Author Topic: Need help buying a 60% Keyboard  (Read 8109 times)
Offline esko997
  • Linux Lover
« on: Tue, 01 April 2014, 10:43:32 »
Hey GH,
I'm looking to get a new keyboard, specifically one thats good for traveling with/using in crowed places. I've been looking at the Poker II but I cant seem to find it in stock anywhere with the switch type I would like (MX Blacks). The other one I was looking at is the Tex Beetle, but I've never heard of it before, not sure if anyone has any experience with this board? Does anyone have any recommendations for 60% keyboards? I'm open to pretty much anything in terms of switches, but would like to hear GH's experience/recommendations. I'd rather not spend above $200, but if its really worth it I would be OK with springing for it.
Thanks in advanced! :D
Daily Drivers:  Unicomp Customizer (BS -- Linux Layout) | Vortex Race 3 (Clears)
Other Boards: CM Quickfire Stealth (Greens) | Poker II (Blues) | PLU-ML 87 (Ergo Clears)  | JD40 (Browns) | Leopold FC660C (Topre) | IBM Model M | ErgoDox (Clears) | Sentraq s60x DIY (Blacks) | Anne Pro 2 (Blues) | Cherry G80-11900 (Blacks) | Kira (99 Key) (Hako True)
Offline Linkbane
Re: Need help buying a 60% Keyboard
« Reply #1 on: Tue, 01 April 2014, 11:06:15 »
Get an HHKB, it's the only keyboard worth getting. Full size is for the proletariat scum and TKL is for hipsters who think that they're unique by having a smaller board. HHKB4lyfe.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
« Reply #2 on: Tue, 01 April 2014, 11:10:39 »
Mashby made this great list of 60% keyboards. I like the Poker 2 and Pure personally.
Offline mashby
  • What Up Shoney? (ツ)_/¯
    • Mashby
« Reply #3 on: Tue, 01 April 2014, 12:52:02 »
Thanks for the link CPTBadAss!  :thumb:
In my experience, one of the tipping points on if a 60% board is going to work for you comes down to a couple of issues:
1. Do you need cursor/arrow keys?
You can of course use the Fn key and then access cursor keys that way, but some people prefer dedicated keys. If you do, then you'd be looking at the Tex Beetle or Pure Pro.
2. How short can the right shift be?
Unfortunately, in order to add those keys, the right shift key gets quite a bit shorter and that can present a problem for some. I know it did for me. My first mechanical was the Race and I found the right shift to be way too short and I kept miss hitting the key and then deleting text that I was typing. It was maddening.
If you don't need dedicated arrow keys, then it's really not an issue, the Poker X (several in the classifieds) and the Poker II have a standard ANSI layout. The Pure adds one key, the "~" key to the right of the shift key, and I've found no issues typing on them.
The only issue with the Pure is that if you ever want to replace your key cap set, you'll have to find one with a Tsangan set to include the short right-shift key. Most group buys here have this set, but many commercial sets do not.
Other Options
Happy Hacking Keyboard (HHKB) - If you're willing to look outside of Cherry-MX, the HHKB is a really nice board. It has a much different layout, which is a deal breaker for some, but it also has a reputation of converting people over to the layout and making zealots out of them (as Linkbane can attest). They are expensive, but they are very well made. If you're looking to tweak out your board, there are fewer options. No metal cases and very not as many key caps sets.
Leopold FC660 - this is a little bigger than 60%, but is a nice compromise between having dedicated cursor keys in a standard ANSI layout. They come in Topre and Cherry-MX versions.
GH60 - this is a project board that you'll have to build yourself, or have someone build for you. We're a couple of months away from seeing the kits ship, so you might as well get a board for now.  :p However, once you've gotten your first 60%, if you find you like the form factor then I think this board will give you pretty much any Cherry-MX option you heart could dream of.
Hope that helps!
Offline esko997
  • Linux Lover
« Reply #4 on: Tue, 01 April 2014, 14:21:48 »
Other Options
Hope that helps!
Thanks a lot for the replies all, very helpful in terms of looking. I'm really torn still, but looking at the Choc Mini due to relatively low price. I also really like the Duck Viper that was posted not too long ago, would love to get in on building.
Offline Razor Lotus
« Reply #5 on: Tue, 01 April 2014, 14:26:35 »
poker 2 has my vote :)
Offline mashby
    • Mashby
« Reply #6 on: Tue, 01 April 2014, 18:37:00 »
Now you know why we call GeekHack, "WalletHack". Each of these boards is special in it's own way and I seem to have lost my ability to say no to any of them. I seem to have succumbed to the "Pokemon Effect" -- gotta collect them all!!!  :p
Offline esko997
  • Linux Lover
« Reply #7 on: Tue, 01 April 2014, 19:00:19 »
Tell me about it...I couldnt decide so I've decided to buy a Poker and a Choc Mini  :rolleyes:
I've got the K.A.S..
