Author Topic: numpad not working properly!!!!! need help!!  (Read 1525 times)
Offline Chemoletter
« on: Mon, 07 April 2014, 09:15:26 »
hi guys and gals,
i have a question about my cmstorm quickfire tk. when numlock is turned on you'd expect all numkeys to work but my "4" and "8" aren't. i checked if the switches work at all by turning numlock off. they work fine. what am i missing? ( layout is ISO german ) i have NO clue!!!
thanks for your time!
Re: numpad not working properly!!!!! need help!!
« Reply #1 on: Mon, 07 April 2014, 09:19:11 »
IIRC, the num-lock is toggled on, it works like numbers. If it's toggled off, it goes to the function layer. So 4 becomes Delete and 8 becomes Home.
Offline Chemoletter
« Reply #2 on: Tue, 08 April 2014, 01:16:27 »
hi,
yes, delete works just fine and page up, down, home and end as well. just tested to be safe that the switches work at all. but the moment i turn numlock on to have numbers, 4 and 8 won't work. mysterious and i have no idea why. have you got any further thoughts?
