Author Topic: Cherry G80-3000 - Double spaces  (Read 2086 times)
Offline CX23882
« on: Tue, 07 April 2009, 03:52:21 »
Ever since getting this board I've noticed that I occasionally get a double space. None of the other keys do this.
Has anybody else seen this behaviour and any ideas as to what might be causing it?
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
« Reply #1 on: Tue, 07 April 2009, 06:33:12 »
Which key response do you have? Judging from the force displacement diagrams, clicky (blues) should do best in terms of bounce resistance, followed by soft (clear) and finally linear (black).
« Last Edit: Tue, 05 May 2009, 04:34:38 by keyb_gr »
Offline CX23882
« Reply #2 on: Tue, 07 April 2009, 06:49:51 »
It has the blues, but the space bar is green.
Offline itlnstln
« Reply #3 on: Tue, 07 April 2009, 06:56:56 »
You could always try swapping the guts of the switch with one of the others (like Pause/Break) to see if it helps.  There might be something loose in the switch that might be triggering the switch mulitple times.  I wonder if something is triggering it on the downstroke and the upstroke.
