Author Topic: GMK/Cherry Spacebar Discussion - Markings?  (Read 8825 times)
Offline phoenix1234
« on: Sat, 19 April 2014, 07:22:17 »
Mod note: the following posts have been split off from the Simple Questions Simple Answers thread for a more in-depth discussion
Hmm, well at the very least, are all (unmodified) 11800 boards guaranteed to have a PBT bar? There are quite a few on eBay.
yea 11800 has pbt
How are you so certain? I'm not sure. All the other Cherry boards I've bought with PBT caps have had ABS spacebars. Do you have a link?
My 11800 has PBT, and I really doubt cherry would put pbt on one board out of all of their boards
Are you REALLY sure they're PBT? Like, you've done the acetone test to the underside, and it wasn't affected? Because Cherry liked to make ABS spacebars in molds that had PBT stamped in them.
I can confirm Cherry G80-11800 has a thick PBT space bar (4 stems on the bottom totally).
7x Cherry PBT space bar weight: ~7.5g
7x GMK ABS space bar weight : ~6.8g
7x SP ABS space bar weight: ~6.2g
« Last Edit: Mon, 21 April 2014, 14:50:52 by Photoelectric »
I like linear switches
Offline intelli78
Re: Re: Simple Questions, Simple Answers (FAQ in the OP)
« Reply #1 on: Sat, 19 April 2014, 07:27:12 »
is the molding of the Cherry and GMK space bars exactly the same? (Including stems) If not, that could account for the weight difference rather than the density of the material.
Offline phoenix1234
« Reply #2 on: Sat, 19 April 2014, 07:42:05 »
They are not exactly the same but they have similar structures. The PBT space bar is hard and steady. It is not easy to bend the PBT one while the ABS is. Plus, the PBT space has well-finished shapes, surfaces and corners.  It is not easy to tell in the picture but I believe we all can tell which one is a PBT space bar when we touch it and try to bend it.
Here is my comparison between the three 7x space bars
61434-0
61436-1
Offline Dubsgalore
« Reply #3 on: Sun, 20 April 2014, 13:21:52 »
I'd like to add something here
the left is a new orange GMK 7x spacebar, and the right is an OG white 7x spacebar. the Orange has a '1' on it and the Original has a '2' on it.
I can say all my gmk spacebars from Ivan's buy feel a little warped outward, where the original spacebar feels 100% perfectly flat.
I'm going to go check some more OG 7x spacebars and an originative 7x spacebar to see what numbers they have..
« Reply #4 on: Sun, 20 April 2014, 13:50:51 »
my originative 7x also have a 1
Offline Candyflip
« Reply #5 on: Sun, 20 April 2014, 14:04:17 »
My two og cherry 7x also have 1
« Reply #6 on: Sun, 20 April 2014, 14:34:38 »
I see nothing there that indicates anything other than a standard layout, with the possible exception of an off-center capslock.  The spacebar is 6.25x and the bottom row mods are all 1.25x.  Everything else looks standard ANSI.
I think he meant the colors etc.
Oh.  I suppose that's possible too.  :)  If that was the case, then it looks like it's probably the GMK Dolch from Originative.
« Reply #7 on: Sun, 20 April 2014, 15:02:27 »
My Ivanbars have 1 on them.
« Reply #8 on: Sun, 20 April 2014, 15:04:24 »
Mine do as well.
Offline Pacifist
  • on hiatus
« Reply #9 on: Sun, 20 April 2014, 15:05:35 »
GMK has 1, 11800 also has 1
Offline Dubsgalore
« Reply #10 on: Sun, 20 April 2014, 15:20:33 »
here's what i've found on my 6.25xs
Ivan & Originative GMK Dolch are the same
The lanch has 2, with stab inserts
and the 8904 is pbt apparently and has the perma MY stab molds
o.O
do you have a photo of that? :P
Offline Candyflip
« Reply #11 on: Sun, 20 April 2014, 15:36:40 »
I don't have a good camera for macro but it is what it is  :))
61645-0
Offline Dubsgalore
« Reply #12 on: Sun, 20 April 2014, 15:41:10 »
hmm cool well let's all try to figure out what this means :))
« Reply #13 on: Sun, 20 April 2014, 15:48:37 »
I saw these on KBDmania, where can I get similar ones?
http://www.kbdmania.net/xe/index.php?mid=photo&page=2&document_srl=8294012
Looks like vortex PBT doubleshots. They should be up for sale on MechanicalKeyboards.com
o.O
I think it's time to branch this off into a new thread. Or perhaps add it to this thread that Intelli78 started. Think this is a good discussion to document in a thread on it's own so it doesn't get buried here.
