Author Topic: 3D Printed ErgoDox Tent  (Read 5201 times)
Offline madereth
    • My Blog
« on: Fri, 11 April 2014, 15:40:42 »
I just published the source for a 15 degree tent for the ErgoDox that can easily be printed on a Makerbot or other 3D printer:
https://github.com/adereth/ergodox-tent
I can relatively easily make versions at different angles or one that works for the wrist-rest version if there's interest...
Kinesis Advantage LF - Kinesis Advantage with Cherry MX Blues - ErgoDox with Cherry MX Blacks - Cherry MX 8100
Offline mkawa
  •  No Marketplace Access
  • (ツ)@@@. crankypants
Re: 3D Printed ErgoDox Tent
« Reply #1 on: Fri, 11 April 2014, 15:54:27 »
i frown at your use of clojure, but do understand where you're coming from on that :))
anyway, it seems like you should be able to make the generated scad parameterizable..?
Offline tricheboars
  • Keyboards are Important!
« Reply #2 on: Fri, 11 April 2014, 23:24:41 »
said this on reddit but i will say it again.  MAKE A FULL HAND VERSION YO!
Offline l_b
    • vanutsteen.nl => nerds only
« Reply #3 on: Thu, 10 July 2014, 16:30:05 »
Would this also work with the massdrop case?
Nevermind, stupid question...
« Last Edit: Thu, 10 July 2014, 16:35:00 by l_b »
Offline madereth
    • My Blog
« Reply #4 on: Mon, 02 November 2015, 23:16:50 »
Looks like somebody forked my version and made something much better, including full-hand support: https://github.com/bchociej/ergodox-stand
Offline grav3serker
  • graves + berserker = grav3serker
« Reply #5 on: Tue, 03 November 2015, 01:05:53 »
I really want to try an ErgoDox. They seem really comfy and fun to type on, especially with an awesome tent like that! Looks great!  :thumb:
