Author Topic: Hi from Norway  (Read 2124 times)
Offline andersdosen
Hi from Norway
« on: Wed, 09 April 2014, 13:11:52 »
Hi, guys! :) I just registered to ask for help with my Happy Hacking Keyboard Professional 2. I bought it a few years back, but it got lost in storage after moving a couple of times. I came here to see if anyone could help me locate the less-than/greater-than button on this thing, as it's been bugging me not finding it. I'm using the mac layout. I'm a web developer, so the button really comes in handy. I accidentally found it writing my other post, though, so no help is needed at the minute, but this forum looks like a place with a lot of knowledge about these darn keyboard. It's an absolute blast typing on this thing, and now I can't wait to use it in my web development.
Well, nice to meet you all! :thumb:
Offline epzy
  • HHKB Fiend
  • ded
Re: Hi from Norway
« Reply #1 on: Wed, 09 April 2014, 13:23:00 »
Hey. Hvis du bruker Norsk layout i Windows, eller Mac da, så må du bytte til Amerikansk også trykke Shift + punktum og komma. Det er den eneste måten jeg vet om iallefall. :)
Offline andersdosen
Re: Hi from Norway
« Reply #2 on: Wed, 09 April 2014, 13:40:00 »
Hei, du! På norsk layout er det knappen helt øverst til høyre. I allefall for min del. :)
Offline epzy
  • HHKB Fiend
  • ded
Re: Hi from Norway
« Reply #3 on: Wed, 09 April 2014, 13:46:37 »
Ah, annerlednes for Mac da tipper jeg. :) Min øverst til høyre er: | og med shift: §. :P Bra du fant ut av det. :)
Offline andersdosen
Re: Hi from Norway
« Reply #4 on: Wed, 09 April 2014, 13:59:37 »
Ah! Ja, er nok et par forskjeller, sikkert :) Takk uansett, får bruk for tipset ditt hvis jeg plutselig skulle befinne meg i Microsoft-miljø :thumb:
Offline blackbox
Re: Hi from Norway
« Reply #5 on: Wed, 09 April 2014, 14:01:29 »
Velkommen! Tror du det er mulighet for å prøve den? Har veldig lyst til å prøve den.
The LAN table!
Offline andersdosen
Re: Hi from Norway
« Reply #6 on: Wed, 09 April 2014, 14:25:25 »
Takk for det!
Hvor hen i dette langstrakte land kommer du fra? Hvis jeg er på din kant av landet en gang, så må jo det la seg gjøre.
Offline blackbox
Re: Hi from Norway
« Reply #7 on: Wed, 09 April 2014, 14:27:39 »
PMed
The LAN table!
