Author Topic: Good keyboard for someone that spend all day in the computer  (Read 6336 times)
Offline xeon123
« on: Wed, 02 April 2014, 04:39:37 »
I spend all day in the programming, and I want to buy a keyboard that allows me to write fast and don't hurt my hand causing RSI.
I see lots of keyboards out there and they cost money, like the Logitech B810, das Keyboard , Poker II, Leopold, Wacky, etc.
My previous keyboard was a mechanical keyboard Razer BlackWidow, but it lasted 1 year. The mini USB socket broke.
What keyboard should I buy? Preferable, a durable keyboard.
Re: Good keyboard for someone that spend all day in the computer
« Reply #1 on: Wed, 02 April 2014, 04:48:14 »
Topre?
Variable weight (for the ergonomics) if you touch-type, uniform if not.
45g if you have average fingers, 55g if you have strong fingers.
« Reply #2 on: Wed, 02 April 2014, 05:07:25 »
It is not the first time I have heard the Razer BW failing at the cable outlet. Have you considered repairing it?
Offline xeon123
« Reply #3 on: Wed, 02 April 2014, 05:12:44 »
I tried to, but it is very difficult to solder a mini-USB to a printed circuit board. The money that I would spent in buying a soldering iron for a tiny chips, is the price of a new keyboard. I only have a soldering iron for normal sized components, and not for tiny ones.
Offline Belfong
« Reply #4 on: Wed, 02 April 2014, 05:22:53 »
Durable keyboard: I think Matias is durable. And it is also reasonably price. And the keyboard is available in many retails store so perhaps you can get people in those store to help you fix should this happened again.
Offline xeon123
« Reply #5 on: Wed, 02 April 2014, 08:40:27 »
I am thinking in buying the "das Keyboard" MX-blue. Is it a nice and durable keyboard?
Offline Linkbane
« Reply #6 on: Wed, 02 April 2014, 09:13:13 »
The Das is fine, but for its price a Filco or Ducky are much better options, the Ducky more so if you get one of the versions with their classic thick PBT caps. Matias is also nice, overall you should stick to low-force switches (Blues, Browns, Reds, Topre 45g, Matias?) to avoid RSI over a long period.
Quickfire TK MX Blue Corsair K60 MX Red Ducky Shine 3 Yellow TKL MX Blue Leopold FC660C
Current best: 162 wpm.
Offline ideus
  • Björkö.
« Reply #7 on: Wed, 02 April 2014, 09:18:54 »
Get any Leopold, I suggest you in particular the FC660, either M or C, the second if you are after Topre. But the first will allow you to use most MX sets available, but the spacebar. To say that keyboards are rock solid, is a common expresion around here, that may be a little worn off, however it is the way you can actually describe the Leopold FC660M.
« Reply #8 on: Wed, 02 April 2014, 09:21:41 »
Pretty much anything at Elitekeyboards is worth your money and time.  If you want pure durability, you can look into a classic buckling spring board, but they tire me out.
Offline RESPRiT
  • HHKB = ❤
« Reply #9 on: Wed, 02 April 2014, 09:41:48 »
Das is pretty expensive, although it's the most "professional" looking keyboard in my opinion. Like it's been said, though, you can get a nicer keyboard for the same cost. I'll give another +1 for Leopold, their stuff is super solid. Also, if you're willing to pay, Topre is fantastic, I love the layout of my HHKB, it makes typing awesome :thumb:
Offline Linkbane
« Reply #10 on: Wed, 02 April 2014, 09:49:26 »
Don't know if the Das 4 could be considered professional, especially considering Cherry boards. :p
Offline ideus
  • Björkö.
« Reply #11 on: Wed, 02 April 2014, 09:52:35 »
Well, the problem is semantics for professional, that may be a differente thing if you consider it should be applied to people, not to things.  :p
Offline xeon123
« Reply #12 on: Wed, 02 April 2014, 09:59:56 »
the Leopold 66key Tactile Click "Mini" Keyboard is a nice one?
Offline RESPRiT
  • HHKB = ❤
« Reply #13 on: Wed, 02 April 2014, 10:00:46 »
Very solid board, very nice layout, and if you like compact boards, also very nice :)
Offline ideus
  • Björkö.
« Reply #14 on: Wed, 02 April 2014, 10:00:53 »
There is a review somewhere. Let me check and post the link. I found it here.
Offline Mooby
  • Funployee
« Reply #15 on: Wed, 02 April 2014, 10:37:17 »
Or you could buy a cheap QFR Rapid, which is not bad at all in the quality department and replace it with another cheap QFR Rapid if something should break outside of warranty.
Offline Linkbane
« Reply #16 on: Wed, 02 April 2014, 10:43:49 »
My favorite layout and favorite MX switch. An excellent choice, if I do say so myself.
Offline xeon123
« Reply #17 on: Wed, 02 April 2014, 10:46:18 »
Is it possible to buy a elitekeyboard in Europe, or do I need to pay the ship taxes from buying in US?
