Author Topic: Qazpad info  (Read 1633 times)
Offline Misterorjoe
Qazpad info
« on: Mon, 21 April 2014, 21:24:49 »
How does one go about acquiring a Qazpad? I built myself an Ergodox, so I am able to build one, but where would I find the components?
Offline Pacifist
  • on hiatus
Re: Qazpad info
« Reply #1 on: Mon, 21 April 2014, 21:52:58 »
step 1. go to the proper thread http://geekhack.org/index.php?topic=43183.0
2. either purchase an extra from metalliqaz or make your own, its open source
3. contact moz for a case (if hes still avalible for it) or, again, make your own
Re: Qazpad info
« Reply #2 on: Mon, 21 April 2014, 21:56:03 »
I need to build the rest of those boards.... I stopped because I ran out of ATmegas.  I'll order some more and build up the rest.
Offline Pacifist
  • on hiatus
Re: Qazpad info
« Reply #3 on: Mon, 21 April 2014, 21:58:17 »
btw how many do you have? I may make another one with a different case
Re: Qazpad info
« Reply #4 on: Mon, 21 April 2014, 21:59:58 »
I've got them with me right here.  Looks like... three.
By the way, have you been able to run yours yet?
Offline Pacifist
  • on hiatus
Re: Qazpad info
« Reply #5 on: Mon, 21 April 2014, 22:04:52 »
Yup, working like a beast. Your software is really easy to use. After some issues with flip(mainly because of laptop USB hub) the hex was programmed really easily. Great for gaming, great for data input, great for whatever you want
