Advanced search
bounce or buckle?
Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Have you read the
geekhack TOS
lately?
Home
Watched
Unread
Notifications
IRC
Wiki
Search
Spy
Login
Register
geekhack
geekhack Projects
Making Stuff Together!
(Moderator:
Soarer
Iso to ansi left shift
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Iso to ansi left shift (Read 3068 times)
Onez
Thread Starter
on:
Mon, 21 April 2014, 12:11:52 »
I was wondering how difficult it would be to find a keycap of a left shift ansi Mx cherry that would fit over the 2 switches of a ISO board (the left shift and adjacent key). Do they make these or would it require modding?
Thanks in advance.
Logged
Candyflip
Re: Iso to ansi left shift
Reply #1 on:
Mon, 21 April 2014, 12:15:37 »
I don't believe anyone produces those kind of shifts, even you were able to find one you will have problems with the stabilizers. I am not sure about your goal, are you trying to turn ISO into ansi layout?
Logged
Onez
Thread Starter
Reply #2 on:
Mon, 21 April 2014, 12:50:36 »
Yes but just the shift key really as I play alot of FPS games now and would prefer a larger shift key.
Logged
Photekq
wheat flour zone
sorry if i was ever an ******* to you
Reply #3 on:
Mon, 21 April 2014, 12:53:12 »
Unfortunately these aren't available...
To get an ANSI left shift you would need a custom PCB, or you would need to modify your current PCB by drilling new holes.
Logged
Pacifist
Report me *again* if there are gifs in my sig
Elevated Elder
on hiatus
Reply #4 on:
Mon, 21 April 2014, 13:02:48 »
You could do a stem transplant, make the stems only have two and use the shift and other key as the stab, and disable the extra key either through scripts
Logged
FS-Pretty much everything:
http://geekhack.org/index.php?topic=58087
laffindude
Reply #5 on:
Thu, 24 April 2014, 23:12:17 »
PCB is usually not a problem, since most PCBs share layouts now. What keyboard is this. The main problem is if it has a plate. You need a custom plate to have ANSI left shift + ISO Enter.
Logged
Hak Foo
Make America Clicky Again!
Reply #6 on:
Fri, 25 April 2014, 00:40:05 »
I've seen a board that was designed that way, but it was a heap old board with Monterrey switches, and thus, an ALPS-style mount.
This is what the ANSI left shift looked like
Notice how the stem is off-centre to hit the left switch .
Logged
Overton130, Box Pale Blues.
Print
Pages: [
1
Go Up
« previous
next »
geekhack
geekhack Projects
(Moderator:
Soarer