« Last Edit: Wed, 02 April 2014, 10:49:21 by xeon123 »
Offline RESPRiT
  • HHKB = ❤
« Reply #18 on: Wed, 02 April 2014, 10:50:54 »
Is it possible to buy a elitekeyboard in Europe, or do I need to pay the ship taxes?
I would try qtan's store, EK's shipping costs outside of CONUS are rather prohibitive. Alternatively, people sell them on the classifieds every once and a while. Qtan's store is here: http://www.vendio.com/stores/E-sports-Gaming-equipments/
Offline ime1729
« Reply #19 on: Wed, 02 April 2014, 10:51:40 »
If you play the piano or a stringed instrument, you probably have stronger fingers than some of us, and I would recommend you trying the stiffer springs first. (Blacks, greys, greens, BS)
Offline Linkbane
« Reply #20 on: Wed, 02 April 2014, 10:54:41 »
Stiff springs aren't better. And despite fencing daily and typing frequently, I type more slowly on heavier springs and they feel significantly worse.
Offline RESPRiT
  • HHKB = ❤
« Reply #21 on: Wed, 02 April 2014, 10:59:31 »
I've played the piano for 7 years and heavy switches are still too tiring for me :P
Offline Parak
« Reply #22 on: Wed, 02 April 2014, 11:02:26 »
Meh. I have weak fingers and can't stand using anything but model Fs at home and work, so I'd say a good 12+ hours a day in front of a keyboard. They are slightly lighter than Ms, however. YMMV.
Offline SonOfSonOfSpock
« Reply #23 on: Thu, 03 April 2014, 00:27:47 »
It might be worth your time to consider a split board if you are worried about RSI or ergonomics.
« Reply #24 on: Thu, 03 April 2014, 00:32:12 »
I seem to recall that piano keys are not that heavy (it's been a good few years since I last played).
Anyone know what the actuation force of piano keys is?
Did I really ask that?
Offline Linkbane
« Reply #25 on: Thu, 03 April 2014, 00:46:44 »
When people say 'press' and you immediately think of actuation force, you know you're a real geekhacker. It's already happened to me!
« Reply #26 on: Fri, 11 April 2014, 10:33:14 »
Piano keys don't have much resistance but they have a lot of inertia.  It isn't an apples to apples comparison
Offline ynrozturk
« Reply #27 on: Fri, 11 April 2014, 10:58:23 »
Get a Filco with MX Browns. Never look back.
IBM Model F | IMB Model M | Poker II MX Brown | Poker II MX Clear | Filco TKL MX Brown | Bastardized Razer Blackwidow TE MX Blue | Logitech G602 |  Cyborg R.A.T. 7 | | Logitech MX518 | Icemat  | Artisan Hien
Offline QuadGMoto
« Reply #28 on: Fri, 11 April 2014, 11:08:42 »
I just checked the fairly decent piano in our living room. It needs about 75 grams just to push the key down. Obviously you need more to actually play a sound, nevermind playing fortissimo.
Offline sth
  • 2 girls 1 cuprubber
« Reply #29 on: Fri, 11 April 2014, 11:10:11 »
i like topre a lot so i would recommend full-size realforce, if you're just looking for a keyboard and don't plan on switching keycaps or modding things. it sounds like you're used to fullsize already but if you dont want the numpad, the 87 key is there too. it's like buying the cadillac of keyboards - big, comfy, classic and distinguished, and it will last for a dang long time without looking or feeling worn.  the hi-pro version is interesting too but i haven't used one for long.
the price tag is up there with caddies too, so you could also go filco or leopold. both make great, professional-looking boards as well but my fingers seem to like topre's rubber more than springs for extended use.
« Last Edit: Fri, 11 April 2014, 11:12:17 by sth »
Offline Linkbane
« Reply #30 on: Fri, 11 April 2014, 11:46:51 »
Only thing about the high profile is that according to reviews I've seen and the company themselves, is that they don't recommend it for typing because the spherical shaping makes it require a large movement comparatively to others.
« Reply #31 on: Fri, 11 April 2014, 12:08:33 »
Why would a company that makes a keyboard not recommend typing on said keyboard?
Offline Linkbane
« Reply #32 on: Fri, 11 April 2014, 12:28:32 »
Nice rhetoric, but it's apparently supposed to be for data entry/aesthetics rather than function.
Offline hoggy
  • * Ergonomics Moderator
« Reply #33 on: Fri, 11 April 2014, 13:27:23 »
If you are in Europe, then check out www.keyboardco.uk
Offline lunr
« Reply #34 on: Fri, 11 April 2014, 14:10:01 »
Filco, Ducky, Topre, or Leopold are equally solid and great keyboards. I love Topre now ever since I was introduced but you should do more research on Topre switches since they are not for everyone.
« Reply #35 on: Fri, 11 April 2014, 14:16:44 »
Equally?  I dunno.  I'd probably put the order as Leopold > Filco > Ducky, with Topre boards over on a different scale.
