic.
« Reply #40 on: Thu, 03 April 2014, 08:11:32 »
Very interested in BoW because i have Vintage Cherry Double Shot BoW keycaps :)
Offline samwisekoi
  • MAWG since 1997
    • Tweet samwisekoi
« Reply #41 on: Thu, 03 April 2014, 08:39:09 »
This is going to take forever to sort out across all of the threads started on or around April Fool's Day.
Also, Interested in WoB 1.25 text mods plus 6.25 and 7.00 spacebars.
(And the Unicomp SSSK, announced on the 32nd hour of April 1st.  Eight hours late is on-time for Unicomp.)
 - Ron | samwisekoi
Offline Mooby
  • Funployee
« Reply #42 on: Thu, 03 April 2014, 09:46:30 »
Interested in a standard moogle adapterkit. If this set gets to big and expensive I'll wait for a better opportunity.
« Reply #43 on: Thu, 03 April 2014, 09:50:50 »
So what exactly is a standard moogle? Different group buys have included various different keycaps, depending on who runs them and for which set they are offering compatibility.
Offline ideus
  • Björkö.
« Reply #44 on: Thu, 03 April 2014, 09:52:56 »
It is very easy to see there is no such thing, like an standard moogle, but I think he/she is referring to the more common breed.
« Reply #45 on: Thu, 03 April 2014, 09:55:54 »
http://geekhack.org/index.php?topic=40501.0#post_NNN
« Reply #46 on: Thu, 03 April 2014, 10:00:32 »
That graphic is actually misleading. Moogle kits usually include variously Backspaces, Enters, Shifts, etc.
« Reply #47 on: Thu, 03 April 2014, 10:02:55 »
That's why there's a billion links before it saying read this first. Can you find me a proper picture of a Moogle and Tsangan then? I couldn't find one to put in that thread.
Offline esoomenona
  • Gnillort?
« Reply #48 on: Thu, 03 April 2014, 10:03:21 »
It would depend on what set we're building a moogle for, before we can determine what keys are necessary to complete the set. So until someone says the sets that we're building them for, this conversation is unnecessarily winded.
Offline whiskytango
« Reply #49 on: Thu, 03 April 2014, 10:05:16 »
I was thinking about this too. The whole point of a moogle is to adapt an older key set to use modern, widely available boards. Just throwing this out as an idea: I am wondering if it would have the best chance to meet MOQ if you strip it down to only the keys necessary to get a functional ANSI set. Think only the keys that you need to make a donor Cherry DS set work. Should include ANSI enter because some of the Cherry POS keyboards have DS keys but ISO style enter keys. Should also include shift keys because the Cherry 1800 has short right shift. And of course it should include a full touch caps lock because many Cherry used sets only come with stepped which most ANSI boards cannot handle. Then include a normal ANSI bottom row (1.25 mods and 6.25 spacebar).
I realize this does not meet everyone's needs (including my own), but it will be cheaper, maybe cheap enough to gain enough popular support to meet 250 MOQ without people having to buy four sets each. And hopefully it won't take 6 months to get up to 250 orders either. Let's face it, reaching MOQ has been an issue because of the expense of GMK sets. Maybe to get to MOQ the set will need to be cheaper and more mainstream is all I am suggesting. My $0.02
