Author Topic: CM Keyswitch Tester Teensy Mod  (Read 1674 times)
Offline tbc
« on: Fri, 18 April 2014, 19:43:33 »
Can someone link me to the thread where someone put a teensy into the cm storm switch tester?
I'm having a really hard time finding it -_-
Offline Grendel
Re: CM Keyswitch Tester Teensy Mod
« Reply #1 on: Fri, 18 April 2014, 19:53:50 »
A bit more collated here->.
- I'm game !
Offline drinkbleach
« Reply #2 on: Fri, 18 April 2014, 19:55:33 »
http://geekhack.org/index.php?topic=50594.120
I was also thinking of trying this mod. Let me know how it works out if you decide to do this.
Offline tbc
« Reply #3 on: Fri, 18 April 2014, 20:14:58 »
thanks!
for those curious, I'm thinking of converting it into a cursor key 'board' for use with 60% boards.  it'd work BETTER for something with a built-in usb hub, such as a HHKB, but it would obviously be functional by itself.
4 cursor keys + backspace + enter fits my usecases perfectly
