Author Topic: 3D printed Key cap (cherry MX)  (Read 6678 times)
Offline franklima260
« on: Thu, 03 April 2014, 20:52:26 »
Hey guys and gals,
I am new to mechanical keyboards but have been into 3D printing for a while now. So I thought hey... let make some key caps.
So to go over the design concept I wanted to combine the spherical key cap bowl with wide finger pad of chicklet style keys. Pictures bellow.
I still need to work out a few details mostly dealing with the stem and the depth of the bowl for quality printing on FDM printers (RepRap and Makerbot).
I have attached the STL and STEP if you want to play with the files yourself.
https://dl.dropboxusercontent.com/u/3207174/Key2b.zip
Let me know what you think, Frank
« Last Edit: Thu, 03 April 2014, 21:01:18 by franklima260 »
|Cooler Master QuickFire TK (CMTK) Blue | Adesso Compact Mechanical Keyboard (ACMK)
Offline 82times
Re: 3D printed Key cap (cherry MX)
« Reply #1 on: Thu, 03 April 2014, 21:17:34 »
Looks like a great way of experimenting with different profiles.
I'm curious about what you'd estimate the materials cost to be for, say, a single keycap.
...this could be a good excuse to finally buy a 3D printer...
Offline badman5
« Reply #2 on: Thu, 03 April 2014, 21:31:16 »
YES. Keep experimenting and hit me up once yuo have some nice slim caps, when i get my mechanical keyboard i will probably buy a full keyboard worth of caps.I want slim mechanical kb. This seems like the best solution so far.
« Reply #3 on: Thu, 03 April 2014, 21:41:28 »
Cost per key works out to about:
 $6.25 each but...
the break down is $0.32 for materials and  $5.93 for machine time. If you are not planing on selling the key caps or don't care about selling sustainably you can ignore the machine time cost. So.....
$6.25 each or $0.32 you pick.
Frank
Ps. I have access to a bunch of printers 2 are mine and 2 more at my local maker space so I can more or less get away with 'at cost' if I ever get the design worked out.
Offline Vibex
  • Love y'all
« Reply #4 on: Thu, 03 April 2014, 21:43:44 »
If you get some proto types you are happy with, let me know. I like testing things and playing with designs.
Offline SSIPAK
  • ★ Bootlegcaps ★
« Reply #5 on: Thu, 03 April 2014, 21:46:11 »
Is it possible for you make Topre keycaps? Im sure plenty of people would be interested.
« Reply #6 on: Sun, 06 April 2014, 04:28:23 »
Hey guys and gals,
New designs (from left to right):
The original design with an improved stem design.
2mm deep dome (I think this would do well for the 'F' and 'J' keys)
1mm deep dome I think this is the best feeling key.
Attached are all three key types in "STL" and "Step" formats:
https://dl.dropboxusercontent.com/u/3207174/Key1-2-3.zip
To print just make sure they are properly oriented, no support  is required as all the keys have support already model in. I have found that printing with a raft helps but is not required.
« Last Edit: Sun, 06 April 2014, 04:40:25 by franklima260 »
