Author Topic: HHKB and VirtualBox  (Read 10365 times)
Offline bigpook
HHKB and VirtualBox
« on: Sun, 12 April 2009, 22:23:00 »
I am using VirtualBox as my VM and an HHKB keyboard.
When VirtualBox has the focus you need to hit the Right Control key to break the focus. There is no Right Control key on the HHKB.
I am missing something?
Offline tamasrepus
    • http://blog.samat.org/
HHKB and VirtualBox
« Reply #1 on: Sun, 12 April 2009, 22:38:45 »
No, you're not—there's no control key on the right side of the board.
VirtualBox lets you redefine the break focus key. I personally use the right-side Windows key (I never use it otherwise).
Noppoo Choc Mini w/ Cherry MX Brown
Happy Hacking Keyboard Professional 2, Black w/labels
Topre Realforce 87U, 55g
ABS M1
Happy Hacking Keyboard Lite 2
Logitech diNovo Edge
Sun Type 6 USB
Offline bigpook
HHKB and VirtualBox
« Reply #2 on: Sun, 12 April 2009, 22:56:58 »
Quote from: tamasrepus;28515
I feel pretty stupid now. But thanks, I found the setting.
Offline D-EJ915
HHKB and VirtualBox
« Reply #3 on: Sun, 12 April 2009, 23:32:04 »
yep, or just hook up another keyboard for when you need the ctrl key.
Offline bhtooefr
    • bhtooefr.org
HHKB and VirtualBox
« Reply #4 on: Mon, 13 April 2009, 01:25:24 »
One of these would be perfect:
:D
Offline iMav
  • geekhack creator/founder
HHKB and VirtualBox
« Reply #5 on: Mon, 13 April 2009, 05:03:16 »
I've got nothing to add other than the fact that I LOVE VirtualBox.  :)
Offline bigpook
HHKB and VirtualBox
« Reply #6 on: Mon, 13 April 2009, 06:11:30 »
Quote from: D-EJ915;28524
: ) I had to hook up my model m mini until I figured out how to change the setting. Once found, I changed it to right alt. All is well now.
Offline bigpook
HHKB and VirtualBox
« Reply #7 on: Mon, 13 April 2009, 06:13:45 »
Quote from: iMav;28540
I don't use the vm all that much but have to say that virtualbox installed straightaway and for what it does, works fine for me. Up till now, I was using vmware which worked fine also but was more of a pain to install.
Offline iMav
HHKB and VirtualBox
« Reply #8 on: Mon, 13 April 2009, 07:04:40 »
Quote from: bigpook;28547
I find VirtualBox to be a great desktop VM solution.  However, it really shines as a dedicated VM server solution.  Easy to manage exclusively from the command line.  Unfortunately, I have VM's that will ONLY run under VMware, so I have to use both.
Offline cb951303
HHKB and VirtualBox
« Reply #9 on: Mon, 13 April 2009, 12:31:21 »
for windows guests, if you install guest additions (it's in the menu) you don't need to use a break focus key. It automatically grabs focus when mouse cursor is over and breaks it when you move the mouse out of the virtual machine window. very handy.
Filco Zero FKBN87Z/EB
Kensington Orbit K72337US
