Author Topic: Thinking about swapping caps (again) and painting my QFR  (Read 3509 times)
Offline tigersharkdude
« on: Thu, 17 April 2014, 08:45:29 »
Recently I purchased a two toned set of caps from WASD because I really like a similar themed Poker. Well I got them and Im not the biggest fan, the inspiration keyboard had blanks and I wish I would have went with them myself.
My board (My tower is black with green LEDs inside, hence why I wanted this color scheme)
So, Im not the biggest fan of how it turned out, I think it's a combination of the font and the keycap style (I though I was ordering the DSA style caps). I have also recently ordered a QFR top case and plan on painting it a metallic lime green color (I have access to automotive paint and equipment)
If I go with the metallic lime green for the case, do you all think I should go with BLACK or WHITE blanks? I am a huge fan of WHITE blanks
Offline nuclearsandwich
Re: Thinking about swapping caps (again) and painting my QFR
« Reply #1 on: Thu, 17 April 2014, 09:15:45 »
The white DSA blanks show dirt really quickly and aren't that easy to clean due to the texture on top. I ended up swapping my blanks out after just a couple months the two or three times I put them on a board so I could soak them in soapy water and give them a wash. Then I never put them back on anything.
Offline billnye
  • ability man
« Reply #2 on: Thu, 17 April 2014, 09:18:24 »
If you decide you would like printed caps it might look good with Toxic
http://geekhack.org/index.php?topic=55644.0
« Reply #3 on: Thu, 17 April 2014, 09:25:17 »
I really like the Toxic set, but I dont have the funds to justify spending that much on a "novelty" item
« Reply #4 on: Thu, 17 April 2014, 09:55:23 »
I think the black and green DSA blanks from Signature Plastics look really nice together and that would look pretty slick on a case color matched to the green PBT blanks. Similar to the setup you have now but with DSA blanks and with the case painted lime like you mentioned.
« Reply #5 on: Thu, 17 April 2014, 19:20:17 »
You can clean most keycaps fairly easily with denture tablets.  Just dissolve 2 or 3 tablets in warm water, soak keycaps for 1/2 hour or so, let them dry - clean as new.
If you find that the keycaps are getting dirty (which could be an environmental issue), just plan to do this every couple of months.
As to colour - it is your keyboard, get the keycaps you want.  If you like the white ones, get them.
You'll probably end up buying more at some stage anyway :p
« Reply #6 on: Thu, 17 April 2014, 20:49:26 »
Two weeks later   :p
