Author Topic: Ascii->ps/2/usb  (Read 2385 times)
Offline huha
Ascii->ps/2/usb
« on: Thu, 09 April 2009, 07:02:00 »
Hi,
I've got an old keyboard here which spits out ASCII on 7 lines. There are quite a few projects enabling to adapt PS/2 keyboards to spit out ASCII, but I have found none that does it the other way round, i.e. converting an ASCII keyboard to PS/2 or even USB.
Are there any cost-effective solutions available or will I have to build my own?
-huha
Unicomp Endurapro 105 (blank keycaps, BS) // Cherry G80-3000LSCDE-2 (blues, modded to green MX) // Cherry G80-3000LAMDE-0 (blacks, 2x) // Cherry G80-11900LTMDE-0 (blacks, 2x) // Compaq G80-11801 (browns) // Epson Q203A (Fujitsu Peerless) // IBM Model M2 (BS) // Boscom AS400 Terminal Emulator (OEM\'d Unicomp, BS, 2x) // Dell AT102DW (black Alps) // Mechanical Touch (chinese BS) Acer 6312-KW (Acer mechanics on membrane) // Cherry G84-4100 (ML) // Cherry G80-1000HAD (NKRO, blacks)
Offline keyb_gr
  • Cherrified user
    • My keyboard page (German)
Ascii->ps/2/usb
« Reply #1 on: Thu, 16 April 2009, 15:36:21 »
The one problem I see with such a conversion is that you have to make assumptions about the host PC's keyboard layout when generating scancodes. Of course scancode --> ASCII converters have the same problem at the keyboard side. In any case some kind of configurability would be required, and that usually doesn't aid cheap mass-production...
In any case, judging from the enormous number of responses, I fear you'll have to tackle this for yourself... :(
Offline annoyedatKVM
Easy input by RADOVAN ROBOTICS
« Reply #2 on: Thu, 16 April 2009, 18:39:30 »
