Author Topic: NIB Model M 1991 White Label  (Read 5941 times)
Offline MANISH7
« on: Tue, 07 April 2009, 15:30:29 »
This is part #1394540. It is white label and without drainage holes. This is identical to the common 1391401 but has two speakers.
http://cgi.ebay.com/IBM-Model-M-Clicky-Keyboard-Part-1394540-NEW_W0QQitemZ310132850333QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item310132850333&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
The above sold for $27. If I hadn't butted in with a $26 bid, the buyer would have gotten it for $22. I feel bad about wasting a couple of his bucks. I just bid for the heck it, in case of dumb luck I did get it for $26.
http://cgi.ebay.com/IBM-Model-M-Clicky-Keyboard-Part-1394540-NEW_W0QQitemZ250402561136QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item250402561136&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Here are blue label 1391401 made by IBM. Just as good IMO.
One hour to go (04/08)  - UPDATE SOLD for $37.
http://cgi.ebay.com/IBM-1391401-Model-M-Clicky-Keyboard-1392090-NEW_W0QQitemZ310132719728QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item310132719728&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
(2 days to go)
http://cgi.ebay.com/IBM-1391401-Model-M-Clicky-Keyboard-1392090-NEW_W0QQitemZ310133998297QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item310133998297&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
(9 days to go)
http://cgi.ebay.com/IBM-1391401-Model-M-Clicky-Keyboard-1392090-NEW_W0QQitemZ250398892131QQcmdZViewItemQQptZPCA_Mice_Trackballs?hash=item250398892131&_trksid=p3286.c0.m14&_trkparms=72%3A1205|66%3A2|65%3A12|39%3A1|240%3A1318|301%3A1|293%3A1|294%3A50
Offline MANISH7
NIB Model M 1991 White Label for cheap
« Reply #1 on: Tue, 07 April 2009, 15:32:08 »
When they say NIB, they mean NIB. The keyboard is sealed to the foam with original tape. All of these keyboards come without cables (so just order one from Unicomp).
Offline FKSSR
« Reply #2 on: Tue, 07 April 2009, 16:02:14 »
Thanks for posting.  I may keep my eye on them, but I'd rather have a black Unicomp, at this point.
Add me on Steam | Twitter
Offline MANISH7
« Reply #3 on: Tue, 07 April 2009, 19:49:31 »
Cool! I paid $50 and was ecstatic :) These guys are awesome. How long ago did you get yours? I just got mine this week.
Offline rdjack21
« Reply #4 on: Tue, 07 April 2009, 21:15:27 »
I've been keeping eye on those trying to decide if I want one or not. According to http://en.wikipedia.org/wiki/Model_M_Keyboard the 1394540 was "Made for IBM RS/6000 computer. Contains real speaker". So it may work but I don't know.
Keyboards
Topre Capacitive: Realforce 87U, Realforce 86U, HHKB Pro 2, Topre MD01B0, Topre HE0100, Sun Short Type, OEM NEO CS (x2), NISSHO Electronics KB106DE
Buckling Spring: IBM Model M Space Saver (1291472), Unicomp Customizer x 2
Cherry Brown: Filco FKBN87M/EB, Compaq MX11800
Black Alps: ABS M1
Not so great boards Rare Spring over dome OKI, Sun rack keyboard
Trackballs - Trackman Wheel (3), Trackman marble (2)
Keyboards I still want to get - Happy Hacking Keyboard Pro 2 the White version, Realforce 23U number pad in black and maybe white, μTRON ergo board with Topre switches.
Previously owned - [size=0]SiiG MiniTouch (White Alps), Scorpius M10 (Blue Cherry), IBM Model M13[/size]
Offline rdjack21
« Reply #5 on: Tue, 07 April 2009, 23:34:46 »
Quote from: ripster;27577
The "real speaker" thing makes me suspicious.  I thought IBM used an older mold for the cases but never put a speaker in the keyboards for PCs.
On the other hand the cable connector is a SDR connector so it MIGHT be for a PC.
Someone should ask this seller if it works with PCs.  He obviously knows and should be mentioning it if it doesn't.
- Ripster
I didn't ask the seller but I did find this about the IBM RS/6000 keyboards http://www.tifaq.org/keyboards/accessories-interfaces.html#pc-rios which states that the board will not work in a normal PC without a converter and then also some extra software. So maybe it would be a good parts board.
Keyboards
Black Alps: ABS M1
Offline Hak Foo
  • Make America Clicky Again!
