Author Topic: Silent replacement for unicomp?  (Read 1547 times)
Offline phoebus
« on: Thu, 10 April 2014, 01:52:25 »
I have been using IBM M and unicomp for ages now and I love them. I love long key travel and the tactile response of buckling spring. I also love clicking but I'm not alone in the office anymore so I can't use it anymore because it's too loud.
So now I'm looking for reasonably-priced (!) full-size silent mechanical keyboard with _standard_ windows UK layout similar to buckling spring. Would MX clear be the best replacement?
which keyboard would you suggest? I don't need illumination or "gaming-features"- it's for programming.
"CODE" keyboard looks nice but it's a bit on expensive side.... what would you suggest?
Offline hoggy
  • * Ergonomics Moderator
Re: Silent replacement for unicomp?
« Reply #1 on: Thu, 10 April 2014, 02:03:14 »
Have you tried using floss to quiet the keyboard down a bit?  It won't make it silent, but it's an easy first step.
Offline jacobolus
« Reply #2 on: Thu, 10 April 2014, 02:03:39 »
The most tactile quiet switch you’re going to find is the Matias “quiet” switch. That’s not going to feel like a Model M, but it’s in many ways closer than MX clear. (With the caveat being that Alps/Matias switches have the actuation point much higher up than buckling spring or Cherry MX switches, with lots of post-actuation travel; some folks like this, others don’t)
Their UK reseller (only way to get a UK layout) has them available here:
http://www.keyboardco.com/keyboard/matias-quiet-pro-for-pc-uk.asp
Does £99.00 ex. VAT count as “reasonable price”? (Everyone has a different idea of reasonable.) :)
About the sound level, specifically, check out: http://geekhack.org/index.php?topic=56648.0
« Last Edit: Thu, 10 April 2014, 02:11:59 by jacobolus »
