Author Topic: How to correctly rivet-mod your Model M  (Read 2680 times)
Offline komar007
    • komar's blog
« on: Wed, 16 April 2014, 16:17:48 »
Here it is:
4 different techniques;)
Offline iri
Re: How to correctly rivet-mod your Model M
« Reply #1 on: Wed, 16 April 2014, 16:33:05 »
hello agent mosquito. awesome video.
-Ray Bradbury
« Reply #2 on: Wed, 16 April 2014, 16:33:25 »
LOL I love that video
Offline Melvang
  • Exquisite Lord of Bumfluff
  • Melvang's Desktop Customs
« Reply #3 on: Wed, 16 April 2014, 20:25:36 »
When I was in the service solid cold worked aluminum riveting was part of my training and I had to do some as well in the fleet.  This has some very good information.  The "sheet metal riveting clamps" they referred to are called Cleco clamps.  I actually wish they would have had this video in my training.  All info given is very accurate.
Although, if you have seen one of the rivet guns in action you wouldn't let one in the same building as your M.
« Reply #4 on: Wed, 16 April 2014, 20:28:26 »
Hahaha.  You can get smaller guns for this sort of work though, right?
Offline Melvang
« Reply #5 on: Wed, 16 April 2014, 20:47:00 »
They don't hit that much lighter and hit much faster.
Skip to about 6:20
« Last Edit: Wed, 16 April 2014, 21:19:15 by Melvang »
« Reply #6 on: Wed, 16 April 2014, 21:17:23 »
Skip to about 6:20
Change it to HTTP instead of https and it will work
like so
Code: [Select]
[youtube]http://www.youtube.com/watch?v=3zQaMz7rtqY[/youtube]
Offline Melvang
« Reply #7 on: Wed, 16 April 2014, 21:20:13 »
Either way even these smaller guns would smash the barrel plate to bits.  Now if there was a version of the M that had a metal barrel plate I would be all over that like a fat kid on a cupcake.
« Reply #8 on: Wed, 16 April 2014, 21:21:30 »
 :eek:  That would be so glorious...
Offline Melvang
« Reply #9 on: Wed, 16 April 2014, 21:52:09 »
I could be done I would think.  All aluminum.  It would be simple rolled aluminum for the actual back plate and extruded aluminum for the actual barrels with laser welding.  Though the laser welding and the custom die for the extrusion would be expensive as hell.  I still want one.
This would probably be my unicorn board.  But have the circuitry resemble the F just for the NKRO geek factor.  Ohh and MX compatible stems for customization goodness.
« Reply #10 on: Wed, 16 April 2014, 22:29:11 »
I wish I could hot rivet at home instead of just doing pop rivets.
Offline Melvang
« Reply #11 on: Wed, 16 April 2014, 22:35:53 »
Don't need to get them hot.  You can cold work rivets.  It just works a lot easier with aluminum.  We had one of these in out shop.  Worked great on small pieces we could take into the shop and could get the jaws around.
