Author Topic: HHKB2 PRO ABS Spacebar?  (Read 3451 times)
Offline iLLucionist
  • Topre is Love.
« on: Mon, 21 April 2014, 10:27:50 »
I started out with a Filco Majestouch 2 TKL, which I will be taking to my work (after modding it with PBT keycaps and o-rings as to not annoy my co-workers). As I am either writing articles, developing software, or doing sysadmin / terminal work, I am on my keyboard for more than 10 hours a day. So, I figured it was time to upgrade and I ordered a HHKB2 Pro Black-on-Black PBT. But I read here on the forums that the spacebar is ABS. Is that right? If so, what is the best way to prevent wear on the spacebar? I read some people put 3M's Crystal Clear tape on it. Is it worth it? Are there any PBT spacebars for the HHKB2 Pro? Any advice?
Re: HHKB2 PRO ABS Spacebar?
« Reply #1 on: Mon, 21 April 2014, 10:29:43 »
You could buy a couple HHKB replacement space bars
 http://elitekeyboards.com/products.php?sub=access,toprekeys&pid=tspacebar_blk
Offline iLLucionist
  • Topre is Love.
« Reply #2 on: Mon, 21 April 2014, 10:32:40 »
Thanks! Aren't there any PBT ones? I just ordered a PBT Ducky keycap set, but perhaps the spacebar is ABS as well.. Looks PBT from the pics.
Offline Flyersfan1
  • Hi!
« Reply #3 on: Mon, 21 April 2014, 11:12:04 »
As far as I know, PBT topre space bars do not exist.
Quote from: Photekq
Offline MJ45
  • HHKB Pro
« Reply #4 on: Mon, 21 April 2014, 11:13:42 »
Most if not all Ducky PBT sets have PBT spacebars but some that I have been warped a little bit.
Offline iLLucionist
  • Topre is Love.
« Reply #5 on: Mon, 21 April 2014, 11:23:35 »
Hmm, ok. Hope that my Ducky PBT set is not warped, that would suck. Too bad there are no Topre PBT spacebars. Well, perhaps the crystal clear tape trick? I hate the feel when they get glossy (like on my Filco).
Offline MJ45
  • HHKB Pro
« Reply #6 on: Mon, 21 April 2014, 11:30:45 »
I think the tape would feel as bad as a shiny one, they are only $4.50ea at EK. I got myself some spare's, they also fit Realforce & Leopold F660C.
Offline iLLucionist
  • Topre is Love.
« Reply #7 on: Mon, 21 April 2014, 13:47:27 »
Great, thanks! Then I'll go for some spare ABS spacebars.
Offline Lu_e
« Reply #8 on: Mon, 21 April 2014, 14:06:17 »
If it is warped you should be able to straighten it out by laying it on a very flat surface, like a glass table or equally flat surface and taking a hair dryer to it. So they say.
Just say NO to ABS keycaps
« Reply #9 on: Tue, 22 April 2014, 05:45:44 »
Welcome to Geekhack!
I'd suggest you buy them sooner rather than later.  These could be the last of the spare keycaps for a long time.
Offline iLLucionist
  • Topre is Love.
« Reply #10 on: Tue, 22 April 2014, 07:31:57 »
Thanks! Hope my HHKB2 will arrive soon, can't wait to see how Topre's feel.
Offline beartung
« Reply #11 on: Tue, 22 April 2014, 09:43:49 »
I have got a orange space bar  ;D
Looking for Topre Orangesicle CC & Topre Limoncello CC
