Author Topic: Black vs White keyboard  (Read 29996 times)
Offline epsilon
« on: Sun, 20 April 2014, 20:29:54 »
I'm trying to decide between a white Poker II keyboard and a black one.
Are there any relevant differences aside aesthetics?
Thanks for your response.
Offline Pacifist
  • on hiatus
Re: Black vs White keyboard
« Reply #1 on: Sun, 20 April 2014, 20:30:22 »
apart from aesthetics, no
Offline epsilon
« Reply #2 on: Sun, 20 April 2014, 20:32:08 »
Should I worry about the caps getting darker or something like that?
Offline Lastpilot
  • Power stance
« Reply #3 on: Sun, 20 April 2014, 20:32:12 »
Unless specially coated, white plastic boards tend to yellow over time when exposed to UV light. I think HHKB is an example.
But then black is so boring.
The answer is obviously getting a custom metal case!
Offline Pacifist
  • on hiatus
« Reply #4 on: Sun, 20 April 2014, 20:32:59 »
But  really, how long will that take? You'll probally have 10 more boards by then
Offline Lastpilot
  • Power stance
« Reply #5 on: Sun, 20 April 2014, 20:37:45 »
A valid point Pacifist!
I suppose it would depend on how much sunlight you let in your room. But yeah, either way I think it would take a while!
But, then again, one of the beauties of typing on a mechanical is its durability. You need a case that can last as long as the switches inside, right?
Offline Pacifist
  • on hiatus
« Reply #6 on: Sun, 20 April 2014, 20:49:37 »
Of course. Im sure that by the time the case yellows, you'd get a snazzy alum case to go with the board
Offline epsilon
« Reply #7 on: Sun, 20 April 2014, 21:08:26 »
I have decided to purchase the "black" one. In fact, the keycaps are kinda charcoal to me, they are not really black.  That will set it aside from my other black keyboards! :)
Besides, I live in Brazil, and there is too much sunlight in here!  :cool:
Offline Tony
« Reply #8 on: Sun, 20 April 2014, 23:23:33 »
All white keyboards will become darker after 20 years of sunlight exposure. See the Compaq MX 11800s for evidence.
Offline hoggy
  • * Ergonomics Moderator
« Reply #9 on: Mon, 21 April 2014, 01:21:32 »
One extreme solution would be to move to the UK...😀
Offline False_Dmitry_II
« Reply #10 on: Mon, 21 April 2014, 01:45:18 »
Wait, what? I was pretty sure old stuff yellowed because of their chemical makeup. The Compaq MX 11800 is something from that era.
So why are we assuming that the HHKB and other modern things have that same failing?
« Reply #11 on: Mon, 21 April 2014, 07:39:20 »
Plastic usually yellows due to the chemical makeup. I think the bromine for fire retardancy is the usual culprit. The only HHKB I've seen yellowed is part of the case on a HHKB pro 1, see this image:
Offline ajx
« Reply #12 on: Mon, 21 April 2014, 08:21:05 »
Usually i pick black keyboard but for Poker II, i decided to pick white version.
Its a matter of aestheticism, not everyone likes white version
Black Poker II comes with PBT keycaps and its rather dark grey than full black
With black case, its contrasted and i quit dislike it.
White vs Black keyboard, in my opinion:
+ easy to clean up when keys get dirty, you ll see it immediately
+ more beautiful (still a matter of taste)
+ pretty rare for high technology stuff that usually comes often in black version (TV, phones, consoles...)
+ sightly brighter into darkness
- its more complicated if you want all your stuff matching color with your keyboard, meaning desktop, screen, mice...
- get dirty quicker if you are lazy to clean up
- can yellow over time but at least it will becomes less white than new white stuff for sure (i had white iPhone and within fews month of use, it clearly less white than other newer white phones)
Offline terrpn
  • Alpha Geezer
  • - Buy Vintage -
« Reply #13 on: Mon, 21 April 2014, 09:04:51 »
right............the polymers in the plastic degrade due to the attack from UV and turn yellow-brown. i was under the impression that newer, modern, expensive plastics they put in keyboards retard that from occurring? they have UV stabilizers in them to avoid this happening?
either way avoid from placing in direct UV.
i personally like white boards, but not to many people sell them in white anymore. like one previous post there are a lot of options out there for custom cases or even customizing your own case. the paint they make out there today for plastic in particular, vinyl dyes, etc. are pretty bullet proof if you do it right. mine adhered to the plastic like factory and you would think it would have came that way.
