Author Topic: SIP Socket Mods  (Read 3835 times)
Offline skcheng
    • Tenafly Dentistry
SIP Socket Mods
« on: Tue, 08 April 2014, 09:12:49 »
I know there's another SIP thread here, but hopefully this will add to that thread helping some people out with fitment.
So, if you looked at the other thread, you'll see that MX switch top isn't fully snapped together.   That's because of the small fin/bar which needs to fit between the SIP and the bottom housing:
Without altering the housing or the switch top, it's impossible get the pieces back together and the fit looks like this.    This is a problem since the tops are not fully closed, the LEDs aren't fully seated and the tops can pop off since the LED side clips aren't fully engaged:
I know some have simply removed the housings entirely, place the little wobbly metal pins inside the lower housing and used the LEDs to align everything.   I don't really like that solution since it's difficult to get everything straight and then everything is held together by two small dabs of solder.   So I figured I'd search for a more elegant solution.
So at first, I tried shaving down the little bar between the two tabs and that works, but then I'm altering the switch and the fit isn't as secure.   So then I figured I just needed to remove the housing along one side of the pins like this:
This allows the top to fully close while leaving everything very secure and straight:
Now everything is aligned properly, nothing loose and soldering should be a breeze.   The hardest thing is polishing everything after trimming the housings since the plastic is incredibly cheap and just splinters when you start shaving it.
And BTW, I'm not sure if you can tell from my photos, but the Clear MX tops really aren't as nicely cast as the stock Cherry MX tops.   Shapes are inconsistent and I can see why some have issues with fit ..... especially with Clear switches.   Probably not a significant issue for most switches, but noticeable under magnification.   Maybe it's the material used??   Not sure??
Anyway, hope this helps anyone who is looking to add some LED color swap capability.    I know I like these   :thumb: :thumb: ;D ;D
Offline AGmurdercore
Re: SIP Socket Mods
« Reply #1 on: Tue, 08 April 2014, 09:44:08 »
What are you using to remove the top plastic part and how much time does it take you for a whole board?
What the hell am I even doing
Offline skcheng
    • Tenafly Dentistry
Re: SIP Socket Mods
« Reply #2 on: Tue, 08 April 2014, 09:48:14 »
I use a dental handpiece and some F and XF dental drill bits.    Could be done on my lab handpiece or a dremel, but it's just much faster with a highspeed handpiece cutting at 200,000 rpm.    And then I use a bunch of Bronson polishing wheels on a low speed to polish the plastic.
It's kind of a pain ...... takes a few minutes for each socket.    I think it took me 30 minutes or so the last batch I did for my KMAC 2 ..... but that was only 25 of them.
Re: SIP Socket Mods
« Reply #3 on: Tue, 08 April 2014, 20:17:17 »
I just take mine to 400 grit sandpaper and then trim the sides with snips.  It takes maybe two minutes to do a full strips worth of them and they fit into the switch perfectly.
Offline Pacifist
  • on hiatus
Re: SIP Socket Mods
« Reply #4 on: Tue, 08 April 2014, 21:16:49 »
anychance you can make me some? Tried doing something similar but always ended up screwing it up
Offline Paranoid
Re: SIP Socket Mods
« Reply #5 on: Wed, 09 April 2014, 02:17:42 »
Nice investigation! Looks like a clean result. Seems like it does take up a lot of time for each thing. But so does everything else when modding a keyboard ^^
Offline tbc
Re: SIP Socket Mods
« Reply #6 on: Wed, 09 April 2014, 03:49:13 »
how hard to make a 3d printed gb for these?  as in, are there technical reasons why it's not possible to 3d print them.