Offline blingcaps
« Reply #8 on: Tue, 01 April 2014, 19:15:25 »
it comes down to how much you want arrow keys and function keys.
poker 2 if you don't need them, and you want a standard layout so swapping out keycaps is much easier.
if you want arrow keys, then filco minila, tex beetle, or pure pro.
if you just want something smaller than TKL, then you can look at the leopold FC660, or some other boards like the keycool 84, choc mini, or race, which give you dedicated function and arrow keys.
Offline minho
  • i'm kind of back
« Reply #9 on: Wed, 02 April 2014, 00:25:34 »
I was under the impression that orders for this are closed? Is there a way to still participate in the group buy? (Please say no for the sake of my wallet).
Offline mashby
    • Mashby
« Reply #10 on: Wed, 02 April 2014, 09:39:45 »
Your wallet is safe... for now.  :p
Orders are getting close to shipping and there will be people selling their kits on the classifieds. So although you can't participate in the group buy now, you should be able to get one.
Offline sth
  • 2 girls 1 cuprubber
« Reply #11 on: Wed, 02 April 2014, 09:46:51 »
HHKB is a tool for the proletariat to dismantle the capitalist bourgeois means of production. you're just using it for evil.
Full size is a format standardized by IBM, about as far from the proletariat as you can get.
your trolling has been pretty wack lately
Offline Linkbane
« Reply #12 on: Wed, 02 April 2014, 09:50:52 »
Sometimes I forget the date, sometimes sth does also.
Offline RESPRiT
  • HHKB = ❤
« Reply #13 on: Wed, 02 April 2014, 11:03:41 »
The FC660M is my personal favorite, while I can live without arrow keys, I dislike the Poker layout and WASD arrow keys and much prefer the HHKB fn arrows.
Offline minho
  • i'm kind of back
« Reply #14 on: Wed, 02 April 2014, 17:30:09 »
Does the nonstandard layout ever bug you though?
Offline esko997
  • Linux Lover
« Reply #15 on: Thu, 03 April 2014, 22:46:56 »
Hey all,
My Choc Mini with MX Blacks came in the mail today -- totally loving it. The switches feel great for typing and gaming, definitely very pleased with the Chocs quality and feel.
Thanks again for all the input on 60%'s. Also, for others reading the thread, would definitely recommend the Choc Mini as a great keyboard for working/gaming on the go. Great size without sacraficing function keys and great build quality.
Some pics:
Offline ideus
  • Björkö.
« Reply #16 on: Fri, 04 April 2014, 00:06:50 »
Welcome to the club!  :thumb:
Offline mougrim
« Reply #17 on: Fri, 04 April 2014, 02:29:48 »
Got myself Poker II - because I can live without dedicated arrow keys perfectly, and wanted to have a keycaps swapping option (I'll stick with stock keycaps for now - as them don't have Cyrillic layout, I'll try to perfect my blind writing). Also, it's nice to have easily programmed keyboard. Especially if you're working in Linux. Well... it's OK for Windows too :)
IBM AT Model F, Vortexgear Race 3, AEKII (Alps Cream Damped), Metoo Zero (modded to Kailh Box Navy)
« Reply #18 on: Fri, 04 April 2014, 02:48:50 »
Pure limited or poker :)
Offline Linkbane
« Reply #19 on: Fri, 04 April 2014, 11:15:21 »
An excellent purchase, I remember that Noppoo were really popular when I first joined eight months ago. Things seem to have quieted down about them, but that doesn't make them any worse. Hope you can get some cool custom caps to put on.  :D
Offline tribade
« Reply #20 on: Sat, 05 April 2014, 01:56:32 »
Hey all,
Some pics:
Nice choice!  How do you like the format?  I've been loving the modded black I'm typing on right this very minute.  Lighter springs really makes them come alive.
KMAC mini w/ blacks | Realforce 87uw 55g w/ Digil0g case | KMAC w/ blacks | Duck Viper w/ clears
"Te occidere possunt sed te edere non possunt nefas est."
Offline Hypersphere
« Reply #21 on: Sat, 05 April 2014, 13:37:07 »
Having tried virtually every board made from full-size to 60% and a number in between, I have settled on my two all-time favorites, the IBM Model M SSK and the HHKB Pro 2. These are two very different boards, but each is excellent in its own way.
The HHKB Pro 2 layout is so good that I have recently remapped my IBM to the HHKB layout. This approximates my dream board, which will probably never be made -- a 60% with buckling springs and dye-sub PBT keycaps (like the IBM and HHKB Pro 2).
I've tried the Poker II with Cherry blues, but I didn't like the layout or feel.
Other small boards worthy of consideration are the Tek Beetle and the Filco Minila, which comes in a Bluetooth version. Each of these is very solid, but they have some quirks in their layouts that did not work for me -- each has a small right shift, and the Minila has non-standard staggering in the z-row.
Offline Quardah
    • DeliTech
« Reply #22 on: Sat, 05 April 2014, 14:48:52 »
To my good friend OP;
All i can say is that i am currently running a Poker II with browns and it is a very good choice price-wise. For an hundred dollars keyboard you really get a good quality build and a fully-programmable 60% board.