Luga G80-1865/MX Reds + Dolch G80-1813/MX Blues + G80-3700HQAUS + DK9008G2 Pro/MX Browns Thick PBT + DK9008G2 Pro/MX Clears Thick PBT +  QFR TKL/Ghetto Greens + Cherry G80-1800/MX Blues + IBM Model M SSK Bolt Modded + IBM Model M + IBM Model F + IBM AT F + Cherry G80-1000 (HAD)/MX Vintage Blacks + Razer BWU/MX Blues + Leading Edge DC2214/Blue Alps + Compaq MX11800/Browns + Chicony 5181/Monterey Blues + Chicony 5161/MX Black Cherry Clone + Focus 2001/White Alps + Chicony 5191/White Futabas + Olivetti ANK27-101 + Dell (Old Logo) AT101/Black Alps + NMB RT8255C+/Black Space Invaders + Unitek K260/Green Alps + Apple M0116/Orange Alps + AEK II M3501/Cream Alps + AEK M0115/Orange Alps + NEC  APC412/Blue Sliders + NEC APC410/Blue Sliders + Omnikey /White Alps + Wang/Yellow Alps (Omrons) + Laser/White SMK + Fame/Blue Aruz + AEK II M3501/Salmon Alps + Zenith ZKB-2R/Green Alps + Wang 724/Orange Alps + DK1087/Green Alps + Zenith ZKB-2/Yellow Alps + Dell Old Logo AT101/Salmon-Pink Alps + Leading Edge AK1012/White SMK's + Magitronic SK-1030/White (Linear) Futaba's + Packard Bell/White (Clicky) Futaba's + Datacomp DFK101/White  Alps + SGI AT101/Dampened White Alps + NMB AQ6RT-72511/Grey Space Invaders (Hi-Tek) + Datacomp/Blue Alps + Phillips 2812/White Space Invaders (Linear) + Dah Yang K251/Vintage MX Blues + Chicony 5161/DS Caps/Vintage MX Blue + Archie-NMB AQ659ZRT-725/Black Space Invader (Tactile) + IBM Model M 71G4644 (RD) Bolt Modded with Soarers Converter + IBM Model M Silver Label 1390131 + Cherry G80-1501/Vintage MX Clears + Focus FK8000/Linear Futabas + Gateway 2000 Anykey Programmable/Maxi-Switch + Dell GY13PVAT101/Dye Sub Caps/Salmon Alps + Chicony 5161/White Alps + AST K0B101/Slider over RD + Qtronix QX-32H + Everex/NMB RT8255CW+ Black Space Invaders-Split Erase + Tandon/NMB AQ659ZRT-101A/Beige Space Invaders + Cherry G80-11903 MNRUS/MX Blacks + Apple IIGS A9M0330/SMK Whites + WYSE PCE/MX Blacks + Chicony 5160AXT/Clicky Futaba + Cherry G80-0528/Vintage MX Blacks + Dell AT101/Linear (Modded) Black Alps+Topre 55g
Offline maatmouse
« Reply #14 on: Mon, 21 April 2014, 16:32:50 »
White always shows up the dirt and fluff more than black. White keyboards in my house always end up looking like they've been exposed to cigarette smoke (they turn a bit yellow).
Offline Danule
« Reply #15 on: Mon, 21 April 2014, 17:03:59 »
White usually looks more special these days as most computer hardware has been black since the late 90s.
45g Brown Brown Blue
Offline Hyde
  • White Tofu Extraordinaire
« Reply #16 on: Mon, 21 April 2014, 18:46:23 »
^ This
Also contrary to popular believe, white keyboard actually look more clean.  Because dust show up more on black keyboards.
But I'd mainly buy white keyboards because it's more unique.
Offline zig_ziglar
« Reply #17 on: Mon, 21 April 2014, 20:02:24 »
^ This
I'm a fan of the brilliant white look too. Keyboards have been off white or grey for so long. Or black in higher end gear.
However, the trend for white is picking up momentum, so it won't be so unique for long. Not to say it will become less cool.
Offline uzoc
« Reply #18 on: Mon, 21 April 2014, 20:15:41 »
For me the keyboard can be black, but the keys have to have better contrast (white or another lighter color).
It's easier to see in low light, etc.
« Reply #19 on: Mon, 21 April 2014, 20:23:02 »
type faster on black keyboards
Offline pbtforever
« Reply #20 on: Mon, 21 April 2014, 21:36:19 »
Don't buy white.  Makes you look like an Apple user.   :p
Offline minho
  • i'm kind of back
« Reply #21 on: Mon, 21 April 2014, 22:49:49 »
If you plan on keeping the stock keycaps, I think the white looks better. The pad printing on the charcoal version (which I have) tends to get dirty, but the legends are darker on the white keycaps so this won't be nearly as much of an issue.
However, I am planning on replacing my keycaps with thick blank black keycaps and get a black aluminum case, so the black backplate looks better with my future plans for the keyboard.
Offline Beca
  • what am i doing with my life
« Reply #22 on: Mon, 21 April 2014, 22:51:57 »
white4ever. I owned a white/beige keyboard for a while and it never appeared dirty. just gotta wash your hands properly.
« Reply #23 on: Tue, 22 April 2014, 05:28:46 »
Here's another take: I have white (KeyCool), off-white (HHKB), gray (QFR) and black (Ducky) (and yellow (ducky) if you insist).
Of the shades of gray, more keycap sets seem to suit white board than the black one for example Miami and CCnB.
