Author Topic: Identify this IBM terminal keyboard  (Read 2269 times)
Offline blueSmoke
  • Life is what happens while you're busy Fixing RSI
« on: Thu, 17 April 2014, 01:43:39 »
I was looking to buy a Model-F-122 and chop off the numpad and make it a tenkeyless, but this popped up.
http://www.ebay.com/itm/IBM-09F4230-Wired-Keyboard-/331120460206?pt=PCA_Mice_Trackballs&hash=item4d185141ae
Definitely not a model M/F. Looks like a cherry like switch, cant be alps. The seller is confused by the model number, but the actual model is definitely in one of the photos.
I would love to buy it for the case and may be do a tenkeyless mode from a M/F to fit this case.
61231-061231-1" alt="" class="bbc_img" />
Anybody knows what is that blue switch and make/model of keyboard?
« Last Edit: Thu, 17 April 2014, 01:49:32 by blueSmoke »
Model M, Filco Tenkeyless White, Few others, few more others, Noise-hater (ongoing project), blah-blah (to be fillled later...)
Offline tinlong117
Re: Identify this IBM terminal keyboard
« Reply #1 on: Thu, 17 April 2014, 03:32:01 »
It looks like a 73X8360 (Rubberdome version of 1387033 F) http://deskthority.net/wiki/File:73X3860.jpg
According to the Deskthority wiki, it says it is manufactured by micro switch.
Offline ch_123
« Reply #2 on: Thu, 17 April 2014, 04:44:29 »
tinlong117 is right. These things had a few different part numbers, but they are rubber dome keyboards made by Micro Switch (sadly not Hall Effect switches)
The 104-key Model Fs are pretty hard to come by. They are also kind of big (about the width of a 101-key Model M) which sort of defeats the point of having a tenkeyless :D
« Reply #3 on: Thu, 17 April 2014, 06:37:47 »
Seems a shame.
I love the dedicated arrows and 6-pack, but wouldn't an F AT serve your purpose with simplicity?
- Oliver Willis 2026-08-01
Offline E TwentyNine
    • Some of My Keyboards
« Reply #4 on: Thu, 17 April 2014, 08:32:43 »
I've thought about this as well, but when reading through the threads of the people making new controllers for F, there seemed to be a lot going on on the pcb concerning the traces that was fairly precise.  Thought that hacking up that PCB, even if you managed to wire the broken traces up,  would throw everything out of whack.
On top of that, seems a shame to do to a F-122.  You might be better off getting an AT and changing it to a tenkeyless layout.
Offline blueSmoke
« Reply #5 on: Thu, 17 April 2014, 12:07:21 »
OK. I guess I did not mean that. It was just a thought. I would rather think about modding a F AT to tenkeyless.
Offline maatmouse
« Reply #6 on: Sat, 19 April 2014, 13:46:13 »
Looks like an old IBM Model F (one of the terminal keyboards). Definitely an IBM. The layout and the colour give it away. The connector is also a clue. Usually these have a ps/2 connector on them.
Offline Pacifist
  • on hiatus
« Reply #7 on: Sat, 19 April 2014, 13:49:05 »
except its clearly not a buckling spring board....and no F had PS2
