Author Topic: Would SP rgb+y modifiers work with a dolch set, or are the profiles too short?  (Read 2366 times)
Offline rockhawksam
  • I'm a big dirty **** Hawk
    • tanglingstars.com
I have heard that SP profile is pretty short, but would it still look good on a dolch board or is too way too different profile wise?
Offline Pacifist
  • on hiatus
if you have to have everything alligned, go with a cherry ds RGB set(feng is running one)
otherwise Id get all the other mods from SP too to make it uniform
Offline bazemk1979
Feng RGBY GB is already closed
Offline Pacifist
  • on hiatus
then when he puts them on his store the OP can get them there
Offline rockhawksam
    • tanglingstars.com
Thanks, will do!  :thumb:
You could try the GMK RGB keys from EK:
http://elitekeyboards.com/products.php?sub=access,cherrymxkeys
(scroll down near the bottom of the list).
Offline Pacifist
  • on hiatus
no y
plus op I think is looking for caps for an OG dolch so 1.5 and 1.75 is needed
