Author Topic: Quiet Tenkeyless?  (Read 2241 times)
Offline magnetik
Quiet Tenkeyless?
« on: Tue, 22 April 2014, 21:36:50 »
I'm looking for a quiet tenkeyless to use at work. I don't have much desk space, and my current keyboard is on it's way out. I've gotten used to a desk layout with this keyboard that's less than 12 inches wide. Is there anything similar on the market?
Offline AKIMbO
  • HHKBro
Re: Quiet Tenkeyless?
« Reply #1 on: Tue, 22 April 2014, 21:40:06 »
Noppoo Choc Mini
Keycool 84
Both are similar in layout, but not quiet like a rubber dome is.
| KBD75 (box reds)
« Reply #2 on: Tue, 22 April 2014, 21:55:30 »
matias quiet pro is very very quiet:
http://www.matias.ca/miniquietpro/pc/
I think the only quieter KB I have is my 30g uniform topre
Offline jabar
« Reply #3 on: Tue, 22 April 2014, 23:57:37 »
MX is not quiet unless you purposely not bottom out, something I don't think I can ever master. A Topre TKL or the Topre Leopold FC660C might be a good option if you have the budget.
Leopold FC660C - Max Keyboard Nighthawk X8 - Ducky DK9008 Shine II 78 Edition - Noppoo Choc Mini - Cherry G80-2100HDD - Cherry G80-8113HDPUS - Plu-M87 - Leopold FC700R Ergo Clears - Deck Legend Frost 105 - IBM F PC Keyboard - IBM M 122 (Lexmark) - Apple Extended Keyboard II
Phantom 7bit
Offline Oobly
« Reply #4 on: Wed, 23 April 2014, 01:44:50 »
I agree with both of the above posts: Matias Mini Quiet Pro or Leopold FC660C are both similar layout (although the Leopold doesn't have the F-key row) and also quiet. They each have their own switch feeling. The Matias uses an Alps-like switch, the Leopold uses Topre capacitive switches.
There are also a number of similar layout boards with Cherry MX switches, but the only way to really make those quiet is by modding the switches yourself. Mine (KBT Pure Limited Edition) is quieter than the rubber domes at work, but I've done a lot of work to get it that way (trampoline and latex mods on all switches, drawer liner mounted PCB, thick keycaps).
Buying more keycaps,
it really hacks my wallet,
but I must have them.
Offline iLLucionist
  • Topre is Love.
« Reply #5 on: Sat, 03 May 2014, 16:40:05 »
I have the Filco Majestouch 2 TKL with o-rings and PBT caps (more sturdy, sound lower compared to ABS IMHO). I find my Filco quieter than my HHKB (especially on the upstroke). I purposefully fitted my Filco with o-rings and PBT caps to make it quiet enough to take it to work.
