Author Topic: SSKs  (Read 3130 times)
Offline Pacifist
  • on hiatus
Offline Techno Trousers
  • ʘ_ಠ
Re: SSKs
« Reply #1 on: Wed, 09 April 2014, 17:43:37 »
Not a bad price if you'll never need to use the pause/break key, or have the patience to fix it.
Re: SSKs
« Reply #2 on: Wed, 09 April 2014, 19:03:30 »
it'd be a very easy fix. If anyone here gets it, I'll mail them a spring if they want.
Re: SSKs
« Reply #3 on: Wed, 09 April 2014, 19:38:20 »
Damnit one turns up in my price range (and probable within my technical capabilities to fix) during a month where I have much higher than normal expenses, and the Granite set to try to buy too :(
AND a CC 420 sale.
AND a BroBot 420 sale.
Oh fate, why are you so cruel?
Edit: Also the seller only has 1 feedback.
« Last Edit: Wed, 09 April 2014, 19:50:29 by rowdy »
Online fohat.digs
Re: SSKs
« Reply #4 on: Wed, 09 April 2014, 19:56:50 »
This can be a source of bargains, not necessarily a red flag.
- D Trump 2026-10-24
Offline Grr8
  • Quack!
Re: SSKs
« Reply #5 on: Thu, 10 April 2014, 14:58:50 »
http://www.ebay.com/itm/IBM-Model-M-SSK-space-saver-keyboard-1370475-/321374822861
Looks like he has bolted the bottom row. Wouldn't that cause problems with it sitting right the case?
The guides (like Sandy's) say not to use bolts there, either do nothing or use self-tapping flat head screws instead.
Daily Driver: Poker II Backlit (Ducky Mini-fied) + Amazon o-rings. Future daily driver IBM AT Model F (restoring now). For fun: IBM SSK 1397681 (NIB), IBM SSK 1391472, IBM Industrial 101 Square label 1388032, IBM Industrial 101 Black label 1394946, IBM 1391401 (bolt-modding now), IBM 1370477, IBM 42H1292 (USA), IBM 52G9700 IBM, and more....
Ducky Shine w/Blues + WASD o-rings, Ducky Shine 3 TKL w/Browns + ebay o-rings, Rosewill RK-9100 w/Blues, Apple Wireless (slim), Apple Wireless White A1016, Apple Extended II ADB. Next? HHKB2Pro?
Online fohat.digs
Re: SSKs
« Reply #6 on: Thu, 10 April 2014, 15:01:39 »
There are some little plastic ridges that can be snipped with wire cutters. A few little 3mm squares to make room for the nuts.
Offline E TwentyNine
    • Some of My Keyboards
Re: SSKs
« Reply #7 on: Thu, 10 April 2014, 18:28:59 »
Think I'd rather either reverse the bolts on the row or pull them out completely and let the case clamp the assembly together the way it does normally which can be a snug fit (or made more snug by putting something inside the bottom of the case - few sheets of paper, plastic, etc.).
Offline Grr8
  • Quack!
Re: SSKs
« Reply #8 on: Thu, 10 April 2014, 19:07:18 »
Or do a screw mod with flat heads for that row (like phosphorglow and avid collector do all over).
Have you seen an early 1985 board where it is suppose to have a piece of poly foam doing exactly this?
Re: SSKs
« Reply #9 on: Thu, 10 April 2014, 19:15:38 »
Not that I can recall.  You know of one?   Is it missing the rivets in the bottom row?
Offline Grr8
  • Quack!
Re: SSKs
« Reply #10 on: Fri, 11 April 2014, 18:09:50 »
Sorry for being unclear - I was referring to this part of what you said "putting something inside the bottom of the case"
There are suppose to be early 1985 Model Ms with poly foam under the plate supporting it. Anyhow it is OT.
Re: SSKs
« Reply #11 on: Sat, 12 April 2014, 18:22:16 »
When did this place become a stickler about OT-ness?  Where did you hear this?
Some M's have foam under the controller board.