Of course the choice is yours but my final vote is a Poker II. I'm a sellout haha.
See my blog here : https://delitech.live
Poker II - Brown MX
Ducky One II TKL - Silver MX
TEX Shinobi - Clear MX
Offline mougrim
« Reply #23 on: Sat, 05 April 2014, 14:57:34 »
I second this. Good quality for reasonable money.
And even if you don't need programmable keyboard, it's better to have one - you don't know when you'll want to program crazy macro :)
Offline esko997
  • Linux Lover
« Reply #24 on: Sat, 05 April 2014, 19:01:36 »
Honestly, would really love one of these but I'm having a hard time finding on the internet -- waiting for one to show up in the classifieds!
Offline mougrim
« Reply #25 on: Sun, 06 April 2014, 00:36:21 »
« Last Edit: Sun, 06 April 2014, 00:39:11 by mougrim »
Offline mougrim
« Reply #26 on: Sun, 06 April 2014, 00:38:26 »
http://www.banggood.com/KBC-Poker-2-Mini-Mechanical-Gaming-Keyboard-Cherry-MX-Black-Switch-p-85373.html
Black Poker II with Crerry MX Black
Offline Quardah
    • DeliTech
« Reply #27 on: Sun, 06 April 2014, 11:44:17 »
^^^^^^^ This ^^^^^^^
I was about to post some other link but this guy is faster than speedy gonzales.
Don't forget to come back and tell us what you think of the Poker ii after buy.
Poker II - Brown MX
Offline mougrim
« Reply #28 on: Sun, 06 April 2014, 11:58:25 »
Second this :) But don't expect it to arrive earlier than 2 weeks after order. Because, China post. Of course, you can pay some extra for faster shipping, but...
Got my Poker II from this shop. Had to wait about three weeks, but it was totally worth it :)
Offline mr67volks
  • GAO!!!
    • the sweetie bot
« Reply #29 on: Mon, 07 April 2014, 16:39:08 »
I started with a KBT pure , but couldn't get used to the small right shift , got in on a massdrop for the poker 2 with blues and i am in love.
been using it as my daily and I still bust out my dell at101 for gaming , and since messing with the 60% boards I have started making my own 60% out a busted dell AT101. Getting a teensy to set it up and might program it close to how the poker2 is set up.
speaking of 60% boards ... anyone know if any one has made a 60% with the option of a 7bit layout?
even a PCB would do , I have no problem building it myself but I would really like to have it be a plate mount with a real PCB.
I know there is the phantom but its a 75% but I'm wanting a 60%
www.sweetiebot.org
Dell AT101w x3 Alps Black | AT101 / 61 Custom into a 60% MOD ( WIP ) | Poker ii MX Blues (My EVA 01) | KBT Pure MX blacks | MC QFR mx blues w/ Frosty Flake
Offline mougrim
« Reply #30 on: Mon, 07 April 2014, 17:16:07 »
I think you'll eventually have to build one yourself. As I didn't heard about any custom 60% keyboards allowing 7-bit layout.
Offline esko997
  • Linux Lover
« Reply #31 on: Mon, 07 April 2014, 18:00:20 »
Thanks for the link, just dropped on one with blues -- cant wait for it to get here.
Offline mougrim
« Reply #32 on: Mon, 07 April 2014, 18:06:50 »
Got myself white one with blues - totally enjoying it.
Offline MiBe
« Reply #33 on: Tue, 08 April 2014, 11:54:37 »
That's a downside of the Choc Mini, it doesn't have standard sized keycaps which makes it hard with custom keysets. For example the spacebar is different in size.
I used to have the Noppoo Choc Mini in the past but I recently sold it and bought a Keycool 84 instead. I like the last one alot better. Besides the fact that it's easier to customize keycaps, it also has a detachable USB-cable (great for transport) which the Choc Mini hasn't. I would recommend purchasing the white version because it comes with PBT keycaps, they feel and sound a little bit nicer than ABS and POM in my opinion. You can even get them with MX Clears.
IBM Model M 1391401 (Bucking Spring / PBT keycaps) || Dell AT101W (Black Alps / PBT keycaps || Filco Majestouch 2 (MX Brown / PBT keycaps) || Ducky Shine 3 (MX Blue / Magenta LED / PBT keycaps) || KBP V60 Mini (MX Green / Blue & Green LED / PBT keycaps) || Keycool 84 White (MX Black / PBT keycaps) || Razer BlackWidow Chroma Stealth (Razer Orange / RGB LED / ABS keycaps) || SteelSeries 6Gv2 (MX Red / ABS keycaps)
Offline mougrim
« Reply #34 on: Tue, 08 April 2014, 15:25:27 »
Yep. Firs I thought to get myself a Choc Mini, but... I was worried about customization - all those non-standard keys make it close to impossible. Also - I wanted detachable cable, because I wanted to carry it to my work (at home I have a BS keyboard, but it's not exactly portable :)
So... Standard keycaps, detachable cable and good quality - all those brought me to Poker II :)