« Reply #6 on: Wed, 08 April 2009, 01:18:01 »
Quote from: rdjack21;27580
It sounds like (but don't take this as gospel) they're talking about the other way:  the guy has some AT-style ergo keyboard he was trying to plug into the RS/6000; he had to adapt it down to a PS/2 style plug, and then run some program on the RS/6000 to make it work.  But it actually sounds like he was hot-swapping the keyboard too, which is (apparently) not broadly supported for PS/2 interfaces.
The issue is does it work the other way.
Overton130, Box Pale Blues.
Offline MANISH7
« Reply #7 on: Wed, 08 April 2009, 12:02:45 »
I just want to mention that the blue label 1391401s made by IBM are really awesome too. It is just as heavy and solid and well constructed as the white label. I actually like the blue color too. If you can get a blue label 1391401 for less than $60  I'd call it a good deal and certainly a fair one (these things were originally priced in 1990 at $100 IIRC). I don't think its quality is any lesser than the white label. I wouldn't say the same for the other Lexmark made models.
Offline FKSSR
« Reply #8 on: Wed, 08 April 2009, 13:31:40 »
hahahha.  Sweet!  That just lends more credibility to my belief that there has to be at least one reference to the Model M in the "Good Book." :P
Offline dw_junon
    • http://www.9999hp.net/
« Reply #9 on: Wed, 08 April 2009, 18:23:15 »
I'm wondering what a "fake speaker" is.
The speaker in the P/N 1394540 functions as the system speaker for earlier RS/6000 computers, which makes sense if you think of having a remote console away from the system itself (and system beeps actually being useful).
As far as I was able to find out a speaker was never offered with PC products, though could well have been intended.  A suggestion that it was implemented in a "MF-I" [Multi Function 1] keyboard, which I have seen repeated, was retracted by its author.
The speaker is controlled by the two extra lines that are usually redundant on a PS/2 6 pin mini-DIN, so if you were using a 1394540 with a RS6K product you would need a six conductor cable.  For a PS/2 application, you won't be able to do anything with speaker, but I always wondered whether it would complain if you didn't have the six conductor cable.
Anyway, it's a good example of how functionally similar IBM keyboards were between product lines, in this case to the point that they can be swapped!  Only one way, mind...
ARC/Chicony KB-5181 XT/AT blue ALPS? 101 US FCC ID E8H51KKB-5181 • AST ASTKB102 AT capacitive rubber dome 102 UK ISO
Cherry G80-2100 AT black Cherry 126 key German ISO unique • Compaq Enhanced III PS/2 unknown rubber dome 102 UK ISO
Datacomp DFK102ARA03 AT 102 blue ALPS? US/Arabic FCC ID blank, S/N 37880001 • Dell AT102W PS/2 Black ALPS 105 UK ISO x2
Fujitsu KFB4725-102 AT membrane rubber dome with spring 105 UK ISO • Hewlett Packard C1405A AT rubber dome 102 UK ISO
IBM 0989705 XT/AT no LEDs Model M 102 US/Arabic  • IBM 1388076 Industrial AT Model M 102 UK ISO
IBM 1389260 3179/3180 Display Station Model M 122 US 3270 x2 • IBM 1391406 PS/2 Model M 102 UK ISO x2
IBM 1397003 PS/2 Model M "Host Connect" emulator 122 German ISO • IBM 71G4643 PS/2 Model M Quiet Touch "Ouch!    Rubber spring" 102 UK ISO x2
IBM 5640987 3178 Display Station Model C2 capacitive buckling spring 87 key US 3270 • IBM 556-712-01 RT PC rubber dome [same as 2nd PCjr kbd?] 101 US
IBM 6450225 PC/AT capacitive buckling spring 84 key UK PC/AT • Lexmark 8125460 Model M2 102 UK ISO
NMB RT-102 117456-002 AT Hi-Tek black, clicky 102 UK ISO • Olivetti ANK 2462 M24 Personal Computer keyboard 2 clicky Olivetti spring module 102 UK unique
Ortek MCK-142Pro AT white ALPS 142 key UK • Sun 540-1006-03 Type unknown linear(?) keyswitch 2 87 key SunType2
Wang 724 725-3771-UK salmon ALPS 110 key UK Wang724 • Making this list hasn\'t half scared me...
[/I]
Offline lowpoly
« Reply #10 on: Thu, 09 April 2009, 03:39:49 »
Quote from: MANISH7;27516
This is just how ebay works. The 2nd highest bidder defines the value.
