Author Topic: Mechanical Key Sampler  (Read 2536 times)
Offline GiraffePencils
Re: Mechanical Key Sampler
« Reply #1 on: Thu, 03 April 2014, 10:13:42 »
yes....they do....
is this a question, statement or a self promotion?
« Reply #2 on: Thu, 03 April 2014, 10:16:21 »
So you just registered to post those?
Offline esoomenona
  • Gnillort?
« Reply #3 on: Thu, 03 April 2014, 10:18:12 »
Is there a problem with that?
If your suggestion is that he registered to post his own auctions, perhaps you should look at the auctions themselves, being they're from two different people, which would seem to negate that.
Also, a little less passive agressiveness, and more assertiveness in your suggestions.
« Reply #4 on: Thu, 03 April 2014, 10:22:33 »
Well it isn't everyday someone posts ebay links within 5 minutes of registering and then leaves. I'd much prefer people stick around and be involved.
« Reply #5 on: Thu, 03 April 2014, 10:35:39 »
It is okay now though. With the new ebay link forum and all. No need to follow the 2 month rule
Offline Anarchist
« Reply #6 on: Thu, 03 April 2014, 11:01:24 »
I've found keysamples to be pretty unreliable.  I ordered keysamplers and when I finally got them the cherry mx browns felt much stiffer and clickier even without bottoming out. I actually like the feeling a lot but it was a bit of a surprise.
Offline hashbaz
  • Grand Ancient One
  • * Moderator Emeritus
« Reply #7 on: Thu, 03 April 2014, 12:20:34 »
For the record RichardM333, can you clarify whether either of these are your own auctions?
Offline admiralvorian
  • DIY
« Reply #8 on: Thu, 03 April 2014, 13:20:00 »
Darude Status:
☐ Not Sandstorm
☑ Sandstorm                                               wts wtt wtb
