Author Topic: Thank You  (Read 13871 times)
Offline Thechemist
Thank You
« on: Tue, 15 April 2014, 15:27:40 »
Just wanted to say thank you for the awesome job Brad did taking care of my defective switches. This is why I will continue to purchase from you guys in the future.
Offline i3oilermaker
  • * Moderator
  • techkeys.us
    • TechKeys
Re: Thank You
« Reply #1 on: Tue, 15 April 2014, 15:37:00 »
I base my business decisions on how I would want to be treated as a customer.
I have taken the Blue switches off for now and will hopefully get them back soon after dealing with the manufacturer.
If anyone want potentially faulty switches as a very discounted rate, let me know.
Offline danielucf
  • Horrible Mailman
  • Hmmmm beer.
Re: Thank You
« Reply #2 on: Tue, 15 April 2014, 15:42:06 »
faulty how?
  • * Moderator
  • techkeys.us
    • TechKeys
Re: Thank You
« Reply #3 on: Tue, 15 April 2014, 15:48:40 »
I have had reports of switch that don't audibly click properly, scratched housings, and debris in the the switch causing it not to return properly.
Overall seems like a bad batch.
Re: Thank You
« Reply #4 on: Tue, 15 April 2014, 16:13:55 »
Does this only affect the blue switches?
  • * Moderator
  • techkeys.us
    • TechKeys
Re: Thank You
« Reply #5 on: Wed, 16 April 2014, 09:44:45 »
I have had a few isolated issues with the Black switch which I have dealt with on a case by case basis.
No complaints on the Red or Brown switches.
Bottom line is if you are not satisfied, I will make it right.
