Author Topic: Place to buy clear switches?  (Read 1649 times)
Offline Ronnn
« on: Mon, 14 April 2014, 22:06:23 »
I have been using mx brown for 6 months. 3 months on logitech g710+ and 3 months on poker 2. Although they have same switches, the brown in poker tends to feel heavier than g710+ (the tactile is more noticeable). The brown in g710+ feels like red. Probably it's due to the pbt keycaps on poker 2.
Now I want to try mx clear. It is mechanicalkeyboards.com the best place to get cheap switches? 110 pack is $53.90. Is there anyplace where I can get clear cheaper?
Also, I am thinking about swapping the spring in clear. Prefer black springs. Where can I buy the black springs(only the spring)? If it's not possible, is there any alternatives? I know originative sells some. The heaviest I can get from them is 62g, others all sold out. How is the 62g spring compare to black spring?
Thank you for your help!!  :)
Offline Pacifist
  • on hiatus
Re: Place to buy clear switches?
« Reply #1 on: Mon, 14 April 2014, 22:13:17 »
New, MK is your best bet
Used, try to find a board on ebay with them. Results vary
IIRC 62g korean springs are lighter than stock black springs. There should be a diagram on originative
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #2 on: Mon, 14 April 2014, 23:30:30 »
You could also check
www.mouser.com
www.digikey.com  (I have bought clears from hear but that was a while ago.)
Offline SonOfSonOfSpock
« Reply #3 on: Mon, 14 April 2014, 23:36:11 »
http://techkeys.us just started selling switches as well. I was looking for a source for strong springs like those in MX blacks recently and didn't have much luck on commercial sites. Sprit is doing a GB for springs. Not sure if he'll do another round though: http://geekhack.org/index.php?topic=55888.0. Otherwise, maybe check the classifieds.
Offline Melvang
« Reply #4 on: Mon, 14 April 2014, 23:44:21 »
If you want springs from MX Blacks check with e-waste and e-recycle shops.  I have picked up 3 wyse boards with MX Blacks for $3 each, an AEK II with cream alps for $5, and a Lexmark M for $5.
