Author Topic: Truly dead after firmware upgrade – any ideas?  (Read 12905 times)
Offline Mike1
« on: Thu, 17 April 2014, 15:50:43 »
Hi folks!
I tried to upgrade my TEK’s firmware today and somehow managed to completly brick it. I used the official upgrade tool and a 3.40 hex file from the layout designer (on an old Windows XP machine). First time I pressed Upgrade it went from 0% to 100% but didn’t display a success message, so I pressed it a second time and got a DFU Reset failed error. After reconnecting the TEK it doesn’t even do any USB enumeration anymore. dmesg on a Linux machine is completly quiet.
Soooo, I guess there is no way to flash the firmware over USB if I don’t even see a device ID etc.? How accommodating is Truly Ergonomic concerning replacements in such cases? Would it be possible to do some open heart surgery and flash the firmware with a hardware programmer and some wires?
Regards
Michael
Offline EvillePanda
Re: Truly dead after firmware upgrade – any ideas?
« Reply #1 on: Fri, 18 April 2014, 09:24:50 »
I've heard their customer service is not so good.  Did you turn off the DIP switch before flashing?
Offline Azteca
« Reply #2 on: Fri, 25 April 2014, 15:59:10 »
You can try resetting the MCU/firmware, it might allow you to reinstall a firmware. It works most of the time, if you really bricked the MCU, then there is not much to do.
Open the keyboard
Reset the MCU
Upload a Firmware
Close the keyboard
 :thumb:
How to open the Truly Ergonomic Keyboard:
http://geekhack.org/index.php?topic=38943.msg803906#msg803906
Info provided by Truly Ergonomic:
Please be aware that if you open the keyboard, you will dismiss all guarantees.
1.   First remove the 9 screws that hold the palmrest, and then remove the palmrest.
2.   Then remove the top 2 screws and the 4 additional screws that were hidden by the palmrest.
3.   There are 2 additional screws under the back label – located on each of the top corners. Press the label on each corner with your thumbs or fingers to feel where the screw cavity is located, and then use a screwdriver or cutter to split through the label. http://www.trulyergonomic.com/store/image/data/Truly_Ergonomic-underside_all_screws.jpg
4.   After all screws are out, you need to 'horizontally-twist' the top-body against the bottom-body as there are 6 'hooks' that hold these two parts together; 4 hooks on the backside where the cable is located, and 1 hook on each side.
How to Reset the MCU
http://geekhack.org/index.php?topic=38943.msg787293#msg787293
With the keyboard plugged into your computer:
Touch Pin 1 and pin 36 - the upper pins of each side of the chip when the round angle mark is at the top left.
Upload default firmware:
https://www.trulyergonomic.com/store/firmware-upgrade--truly-ergonomic-mechanical-keyboard
Hope it helps.
Offline Mike1
« Reply #3 on: Sat, 26 April 2014, 13:52:44 »
Thanks for the advice. Unfortunately the reset didn’t help. Looks like the Controller was really running without any (or broken) firmware. It’s really a shame if an end-user device from 2011 can be broken by something as simple as a failed firmware update.
Anyways, I got impatient waiting for an answer from Truly Ergonomic, so I re-wired the whole keyboard (88 diodes, 3m of wire  :thumb:) and used an Arduino Micro as controller. Works like a charm and can’t be broken by a firmware upgrade ;D
Offline Azteca
« Reply #4 on: Mon, 28 April 2014, 17:46:41 »
Great that you were able to rewire. Can you post some images.
Is the Arduino controller programmable, or you don't need reprogramming?
Offline EvillePanda
« Reply #5 on: Wed, 30 April 2014, 11:29:07 »
That's impressive.  Glad you got it working.
« Reply #6 on: Wed, 30 April 2014, 11:35:54 »
Using the reset pin jumps to the bootloader.  It shouldn't be possible to corrupt the bootloader with a botched firmware load.
Offline addwyn
« Reply #7 on: Fri, 02 May 2014, 10:39:35 »
...Unfortunately the reset didn�t help. Looks like the Controller was really running without any (or broken) firmware...
DIP switch #5 must be ON (firmware protected) during the reset to have the MCU restarting in ISP mode (Yes, that's the opposite position of the DIP switch #5 OFF that allows firmware to be reprogrammed the "normal" way !)
« Last Edit: Fri, 02 May 2014, 10:47:25 by addwyn »
Offline zorglups
« Reply #8 on: Tue, 14 November 2017, 17:54:13 »
Hello Mike,
Would you PLEASE be so kind to share some details on your re-wiring of the TEK?
Did you load QMK on it?
Thanks a lot,
Pierre
« Reply #9 on: Tue, 14 November 2017, 18:56:48 »
Hello Mike,
Thanks a lot,
Pierre
Was QMK a thing in 2014?
« Reply #10 on: Tue, 14 November 2017, 20:23:26 »
Hello Mike,
Thanks a lot,
Pierre
Sounds like he essentially did a whole hand-wire job on it.  He probably used TMK given the year, as spamray noted.