« Reply #14 on: Mon, 21 April 2014, 10:03:18 »
Breaking out a discussion that's brewing in the Simple Questions Simple Answers thread on spacebar markings. Also check out a related topic from intelli78 on 7x PBT spacebars.
o.O
Mine do as well.
o.O
Offline IvanIvanovich
  • Mr. Silk Underwear
Re: GMK/Cherry Spacebar Discussion - Markings?
« Reply #15 on: Mon, 21 April 2014, 13:35:26 »
In general Cherry ABS molds will have a '1', which also GMK since they came from Cherry. Cherry PBT typically has '2' and POM '3'. Exception is with 6x spacebar where they all have 'PBT' inside regardless of material, and newer MY style integrated stabilizer variant.
Typically the spacebar is the same material as the rest of the keys in the set, but not always. For example I have a 7x black PBT spacebar and it does also have a '2' and the extra set of stabilizer stems typical of PBTs that came off a POM set... OK Cherry. As with anything Cherry this is more a guideline than 100% always.
« Last Edit: Mon, 21 April 2014, 13:37:26 by IvanIvanovich »
Offline tricheboars
  • Keyboards are Important!
« Reply #16 on: Mon, 21 April 2014, 14:07:39 »
yea cherry isnt very consistent with models and materials. sometimes they come with one thing,  sometimes another. it is weird. especially since they are german.
when i bought my POS cherry board even though i had the full model name and number i had no idea what kind of switches were going to be inside. i did know that it was coming with POM caps, which is half the reason i purchased it.
unrelated to spacebars i think GMK makes the nicest OEM/Cherry profile caps in the world.  even their ABS feels great.
PBT spaces are warped. at least the two i have are warped. i have to apply heat and weight to them if i want to use them again.
« Last Edit: Mon, 21 April 2014, 14:11:50 by tricheboars »
Offline Candyflip
« Reply #17 on: Mon, 21 April 2014, 14:34:26 »
I never understood what is up with the pbt marking on an abs spacebar.
Offline yuktsi
  • Colour my life with the chaos of trouble
« Reply #18 on: Mon, 21 April 2014, 23:58:24 »
does anyone notice that the surface of 7x GMK is different from 6.25x? 7x appears to be more shinny
email: yuktsi@ttggrr.cc
My collection
Poker 2 | LZ CE | Leopold FC700R | KMAC 1.2 | EXE | GON NS87 | GON Nerd TKL | Duck Poker | Duck Orion | Realforce 87u 55g | OTD 456GT | LZ B7 | OTD 360C | Ducky G2 Pro | Apple Extended | Apple M0116 | Apple M0116 | Cherry G80-1220HAD | Duck Octagon | HHKB Pro 2 | Duck Unicorn | LZ B8 | LZ RE | ENVKX | OTD 456GT | LZ FE | HHKB Type S | TX1800| Duck Orion V2 | LZ FE | KPad | KMAC Happy | ENVKX | LZ RV | KMAC 2 | Whale | Dolphin | EM7 | TGR Jane | VE.A | DK Saver | Matrix 10xv1.0 | Whale | HHKB BT | Dolphin v2 | EM7 v2 | SSK | SSK (Blue Label) | LZ SQ | Duck Octagon v2 | TX84 | GON Mobik | TX-CP | LZ Ergo2 | KMAC Happy HHKB | TGR 910 | TGR Tris | Matrix 8xv1.2 | KMAC Mini | Mira | Fjell | 356mini | Dolphin GH | EM7 GH | TARO EXENT | Masterkey Pro L Crysta l OTD Koala | Duck Viper | Keycult no.1 | 356mini | 356pad | Matrix 8xv2.0 | 420cl | Matrix 8xv1.0 | Whale Special | Poly Dolphin | Keycult No.2 | FMJ80 | Singa R2 | Whale Poly | 356cl | HBCP | Dolinger | Linger | FMJ80 | KFE
Offline phoenix1234
« Reply #19 on: Tue, 22 April 2014, 00:52:26 »
Thank you mod for splitting this into a separated thread so we can have an opportunity to discuss about the space bars.
 :thumb:
I think in order to identity the material of the space bar whether it is ABS or PBT, we shouldn't trust the number 1 or number 2 on the bottom because as you can see my comparison, a Cherry PBT space bar can have either 1 or 2.
61901-0
61903-1
I think the most reliable factors are the outlook, surface, the 4 bottom-corners, colour of plastic, weight and the stiffness of the spacebar.
« Last Edit: Tue, 22 April 2014, 03:45:28 by phoenix1234 »
« Reply #20 on: Wed, 30 April 2014, 07:53:41 »
They look the same with the bars I have in real life. Could just be a picture thing.
I always thought they were using molding that had that PBT marking and just running ABS into the mold/machine.
