Author Topic: [WTB] Cherry plate stab for space bar  (Read 2180 times)
Offline strict
  • TKL Zealot
  • Trade Count: (0)
« on: Tue, 15 April 2014, 09:39:57 »
Im looking for a Cherry plate mount stabilizer that will fit a 6.25 space bar. I picked up a vintage WYSE terminal board that came with a whole bunch of the smaller cherry plate stabs but the space bar is a PCB mount cherry stab (and roughly 9ft long ...). I'm thinking I'm going to convert either my Phantom or Filco to cherry stabs (both ANSI 125).
« Last Edit: Tue, 15 April 2014, 09:42:16 by strict »
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
Re: [WTB] Cherry plate stab for space bar
« Reply #1 on: Tue, 15 April 2014, 10:08:25 »
GON and Feng have them I think. In fact, I received mine from GON last week.
|||My other keyboards :
x
Offline strict
  • TKL Zealot
  • Trade Count: (0)
« Reply #2 on: Tue, 15 April 2014, 10:39:33 »
Would you happen to have a URL for either seller? I checked GONs site but could only find PCB mount stabs and didn't find anything at all for feng.
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
« Reply #3 on: Tue, 15 April 2014, 10:48:56 »
Sorry, I meant IMSTO.
They are all in my Pearltree.
IMSTO and GON.
And WASD has the plate mounted Costar stabilizers.
However, all of these can be used with plates as far as I know.
x
Offline strict
  • TKL Zealot
  • Trade Count: (0)
« Reply #4 on: Thu, 17 April 2014, 07:50:47 »
After doing some further investigation I'm not sure Cherry even makes a plate mount stab with a wire that will fit a 6.25 spacebar. I think I will either need to bend my own wire or buy one from someone who has made one. Can anyone confirm for sure?
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
« Reply #5 on: Thu, 17 April 2014, 09:08:26 »
Which stabilizers are you talking about right now? Costar or Cherry?
Because WASD has the Costar version and GON the Cherry one.
x
Offline strict
  • TKL Zealot
  • Trade Count: (0)
« Reply #6 on: Thu, 17 April 2014, 09:36:39 »
Cherry plate stabs, I already have costar on my boards and want to convert to Cherry like I said in the OP. Ive only been able to find part numbers on Cherrys site for 1x7, 1x8, 1x9, 1x10 sized cherry plate stabs and nothing for 1x6.25.
Offline JaccoW
  • Fire Typer!!
  • Trade Count: (0)
  • Keyboard is Lava!
« Reply #7 on: Thu, 17 April 2014, 09:50:13 »
If I am not mistaken you could simply use the stabilizer wire from the pcb mounted ones. Those are a lot easier to source. But maybe someone else can chime in.
x
Offline whiskytango
  • Trade Count: (0)
  • Don't touch the trim
« Reply #8 on: Thu, 17 April 2014, 10:35:02 »
Strict, pm me if you're interested in some hand bent wires. And yes, you use the same wire for both cherry plate and pcb stabs
Offline strict
  • TKL Zealot
  • Trade Count: (0)
« Reply #9 on: Fri, 18 April 2014, 07:20:38 »
I just bought two SS 6.25 cherry stab wires from YUIOP, thanks anyways though!
